uIP: napaka pri kompajliranju
rudiP
Pridružen-a: Tor 07 Avg 2007 15:30
Prispevkov: 1234
Aktiv.: 5.67
Kraj: KOPER
PrispevekObjavljeno: Pon Okt 27, 2008 9:28 pm    Naslov sporočila: icon_question uIP: napaka pri kompajliranju Odgovori s citatom
kompajler WinAVR mi pokaže napako " undefined reference to `uip_conn' ". Reference ne znam razvozlati, zato prosim člane foruma, če mi lahko pomagajo pri rešitvi problema. Hvala.
Koda:
   * The uip_conn structure has a field called "appstate" that holds
   * the application state of the connection. We make a pointer to
   * this to access it easier.
 -> struct hello_world_state *s = &(uip_conn->appstate); // napaka: undefined reference to `uip_conn'
 * Representation of a uIP TCP connection.
 * The uip_conn structure is used for identifying a connection. All
 * but one field in the structure are to be considered read-only by an
 * application. The only exception is the appstate field whos purpose
 * is to let the application store application-specific state (e.g.,
 * file pointers) for the connection. The size of this field is
 * configured in the "uipopt.h" header file.
struct uip_conn {
  u16_t ripaddr[2];   /**< The IP address of the remote host. */
    u16_t lport;        /**< The local TCP port, in network byte order. */
  u16_t rport;        /**< The local remote TCP port, in network byte order. */
  u8_t rcv_nxt[4];    /**< The sequence number that we expect to receive next. */
  u8_t snd_nxt[4];    /**< The sequence number that was last sent by  us. */
  u16_t len;          /**< Length of the data that was previously sent. */
  u16_t mss;          /**< Current maximum segment size for the connection. */
  u16_t initialmss;   /**< Initial maximum segment size for the connection. */
  u8_t sa;            /**< Retransmission time-out calculation state variable. */
  u8_t sv;            /**< Retransmission time-out calculation state variable. */
  u8_t rto;           /**< Retransmission time-out. */
  u8_t tcpstateflags; /**< TCP state and flags. */
  u8_t timer;         /**< The retransmission timer. */
  u8_t nrtx;          /**< The number of retransmissions for the last segment sent.*/
  /** The application state. */
  u8_t appstate[UIP_APPSTATE_SIZE];
Lep pozdrav iz Kopra Rudi
Umnik
Prispevkov: 958
Aktiv.: 4.04
Kraj: Novo mesto
PrispevekObjavljeno: Pon Okt 27, 2008 10:01 pm    Naslov sporočila:   Odgovori s citatom
Tukaj recimo je najverjetneje problem sama uporaba strukture. Moralo bi biti nekaj takega:
Koda:
struct hello_world_state *s =(struct hello_world_state *)&(uip_conn->appstate);
vendar moraš vedeti, kaj boš s strukturo hello_world_state sploh počel.
Lahko je to struktura uporabljena za smtp, telnet morda http server, ali pa kaj podobnega, za začetek (da se compiler neha pritoževat) je zadosti že, če obstaja:
Koda:
struct hello_world_state { u8_t karkoli; };
chaos
Pridružen-a: Sob 16 Sep 2006 22:12
Prispevkov: 1063
Aktiv.: 4.66
Kraj: Zagorje ob Savi
PrispevekObjavljeno: Tor Okt 28, 2008 6:35 am    Naslov sporočila:   Odgovori s citatom
Verjetno bo pomagalo, če prestaviš definicijo strukture višje v kodi, kot vrstica, kjer jo uporabiš in ti javi napako.
LP!
