crt0.S
trot
Prispevkov: 1282
Aktiv.: 5.71
Kraj: glej fogl
PrispevekObjavljeno: Tor Mar 13, 2007 2:13 pm    Naslov sporočila:  crt0.S Odgovori s citatom
Kakšno funkcijo ima crt0.S? O asamblerju nimam pujma, zato tudi ne vem kaj dela. Kdaj se sploh kliče ta koda?
Primer:
crt0.S for LPC2xxx
- based on examples from R O Software
- based on examples from newlib-lpc
- based on an example from Anglia Designs
collected and modified by Martin Thomas
.global _etext // -> .data initial values in ROM
.global _data // -> .data area in RAM
.global _edata // end of .data area
.global __bss_start // -> .bss area in RAM
.global __bss_end__ // end of .bss area
.global _stack // top of stack
// Stack Sizes
.set UND_STACK_SIZE, 0x00000004
.set ABT_STACK_SIZE, 0x00000004
.set FIQ_STACK_SIZE, 0x00000004
.set IRQ_STACK_SIZE, 0X00000080
.set SVC_STACK_SIZE, 0x00000004
// Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs
.set MODE_USR, 0x10 // User Mode
.set MODE_FIQ, 0x11 // FIQ Mode
.set MODE_IRQ, 0x12 // IRQ Mode
.set MODE_SVC, 0x13 // Supervisor Mode
.set MODE_ABT, 0x17 // Abort Mode
.set MODE_UND, 0x1B // Undefined Mode
.set MODE_SYS, 0x1F // System Mode
.equ I_BIT, 0x80 // when I bit is set, IRQ is disabled
.equ F_BIT, 0x40 // when F bit is set, FIQ is disabled
.text
.arm
.section .init, "ax"
.code 32
.align 2
.global _boot
.func _boot
_boot:
// Runtime Interrupt Vectors
Vectors:
b _start // reset - _start
ldr pc,_undf // undefined - _undf
ldr pc,_swi // SWI - _swi
ldr pc,_pabt // program abort - _pabt
ldr pc,_dabt // data abort - _dabt
nop // reserved
ldr pc,[pc,#-0xFF0] // IRQ - read the VIC
ldr pc,_fiq // FIQ - _fiq
#if 0
// Use this group for production
_undf: .word _reset // undefined - _reset
_swi: .word _reset // SWI - _reset
_pabt: .word _reset // program abort - _reset
_dabt: .word _reset // data abort - _reset
_irq: .word _reset // IRQ - _reset
_fiq: .word _reset // FIQ - _reset
#else
// Use this group for development
_undf: .word __undf // undefined
_swi: .word __swi // SWI
_pabt: .word __pabt // program abort
_dabt: .word __dabt // data abort
_irq: .word __irq // IRQ
_fiq: .word __fiq // FIQ
__undf: b . // undefined
__swi: b . // SWI
__pabt: b . // program abort
__dabt: b . // data abort
__irq: b . // IRQ
__fiq: b . // FIQ
#endif
.size _boot, . - _boot
.endfunc
// Setup the operating mode & stack.
.global _start, start, _mainCRTStartup
.func _start
_start:
start:
_mainCRTStartup:
// Initialize Interrupt System
// - Set stack location for each mode
// - Leave in System Mode with Interrupts Disabled
ldr r0,=_stack
msr CPSR_c,#MODE_UND|I_BIT|F_BIT // Undefined Instruction Mode
mov sp,r0
sub r0,r0,#UND_STACK_SIZE
msr CPSR_c,#MODE_ABT|I_BIT|F_BIT // Abort Mode
mov sp,r0
sub r0,r0,#ABT_STACK_SIZE
msr CPSR_c,#MODE_FIQ|I_BIT|F_BIT // FIQ Mode
mov sp,r0
sub r0,r0,#FIQ_STACK_SIZE
msr CPSR_c,#MODE_IRQ|I_BIT|F_BIT // IRQ Mode
mov sp,r0
sub r0,r0,#IRQ_STACK_SIZE
msr CPSR_c,#MODE_SVC|I_BIT|F_BIT // Supervisor Mode
mov sp,r0
sub r0,r0,#SVC_STACK_SIZE
msr CPSR_c,#MODE_SYS|I_BIT|F_BIT // System Mode
mov sp,r0
// Copy initialized data to its execution address in RAM
#ifdef ROM_RUN
ldr r1,=_etext // -> ROM data start
ldr r2,=_data // -> data start
ldr r3,=_edata // -> end of data
1: cmp r2,r3 // check if data to move
ldrlo r0,[r1],#4 // copy it
strlo r0,[r2],#4
blo 1b // loop until done
#endif
// Clear .bss
mov r0,#0 // get a zero
ldr r1,=__bss_start // -> bss start
ldr r2,=__bss_end__ // -> bss end
2: cmp r1,r2 // check if data to clear
strlo r0,[r1],#4 // clear 4 bytes
blo 2b // loop until done
Call C++ constructors (for objects in "global scope")
ctor loop added by Martin Thomas 4/2005
based on a Anglia Design example-application for ST ARM
LDR r0, =__ctors_start__
LDR r1, =__ctors_end__
ctor_loop:
CMP r0, r1
BEQ ctor_end
LDR r2, [r0], #4
STMFD sp!, {r0-r1}
MOV lr, pc
MOV pc, r2
LDMFD sp!, {r0-r1}
B ctor_loop
ctor_end:
// Call main program: main(0)
