IRC kanal #elektronik.si
Glitch
Pridružen-a: Pet 07 Apr 2006 11:40
Prispevkov: 1477
Aktiv.: 6.30
PrispevekObjavljeno: Tor Jun 02, 2009 7:41 am    Naslov sporočila:   Odgovori s citatom
"Takrat" me ni preprical, mogoce tudi zato, ker mi niso delale skripte, ki sem jih mel za kontrolo kanalov oz. botov.
Answers: $1, Short: $5, Correct: $25, dumb looks are still free.
Aktiv.: 39.60
PrispevekObjavljeno: Tor Sep 15, 2009 1:21 am    Naslov sporočila:   Odgovori s citatom
Evo še par naslovov Ircnet serverjev...
http://www.ircnet.com/index.php?&p=5
Aktiv.: 59.90
PrispevekObjavljeno: Sre Okt 07, 2009 11:19 pm    Naslov sporočila:   Odgovori s citatom
Kaj vse se da videti na IRC kanalu elektronik.si:
Koda:
(23:09:00) (@VolkD) A good delphi programmer is JernejL
(23:09:11) (@VolkD) JernejL !
(23:09:12) (@VolkD) JernejL !
(23:09:13) (@VolkD) JernejL !
(23:09:25) (@VolkD) A question for you !!
(23:09:42) (+JernejL) i'm listening :D
(23:09:48) (+sphere) this is a Time problem , i know it is something silly but dont know what
(23:10:35) (+sphere) using TFrames in Delphi. I'm placing a few copies of the same Frame on a Form. The frames contain a display, formed by a TPanel, of which the value could be set using a TUpDown next to it.
(23:11:05) (+sphere) After displaying this form, both UpDowns in each Frame works fine. Their values are shown on the displays, the value of the UpDown in one frame hasn't any influence on the one in the other frame. So far so good, this is as I expected.
(23:11:35) (+sphere) The frames do own a TTimer component, defined in the TFrame Unit. The Timer1 procedure is supposed to count down, and refresh the value on the display. And here is the problem that occurs: both displays show the same counted-down times. Obviously, the Timer procedures don't act independantly, although they're defined as private in the TFrame
(23:12:01) (+sphere) Both frames on the Form are descendants of the same frame Class. At the moment, the only solution I see is to place the timer with it's procedure in the form that contains the frames, but by doing that I would loose much of the advantages of using frames in the first place. So I wouldn't like that..
(23:12:06) (+sphere) any ideas
(23:12:46) (+JernejL) you will have to write a custom component, there's no other way around this
(23:13:06) (+JernejL) because the frames themselves aren't exactly a copy of the elements.. but somewhat a mirror
(23:13:27) (+JernejL) and i never got this working quite correct
(23:13:32) (+sphere) they start off at differant times but then all become the same
(23:13:38) (+JernejL) frames are best avoided..
(23:14:27) (+sphere) so how best to work on the component
(23:15:47) (+JernejL) there's tutorials
(23:15:55) (+JernejL) there may be something like it already created
(23:16:07) (+sphere) best place to look
(23:18:54) (+sphere) thank you so much for the help, it saves me another 3 days trying to work out what i did wrong :)
(23:18:59) (+JernejL) torry.ru
(23:19:44) (+sphere) will have a look there thanx again
Aktiv.: 39.60
PrispevekObjavljeno: Sre Feb 10, 2010 10:54 pm    Naslov sporočila:   Odgovori s citatom
update!
Kanal #elektronik.si je preseljen na nov server: IRC.SIOFF.NET.
+ Domač server, brez spama in zunanjih padalcev.
+ Brez splitanja in nedosegljivih serverjev.
- Dostop preko web bo malo bolj težaven (treba vpisat eno polje več).
web dostop:
http://www.mibbit.com/chat/
In ne pozabite kliknit na Charset in nastavit na "UTF-8" (sicer naj bi bila to že privzeta nastavitev).
Aktiv.: 32.97
PrispevekObjavljeno: Pet Feb 12, 2010 9:03 pm    Naslov sporočila:   Odgovori s citatom
Pojma nimam za kaj gre! Bi lahko kdo malo razsvetlil pojme enemu staremu sitnemi dedcu? Nismo vsi otroci interneta.
Še najpametnejša stvar je klepetalnik na forumu
mirkatmir
Prispevkov: 1876
Aktiv.: 7.90
Kraj: Ribnica (JN75IR)
PrispevekObjavljeno: Pet Feb 12, 2010 9:33 pm    Naslov sporočila:   Odgovori s citatom
Branez je napisal/a:
Whistle
lp, Miran (Miro - S51SK)
Aktiv.: 32.97
PrispevekObjavljeno: Pet Feb 12, 2010 9:36 pm    Naslov sporočila:   Odgovori s citatom
Sem vsaj odkritosrčen. Moram pa napisati še vztrajnem. Našel sem!!!!!!
RUros
Prispevkov: 1031
Aktiv.: 4.38
PrispevekObjavljeno: Pet Feb 12, 2010 11:40 pm    Naslov sporočila:   Odgovori s citatom
Ki se pa ne uporablja, zakaj Question
Aktiv.: 32.97
PrispevekObjavljeno: Pet Feb 12, 2010 11:41 pm    Naslov sporočila:   Odgovori s citatom
Ker nihče ne pogleda tja! Še vidva sta zginila za par sekund. Confused
RUros
Prispevkov: 1031
Aktiv.: 4.38
PrispevekObjavljeno: Pet Feb 12, 2010 11:48 pm    Naslov sporočila:   Odgovori s citatom
Pogledam večkrat, pa sem ponavadi sam tam, in potem debata nekako ne steče Smile
Sibica
Prispevkov: 1097
Aktiv.: 5.57
Kraj: Vremska Dolina
PrispevekObjavljeno: Tor Jan 25, 2011 10:22 pm    Naslov sporočila:   Odgovori s citatom
Hmm...trudim se priti na IRC a mi nikakor ne uspe. DOstopam z Mibbit-om.
Problem je ker irc.sioff.net nikjer ne najdem. Kako to? Idea Question
Aktiv.: 39.60
PrispevekObjavljeno: Tor Jan 25, 2011 10:53 pm    Naslov sporočila:   Odgovori s citatom
kanal: #elektronik.si
pa bo šlo.
Prispevkov: 14677
Aktiv.: 61.79
PrispevekObjavljeno: Tor Jan 25, 2011 11:08 pm    Naslov sporočila:   Odgovori s citatom
Port port 6697
sars
Pridružen-a: Tor 05 Jan 2010 20:40
Prispevkov: 671
Aktiv.: 3.56
Kraj: Vransko
PrispevekObjavljeno: Tor Maj 03, 2011 10:55 pm    Naslov sporočila:   Odgovori s citatom
... urejeno
Ko misliš, da nimaš sreče v življenju, pomisli na voznike Renaultov. Very Happy
Prispevkov: 14677
Aktiv.: 61.79
PrispevekObjavljeno: Sob Mar 24, 2012 12:39 am    Naslov sporočila:   Odgovori s citatom
Glede na to, da je trenutno kar živahno na forumskem klepetu - sem dvignil tole staro temo na plan. Za tiste, ki ne veste-že dolgo časa obratuje tudi irc kanal elektronik.si
Stran 2 od 3
Uptime: 8 dni
