Pridružen-a: Pon 23 Avg 2004 16:16 Prispevkov: 16777190 Aktiv.: 70613.58
Objavljeno: Čet Mar 04, 2010 11:56 pm Naslov sporočila: Kako scentrirati kotvo v tuljavi zvočnika? |
ro-bi Član
Pridružen-a: Ned 28 Jan 2007 16:53 Prispevkov: 3580 Aktiv.: 15.95
Objavljeno: Pet Mar 05, 2010 1:34 am Naslov sporočila: |
Kolikor vem, to centrirajo zz vlaganjem distance v režo, dokler se lepilo ne posuši (ko lepijo membrano gor).
Probaj na roko, da bo čimveč lufta, kapni zadaj sekundno in potem bolje fiksiraj, ko bo štimalo?
R _________________ 3 x 3 = 9 |
Pyr0Beast Član
Pridružen-a: Pon 16 Jun 2008 14:11 Prispevkov: 4969 Aktiv.: 23.93
Objavljeno: Pet Mar 05, 2010 3:43 am Naslov sporočila: |
Zadevo furaš z zelo šibkim virom zvoka in nato obračaš magnet dokler ne neha prasketati. Tako sem sam rešil enega, ki je imel magnet privijačen. Rahlo sem odvil vijake, ter nato vrtel magnet dokler ni od sebe dal zvočnik lepega glasu. Toleranca je pa ranga milimetra, verjetno še manj in je muka zadevo pravilno pozicionirati. |
lucca brassi Član
Pridružen-a: Ned 01 Feb 2004 12:46 Prispevkov: 4227 Aktiv.: 17.79 Kraj: KOČEVJE
Objavljeno: Pet Mar 05, 2010 10:24 am Naslov sporočila: |
Kolikor vem se za to kapne v režo neko ferofluidno tekočino , vžge magnetno polje da se scentrira SAM in potem fiksira ( ne vem točnega zaporedja )
http://en.wikipedia.org/wiki/Tweeter
Ferrofluid
Ferrofluid is a suspension of very small (typically 10 nm) iron oxide magnetic particles in a very low volatility liquid, typically a synthetic oil. A wide range of viscosity and magnetic density variants allow designers to add damping, cooling, or both. Ferrofluid also aids in centering the voice coil in the magnetic gap, reducing distortion. The fluid is typically injected into the magnetic gap and is held in place by the strong magnetic field. If a tweeter has been subjected to elevated power levels, some thickening of the ferrofluid occurs, as a portion of the carrier liquid evaporates. In extreme cases, this can degrade the sound quality and output level of a tweeter, and the fluid must be removed and new fluid installed.
Hkrati pa tudi hladi tuljavo med obratovanjem
http://www.ferrotec.com/products/ferrofluid/audio/
Mare ti ko rad kuhaš doma )
http://www.popsci.com/diy/article/2009-09/making-ferrofluids-work-you _________________ Moments before detonation ,....... TT |
nakamichi Član
Pridružen-a: Pon 21 Avg 2006 18:51 Prispevkov: 845 Aktiv.: 3.68 Kraj: Nova Gorica
Objavljeno: Pet Mar 05, 2010 10:38 am Naslov sporočila: |
Ferrofluid se uporablja samo za visokotonske enote, ker so hodi majhni. Pri miadbassih to nima kaj iskat. Za centriranje pa kot so rekli, surova moč. Magnet se najbrž kar fino drži svoje pozicije, lepo z občutkom in silo ga probaj premaknit na mesto in tam nekako fiksiraj.
L.P.,
Miha |
Highlag Član
Objavljeno: Pet Mar 05, 2010 11:04 am Naslov sporočila: |
Na how its made so pokazali da to lepo sestavijo, ko magnet še ni magneten. Potem ko je zadeva sestavljena vtaknejo sestav v eno mašino, ki magnet namagneti. Pa je pozicioniranje enostavno, ker magnet ne otežuje sestavljanja.
Sam bi verjetno postružil en obroč iz kakšnega nemagnetnega materiala, ki bi bil v obliki zagozde. Potem bi ta obroč nataknil na magnet in stisnil. Zagozda bi morala magnet potisnit na sredino. _________________ If at first you don't succeed, destroy all evidence that you tried. |
lucca brassi Član
Objavljeno: Pet Mar 05, 2010 11:52 am Naslov sporočila: |
Pa se mi zdi da sem ravno tu v ''kako deluje'' videl to tekočino , če se ne motim so pa delali tam eden 30-40 cm bas  _________________ Moments before detonation ,....... TT |
Objavljeno: Pet Mar 05, 2010 2:14 pm Naslov sporočila: |
milan62 Član
Pridružen-a: Ned 04 Jan 2004 23:19 Prispevkov: 2391 Aktiv.: 10.06 Kraj: Kranj
Objavljeno: Pet Mar 05, 2010 2:40 pm Naslov sporočila: |
lucca brassi je napisal/a: |
Pa se mi zdi da sem ravno tu v ''kako deluje'' videl to tekočino , če se ne motim so pa delali tam eden 30-40 cm bas  |
V opisu mojih ca. 20 let starih Dynaudio bas zvočnikov piše, da imajo v reži ferofluid
Krampus Član
Pridružen-a: Pon 08 Sep 2008 13:07 Prispevkov: 1853 Aktiv.: 9.04
Objavljeno: Pet Mar 05, 2010 4:36 pm Naslov sporočila: |
20-25 let nazaj je bilo v SAM-u opisano, kako popravljati in izboljšati bas zvočnike s ferofluidom, ki se je takrat res dobil samo pri Dynaudio
Je pa šlo tako: Odlepiš membrano, namažeš to olje na tuljavo, vstaviš membrano, pustiš nekaj minut in fiksiraš membrano. _________________ Nisem ravno najbolj pameten na svetu, tu in tam pa imam kakšno idejo. |
ro-bi Član
Objavljeno: Pet Mar 05, 2010 8:35 pm Naslov sporočila: |
Feofluid se še iz visokotoncev odstanjuje, če hočeš, da dobro igrajo.
S časom se mast obesi na spodnji del in ovira gibanje.
Da bi dal ferofluid v bas? Po mojem bi tisto imelo enakomeren vpliv zelo kratek čas, bas bi bil pa bolj visokotonec, ker tisto je mast in bi ovirala gibanje.
lp _________________ 3 x 3 = 9 |
Krampus Član
Objavljeno: Pet Mar 05, 2010 10:52 pm Naslov sporočila: |
Saj ne pravim, da bi moral tako narediti, je pa zadeva iz časov, ko je bila zica tuljav v Dynaudio bas zvočnikih šestkotna, ne okrogla. _________________ Nisem ravno najbolj pameten na svetu, tu in tam pa imam kakšno idejo. |
nakamichi Član
Objavljeno: Sob Mar 06, 2010 10:04 pm Naslov sporočila: |
Saj 6 kotna je boljša kot oglata. Danes imajo boljše enote pravokotno žico(valjanec), da je popolni izkoristek protora in homogeno navitje.
L.P.,
Miha |
Uptime: 10 dni
