P: PC104 plata
mazdaš
Pridružen-a: Tor 01 Dec 2009 17:19
Prispevkov: 1
Aktiv.: 0.01
Kraj: Dolenjska
PrispevekObjavljeno: Tor Dec 01, 2009 6:05 pm    Naslov sporočila:  P: PC104 plata Odgovori s citatom
Prodam zgoraj omenjeni SingleBoardComputer modul z naslednjimi lastnostmi:
CPU: Embedded SiS 552 x86 MMX compatible
CPU System Memory: On board 64MB PC133 SDRAM
Display: SiS552 embedded with Hardware 2D/Video/Graphics Accelerators
– AGP 4X Compliant / Fully DirectX 8 Compliant
– Supports Shared System Memory up to 128 MB
– Resolution supports up to 1920 x1440 true colors
– 18-bit TTL for LCD display
SSD: 1 x DiskOnChip socket
Audio: AC’97 CODEC
Ethernet: 1 x 10/100Mbps RTL8100BL LAN controllers
I/O:
– 1 x RS-232 serial port
– 1 x RS/232/422/485 serial ports
– 1 x PS/2 connector for Keyboard/Mouse
– 1 x LPT parallel port supports SPP/ECP/EPP Mode
– 2 x USB 1.1
– 2 x IDE ATA-100
– 1 x Floppy
WDT: Software programmable supports 1 ~ 255 sec system reset
Digital I/O: TTL Level, 4 x inputs & 4 x outputs
Power Source: Single +5V only
Operation Temperature: 0~60ºC
Relative Humidity: 5~95%, non-condensing
Slike podobnega na: http://www.orbitmicro.com/global/pm-1045-p-851.html
Če komu pride v poštev se za ceno dogovorimo.
P.S.: Se oproščam, ker je oglas moj prvi post drugače pa že dolgo prebiram ta forum in se najde kar veliko zamivih stvari.
Pyr0Beast
Prispevkov: 4969
Aktiv.: 23.97
PrispevekObjavljeno: Tor Dec 01, 2009 6:35 pm    Naslov sporočila:   Odgovori s citatom
Živjo,
Glede na to da ima priklop za LCD, podpira zadeva LVDS ?
Uptime: 503 dni
