Velikost spremenljivk
marko11
Prispevkov: 893
Aktiv.: 3.77
Kraj: Dobrepolje
PrispevekObjavljeno: Čet Jan 06, 2005 6:32 pm    Naslov sporočila:  Velikost spremenljivk Odgovori s citatom
Koliksne so preostale spremenljivke - Bascom
Dim B1 As Bit ' 0 ali 1
Dim A As Byte ' 0-255
Dim C As Integer ' -32767 - +32768
Dim B As Word
Dim L As Long
Dim S As Single
LP,marko
Če ne veš kam greš, se ne moreš zgubiti.
G-Lab
Pridružen-a: Sob 12 Jul 2003 9:44
Prispevkov: 179
Aktiv.: 0.76
Kraj: Jesenice
PrispevekObjavljeno: Čet Jan 06, 2005 10:59 pm    Naslov sporočila:   Odgovori s citatom
Še string ti ostane.
Uporabi Help pa napiši: Language Fundamentals
tam notri imaš lepo razloženo.
strobos
Pridružen-a: Sre 24 Sep 2003 12:19
Prispevkov: 726
Aktiv.: 3.06
Kraj: Brežice
PrispevekObjavljeno: Čet Jan 06, 2005 11:50 pm    Naslov sporočila:   Odgovori s citatom
Elementary Data Types
· Bit (1/8 byte). A bit can hold only the value 0 or 1.
A group of 8 bits is called a byte.
· Byte (1 byte).
Bytes are stores as unsigned 8-bit binary numbers ranging in value from 0 to 255.
· Integer (two bytes).
Integers are stored as signed sixteen-bit binary numbers ranging in value from -32,768 to +32,767.
· Word (two bytes).
Words are stored as unsigned sixteen-bit binary numbers ranging in value from 0 to 65535.
· Long (four bytes).
Longs are stored as signed 32-bit binary numbers ranging in value from -2147483648 to 2147483647.
· Single.
Singles are stored as signed 32 bit binary numbers. Ranging in value from
1.5 x 10^–45 to 3.4 x 10^38
· String (up to 254 bytes).
Strings are stored as bytes and are terminated with a 0-byte.
A string dimensioned with a length of 10 bytes will occupy 11 bytes.