mov r0,#0 // no arguments (argc = 0)
mov r1,r0
mov r2,r0
mov fp,r0 // null frame pointer
mov r7,r0 // null frame pointer for thumb
ldr r10,=main
mov lr,pc
/* Enter the C code, use BX instruction so as to never return */
/* use BLX (?) main if you want to use c++ destructors below */
bx r10 // enter main()
/* "global object"-dtors are never called and it should not be
needed since there is no OS to exit to. */
/* Call destructors */
# LDR r0, =__dtors_start__
# LDR r1, =__dtors_end__
dtor_loop:
# CMP r0, r1
# BEQ dtor_end
# LDR r2, [r0], #4
# STMFD sp!, {r0-r1}
# MOV lr, pc
# MOV pc, r2
# LDMFD sp!, {r0-r1}
# B dtor_loop
dtor_end:
.size _start, . - _start
.endfunc
.global _reset, reset, exit, abort
.func _reset
_reset:
reset:
exit:
abort:
#if 0
// Disable interrupts, then force a hardware reset by driving P23 low
mrs r0,cpsr // get PSR
orr r0,r0,#I_BIT|F_BIT // disable IRQ and FIQ
msr cpsr,r0 // set up status register
ldr r1,=(PS_BASE) // PS Base Address
ldr r0,=(PS_PIO) // PIO Module
str r0,[r1,#PS_PCER_OFF] // enable its clock
ldr r1,=(PIO_BASE) // PIO Base Address
ldr r0,=(1<<23) // P23
str r0,[r1,#PIO_PER_OFF] // make sure pin is contolled by PIO
str r0,[r1,#PIO_CODR_OFF] // set the pin low
str r0,[r1,#PIO_OER_OFF] // make it an output
#endif
b . // loop until reset
.size _reset, . - _reset
.endfunc
.end
Glitch
Pridružen-a: Pet 07 Apr 2006 11:40
Prispevkov: 1477
Aktiv.: 6.30
PrispevekObjavljeno: Tor Mar 13, 2007 2:30 pm    Naslov sporočila:   Odgovori s citatom
v crt0 (ali pa kaksno drugo ime) so init rutine, irq vektorji, definicija stacka in podobno. Skratka, tu notri je koda, ki se izvede takoj na zacetku, se preden se zacne izvajati kaksna C koda oz. main. Tu lahko definiras tudi kaj se zgodi ob izhodu iz funkcije main.
Sam imam narejeno tako, da je res minimum notri. Ostalo pa v normalni C kodi.
trot
Prispevkov: 1282
Aktiv.: 5.71
Kraj: glej fogl
PrispevekObjavljeno: Tor Mar 13, 2007 3:24 pm    Naslov sporočila:   Odgovori s citatom
Ampak v main.c sploh ne najdem nobenega ukaza, kjer bi klical crt0.S
A ta crt0.S je enak za vse LPC-je, a moram kaj spreminjat, če bom zamenjal čip?
Glitch
Prispevkov: 1477
Aktiv.: 6.30
PrispevekObjavljeno: Tor Mar 13, 2007 3:49 pm    Naslov sporočila:   Odgovori s citatom
Ne mores klicat datoteke. Lahko bi klical kaksno funkcijo, ko jo definiras v crt0, ponavadi so to handlerji za prekinitve.
Linker je tisti (oz. linker skripta), ki ima kaj opraviti s to datoteko in njeno vsebino.
Tudi to datoteko moras malce spreminjat, ce zelis kaksen drug cip uporabit. Ampak spet odvisno kako je napisana. Podal si primer, ki na dolocenih LPCjih ne dela, za kaksne druge ARMe pa se manj. Celo rutina za exit je napisana, ki krmili IO pin.
alessio
Pridružen-a: Pon 04 Dec 2006 8:39
Prispevkov: 363
Aktiv.: 1.60
PrispevekObjavljeno: Tor Mar 13, 2007 3:51 pm    Naslov sporočila:   Odgovori s citatom
crt.s ima poleg tega kar pravi Glitch, še pomembno funkcijo, da inicializira
vrednost spremenljivk v tvojem programu, inicializirane (.data section) in neinicializirane (.bss section). Od tod tudi ime : CRT= C RunTime
trot je napisal/a:
Ne, ker crto.S kliče main funkcijo.
trot je napisal/a:
V osnovi ni enak za vsak program in za vse LPC-je, je pa tale crto.S, ki si
ga pripel dokaj generičen (verjetno povzeto od Martina Thomasa, kaj ne? Wink ).
Aleš
BluPhenix
Pridružen-a: Pet 05 Mar 2004 12:54
Prispevkov: 1018
Aktiv.: 4.29
Kraj: Sežana
PrispevekObjavljeno: Tor Mar 13, 2007 8:05 pm    Naslov sporočila:   Odgovori s citatom
V tem dokumentu imaš precej takih stvari razloženih.
.:alex:.
Pridružen-a: Sre 05 Mar 2008 11:51
Prispevkov: 24
Aktiv.: 0.11
Kraj: Domžale-Kamnik
PrispevekObjavljeno: Tor Dec 02, 2008 2:14 pm    Naslov sporočila:   Odgovori s citatom
Bom ker v tole temo napisal!In sicer potrebujem startup codo za lpc2366 ker kar sam spišem ne dela !Tako da če kdo ima bi prosil zanjo Smile
Uptime: 6 dni
