Izvajanje funkcije iz RAM-a
AlesH
Pridružen-a: Pon 20 Mar 2006 21:20
Prispevkov: 16
Aktiv.: 0.07
PrispevekObjavljeno: Pet Jun 22, 2007 2:12 pm    Naslov sporočila:  Izvajanje funkcije iz RAM-a Odgovori s citatom
Pozdravljeni
Zanima me, ce ima kdo morda izkusnej z izvajanjem funkcij iz RAM-a. Uporabljam GCC compiler. Poizkusal sem z:
Koda:
void FastSPIRead(void) __attribute__((section(".data")));
Vrjetno je potrebna se kaksna sprememba v strat-up kodi. Startup file je naslednji:
Koda:
/* Startup code. First adderss.                                                       */
                .text
                .arm
                .global _start
                .global main
                .func   _start
_start:
/* Program signature explanation:                                                 */
/* Interrupt vector table is 32 bytes long (eight 32-bit instructions). The sixth */
/* instruction is a 32-bit constant named program signature. It must be a 32-bit  */
/* number such that the eight 32-bit instruction codes from interrupt vector      */
/* table produce zero when they are added together (without carry).               */
/* The signature remains unchanged if the interrupt service routine addresses are */
/* listed in a separate table (interrupt address table).                          */
/* Interrupt vector table */
                   LDR       PC, Reset_Addr
                   LDR       PC, Undefined_Addr
                   LDR       PC, Swi_Addr
                   LDR       PC, Prefetch_Addr
                   LDR       PC, Abort_Addr
                   NOP                          /* Reserved Vector */
#                  LDR       PC, Irq_Addr
                   LDR       PC, [PC,#-0x0FF0]  /* Vector from VicVectorAddr */
                   LDR       PC, Fiq_Addr
/* Interrupt address table */
/* Replace the handler address with C routine name if you want to */
/* use some other function that handles an interrupt.             */
Reset_Addr:        .word     Reset_Handler
Undefined_Addr:    .word     Undefined_Except
Swi_Addr:          .word     Swi_Except
Prefetch_Addr:     .word     Prefetch_Except
Abort_Addr:        .word     Abort_Except
                   .word     0x00000000         /* Reserved four bytes */
Irq_Addr:          .word     Irq_Except
Fiq_Addr:          .word     Fiq_Except
/* Default interrupt service routines.      */
/* Hang the system in case of an interrupt. */
Undefined_Except:  B         Undefined_Except
Swi_Except:        B         Swi_Except
Prefetch_Except:   B         Prefetch_Except
Abort_Except:      B         Abort_Except
Irq_Except:        B         Irq_Except
Fiq_Except:        B         Fiq_Except
/* Reset Handler        */
Reset_Handler:
                   value = 0 ... VPB clock is 1/4 of the processor CCLK clock
                /* VPB Setup */
                LDR     R0, =VPBDIV
                LDR     R1, =VPBDIV_Val
                STR     R1, [R0]        /*Store R1 in R0*/
        /* Setup Stack for each mode */
                LDR     R0, =TOP_Stack
        /* Enter Undefined Instruction Mode and set its Stack Pointer */
                MSR     CPSR_c, #MODE_UND|I_BIT|F_BIT    /* Set UND stack pointer */
                MOV     SP, R0
                SUB     R0, R0, #UND_Stack_Size
        /* Enter Abort Mode and set its Stack Pointer */
                MSR     CPSR_c, #MODE_ABT|I_BIT|F_BIT        /* Set ABT stack pointer */
                MOV     SP, R0
                SUB     R0, R0, #ABT_Stack_Size
        /* Enter FIQ Mode and set its Stack Pointer */
                MSR     CPSR_c, #MODE_FIQ|I_BIT|F_BIT        /* Set FIQ stack pointer */
                MOV     SP, R0
                SUB     R0, R0, #FIQ_Stack_Size
        /* Enter IRQ Mode and set its Stack Pointer */
                MSR     CPSR_c, #MODE_IRQ|I_BIT|F_BIT        /* Set IRQ stack pointer */
                MOV     SP, R0
                SUB     R0, R0, #IRQ_Stack_Size
        /* Enter Supervisor Mode and set its Stack Pointer */
                MSR     CPSR_c, #MODE_SVC|I_BIT|F_BIT        /* Set SVC stack pointer */
                MOV     SP, R0
                SUB     R0, R0, #SVC_Stack_Size
        /* Enter User or system Mode and set its Stack Pointer*/
                MSR     CPSR_c, #MODE_USR                    /* Set SYS stack pointer */
                MOV     SP, R0
        /*Setup a default Stack Limit (SL-R10) (when compiled with "-mapcs-stack-check")*/
                SUB     SL, SP, #USR_Stack_Size
/* Relocate .data section (Copy form ROM to RAM).
                LDR     R1, =_etext
                LDR     R2, =_data
                LDR     R3, =_edata
LoopRel:        CMP     R2, R3
                LDRLO   R0, [R1], #4
                STRLO   R0, [R2], #4
                BLO     LoopRel
/* Clear bss RAM section.                                                             */
                MOV     R0, #0
                LDR     R1, =__bss_start__
                LDR     R2, =__bss_end__
LoopZI:         CMP     R1, R2
                STRLO   R0, [R1], #4
                BLO     LoopZI
/* Enter C main function.                                                             */
                B       main
                .size   _start, . - _start
                .endfunc
                .end
Ce komu kaj podobnega deluje, bi ga prosil da pripne svoj startup. Hvala.
Bp Ales
Hi-End
Pridružen-a: Sre 25 Feb 2004 11:51
Prispevkov: 284
Aktiv.: 1.20
Kraj: Višnja Gora
PrispevekObjavljeno: Pet Jun 22, 2007 2:33 pm    Naslov sporočila:   Odgovori s citatom
Na eni strani sem našel tole:
Run selected Functions in RAM with arm-elf-gcc
This example-application demonstrates how to set-up the compiler and linker to execute selected functions from RAM. Shown in this example:
* Declare functions in RAM (section attribute)
* Declare functions to be called by a "long-call" (long-call attribute)
* Linker-script-entries for the "function-section"
* Startup-code which transfers the function-code from ROM to RAM
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/#gcc_ramfunc
Če ti to kaj koristi. V Keilovem prevajalniku je zadeva zelo enostavna __ram Wink
Bi pa tudi mene zanimalo kako se temu streže, ker na embeddedrelated je že nekdo nekaj spraševal na to temo.
http://www.embeddedrelated.com/groups/lpc2000/show/5031.php in to verjetno tudi že poznaš.
Music is a part of my life, DIY is my life !
alessio
Pridružen-a: Pon 04 Dec 2006 8:39
Prispevkov: 363
Aktiv.: 1.60
PrispevekObjavljeno: Tor Jun 26, 2007 10:03 am    Naslov sporočila:   Odgovori s citatom
V tem članku je opisano na kratko tudi izvajanje funkcij iz RAM-a, na koncu so linki na primere.
Aleš
Uptime: 5 dni
