Picbasic pro - pomoč
YZY
Pridružen-a: Sre 02 Apr 2008 21:28
Prispevkov: 9
Aktiv.: 0.04
Kraj: Tolmin
PrispevekObjavljeno: Čet Apr 03, 2008 7:41 am    Naslov sporočila:  Picbasic pro - pomoč Odgovori s citatom
Ali mi lahko kdo pomaga predelat ta program za sledeči priklop LCDja?
' Prikljucitev LCD prikazovalnika:
' DB4 PortB.4 'Data'
' DB5 PortB.5 'Data'
' DB6 PortB.6 'Data'
' DB7 PortB.7 'Data'
' RS PortB.2 'Izbira podatek/ukaz'
' E PortB.3 'Dodaj 1.2k pull UP upor Enable'
' RW Ground 'Upor 1.2k pull DOWN'
' Vdd +5 volts 'Napajanje +5V DC'
' Vss GND 'Masa GND'
' Vo 20K trimer 'Osvetljitev glej manual'
' DB0-3 No connect 'Proste'
Tale program bi predelal:
' Program NO_CURS.BAS
' Disable the flashing cursor on the LCD
Device 16F84 ' We are using a PIC16F84
' ** Load the LCD Routines **
Include LCD
Init LCD,PortB ' Place the LCD on PortB
Symbol EN=B.3 ' Assign the LCD's RS line
Symbol RS=B.2 ' Assign the LCD's EN line
' *************** THE PROGRAM STARTS HERE****************
Define PortB %00000000 ' PortB all Outputs
Define PortA %00000000
Cls ' Clear the Display
Gosub Coff ' Disable the cursor
Cursor 1,2 ' Place TEXT on second line
Print "HELLO WORLD" ' Do the displaying
PortA=%11111111
Inf: Goto Inf ' Infinite loop
' ** Turn off the flashing cursor **
Coff: PortB=0 ' Place the first 4-bits on PortB
High EN ' Strobe the EN line High - Low
Clrwdt
Low EN
PortB=%11000000 ' Place the next 4-bits on PortB 11000000
Clrwdt
Low EN
Delayus (16) ' Pause for 40us with 4mHz OSC
High RS ' Back into character mode
Return ' Exit the subroutine
End ' Mandatory END statement
