Umnik Član
Pridružen-a: Čet 16 Sep 2004 17:52 Prispevkov: 958 Aktiv.: 4.04 Kraj: Novo mesto
Objavljeno: Pet Jun 15, 2007 9:14 am Naslov sporočila: Poučna inženirska |
Problem: One of the most memorable case studies on Japanese management was the case of the empty soap box, which happened in one of Japan's biggest cosmetics companies. The company received a complaint that a consumer had bought a soap box that was empty. Immediately the thorities isolated the problem to the assembly line, which transported all the packaged boxes of soap to the delivery department. For some reason, one soap box went through the assembly line empty. Management asked its engineers to solve the problem. Post-haste,
Solution A: The engineers worked hard to devise an X-ray machine with high-resolution monitors manned by two people to watch all the soap boxes that passed through the line to make sure they were not empty. No doubt, they worked hard and they worked fast but they spent whoopee amount to do so
Solution B: But when a rank-and-file employee in a small company was posed with the same problem, he did not get into complications of X-rays, etc but instead came out with another solution. He bought a strong industrial electric fan and pointed it at the assembly line. He switched the fan on, and as each soap box passed the fan, it simply blew the empty boxes out of the line.
Moral of the story: " Keep It Short & Simple" !! i.e. always look for simple solutions. Devise the simplest possible solution that solves the problem. So, learn to focus on solutions not on problems
Samo v razmislek |
mucek4 Član
Pridružen-a: Sob 18 Jun 2005 20:52 Prispevkov: 2952 Aktiv.: 12.43 Kraj: Tržič - Mesto med gorami
Objavljeno: Pet Jun 15, 2007 9:56 am Naslov sporočila: |
Princip poljuba temu pravijo američani (KISS). Keep it simple, stupid. |
trot Član
Pridružen-a: Čet 18 Jan 2007 20:25 Prispevkov: 1282 Aktiv.: 5.71 Kraj: glej fogl
Objavljeno: Pet Jun 15, 2007 10:06 am Naslov sporočila: |
Tako kot tista reklama: "Porabili smo leta in milijone za razvoj kulija, ki lahko piše tudi v vesolju. In kaj je uporabila konkurenca - svinčnik"
Ne vem a je bil to štos, a je bilo res  |
Sokrat Član
Objavljeno: Pet Jun 15, 2007 10:21 am Naslov sporočila: |
trot je napisal/a: |
http://www.snopes.com/business/genius/spacepen.asp _________________ Ka ti bo pa torba ce si kupu kolo ? |
VolkD Član
Pridružen-a: Pet 24 Sep 2004 21:58 Prispevkov: 14228 Aktiv.: 59.93 Kraj: Divača (Kačiče)
Objavljeno: Pet Jun 15, 2007 11:58 am Naslov sporočila: |
Res je bilo ! Navaden svinčnik !
Ampak pri tej zgodbi je zamolčano dejstvo, da je zlomljena grafitna konica "odplavala" in naredila nekaj elektronske zmede v napravah. _________________ Dokler bodo ljudje mislili, da živali ne čutijo, bodo živali čutile, da ljudje ne mislijo. |
Iztok Član
Pridružen-a: Pet 08 Okt 2004 0:55 Prispevkov: 4974 Aktiv.: 20.95 Kraj: LJ
Objavljeno: Pet Jun 15, 2007 12:32 pm Naslov sporočila: |
Pred leti sem imel za rešit podoben problem na liniji za polnjenje plastičnih sveč z voskom. Mehaniki so mi že skoraj izdelali konstrukcijo s fotocelico in drugimi senzorji ter začeli pripravljat kanale in prostor za elektro omarico avtomatike v kateri bo najmanj LOGO! krmilnik ...
Jaz pa sem vzel spiralno vzmet v obliki palčke (za razteg) dolgo cca. 20cm premera 1cm in jo pritrdil na ograjico transportnega traku po katerem so šle sveče, tako da se je kot zapornica ukrivila ob prehodu vsake polne sveče. Če je bila kakšna sveča brez voska (prelahka) jo je vzmet odrinila na stran traku kjer ni bilo ograjice ... ... mehaniki pa ...  |
boco Član
Pridružen-a: Čet 31 Jul 2003 9:42 Prispevkov: 919 Aktiv.: 3.87 Kraj: Ptuj/Kranj/Ljubljana
Objavljeno: Pet Jun 15, 2007 12:59 pm Naslov sporočila: |
Iztok, ....jaz bi še manj kompliciral in bi postavil ventilator, ki bi pač prazno plastiko samo odpihnil iz traku .
Boco |
Iztok Član
Objavljeno: Pet Jun 15, 2007 1:20 pm Naslov sporočila: |
boco je napisal/a: |
Boco |
No, ne vem kaj je večja komplikacija in neprijetnost za prisotne delavce?
Da nepotrebnega pihanja, hrupa, porabe el. energije, vlečenja novih kablov, ipd. sploh ne omenjam ...  |
Sergej Član
Pridružen-a: Tor 29 Avg 2006 19:43 Prispevkov: 280 Aktiv.: 1.22
Objavljeno: Pet Jun 15, 2007 1:48 pm Naslov sporočila: |
Moje videnje:
Američani rinejo z glavo skozi zid, dokler zadeva ne deluje.
Nemci dodelajo do popolnosti, da komaj še deluje.
Rusi tako poenostavijo, da včasih ne deluje več.
Obstaja poseben problem pri razvoju po naročilu. Za problem vreden 100 je obstajala enostavna rešitev, ki bi stala 10. Seveda se je dodalo čuda nekih sistemov, da je na koncu vse skupaj za silo izgledalo vredno recimo 70.
Avtor rešitve vsaj približno ve kolikšen prihranek bo nekaj prineslo in če se le da, zaračuna del bodočega dobička. Vsaka firma bi zato morala predvsem sama razvijat svojo tehnologijo. Za primer je lahko Kolektor, ki se je po tem receptu prebil na prvo mesto v svetu. |
Uptime: 4 dni
