kle-man Član
Pridružen-a: Tor 21 Okt 2008 17:31 Prispevkov: 14 Aktiv.: 0.07 Kraj: Ilirska Bistrica
Objavljeno: Čet Apr 08, 2010 8:57 pm Naslov sporočila: HID tipkovnica P18F4550 |
Izdelujem tipkovnico za PC ki naj bi delovala prek HID terminala. Imam pic 18F4550.
Za prototip sem si vzel sample program od easyPic5 imenovan HID Write test. Spremenil sem tudi file "USBdsc.c" tako, da mi ga PC zazna kakor tipkovnico. Za to
sem uporabil HID Descriptor Tool, ki sem ga našel na spletni strani www.usb.org . Deskriptor sedaj zgleda takole:
Koda: |
// HID_Report Descriptor
0x05, 0,
0x01, 0, // USAGE_PAGE (Generic Desktop)
0x09, 0,
0x06, 0, // USAGE (Keyboard)
0xa1, 0,
0x01, 0, // COLLECTION (Application)
0x05, 0,
0x07, 0, // USAGE_PAGE (Keyboard)
0x19, 0,
0xe0, 0, // USAGE_MINIMUM (Keyboard LeftControl)
0x29, 0,
0xe7, 0, // USAGE_MAXIMUM (Keyboard Right GUI)
0x15, 0,
0x00, 0, // LOGICAL_MINIMUM (0)
0x25, 0,
0x01, 0, // LOGICAL_MAXIMUM (1)
0x75, 0,
0x01, 0, // REPORT_SIZE (1)
0x95, 0,
0x08, 0, // REPORT_COUNT (8)
0x81, 0,
0x02, 0, // INPUT (Data,Var,Abs)
0x95, 0,
0x01, 0, // REPORT_COUNT (1)
0x75, 0,
0x08, 0, // REPORT_SIZE (8)
0x81, 0,
0x03, 0, // INPUT (Cnst,Var,Abs)
0x95, 0,
0x05, 0, // REPORT_COUNT (5)
0x75, 0,
0x05, 0,
0x08, 0, // USAGE_PAGE (LEDs)
0x19, 0,
0x01, 0, // USAGE_MINIMUM (Num Lock)
0x29, 0,
0x05, 0, // USAGE_MAXIMUM (Kana)
0x91, 0,
0x02, 0, // OUTPUT (Data,Var,Abs)
0x95, 0,
0x75, 0,
0x03, 0, // REPORT_SIZE (3)
0x91, 0,
0x03, 0, // OUTPUT (Cnst,Var,Abs)
0x95, 0,
0x06, 0, // REPORT_COUNT (6)
0x75, 0,
0x15, 0,
0x25, 0,
0x65, 0, // LOGICAL_MAXIMUM (101)
0x05, 0,
0x19, 0,
0x00, 0, // USAGE_MINIMUM (Reserved (no event indicated))
0x29, 0,
0x65, 0, // USAGE_MAXIMUM (Keyboard Application)
0x81, 0,
0x00, 0, // INPUT (Data,Ary,Abs)
0xc0, 0
Skratka, PC mi PIC zazna kakor HID Keyboard.
Sedaj se mi je pa zalomilo pri pošiljanju podatkov na PC. Na usb.org sem si ogledal tabele, kako naj bi ti paketki ki jih pošiljam v PC zgledali. Tabela zgleda takole:
Koda: |
The following table represents the keyboard input report (8 bytes).
Byte Description
0 Modifier keys //to je za ctrl, alt, shift...
1 Reserved
2 Keycode 1 //to je za eno tipko
3 Keycode 2
4 Keycode 3
5 Keycode 4
6 Keycode 5
7 Keycode 6
Našel sem še tabelo, kjer se nahajajo "kode" za posamezno črko:
Koda: |
Usage ID(Dec) Usage ID(Hex) Usage Name Ref: Typical AT-101
0 00 Reserved (no event indicated)9
1 01 Keyboard ErrorRollOver9 N/A
2 02 Keyboard POSTFail9 N/A
3 03 Keyboard ErrorUndefined9 N/A
4 04 Keyboard a and A4 31
5 05 Keyboard b and B 50
6 06 Keyboard c and C4 48
No, po teh tabelah sem napisal sample program, ki naj bi mi poslal črko 'b' v PC. (program vsaj meni zgleda logicen:) )
Koda: |
#include "D:\usb\USBdsc.c" //to je predelana dat "USBdsc.c" na tipkovnico
unsigned char k;
int read[64],write[64];
void interrupt()
HID_InterruptProc();
void Init_Main()
// Disable all interrupts
INTCON = 0; // Disable GIE, PEIE, TMR0IE,INT0IE,RBIE
INTCON2 = 0xF5;
INTCON3 = 0xC0;
RCON.IPEN = 0; // Disable Priority Levels on interrupts
PIE1 = 0;
PIE2 = 0;
PIR1 = 0;
PIR2 = 0;
ADCON1 |= 0x0F; // Configure all ports with analog function as digital
CMCON |= 7; // Disable comparators
// Ports Configuration
TRISA = 0xFF;
TRISB = 0xFF;
TRISC = 0xFF;
TRISD = 0;
TRISE = 0x07;
LATA = 0;
LATB = 0;
LATC = 0;
LATD = 0;
LATE = 0;
// Clear user RAM
// Banks [00 .. 07] ( 8 x 256 = 2048 Bytes )
void main() {
Init_Main();
HID_Enable(read, write);
while(1) {
/*Tukaj skenira oz pošlje tipko*/
write[0]=0;
write[1]=0;
write[2]=5; //koda za 'b'
write[3]=0;
write[4]=0;
write[5]=0;
write[6]=0;
write[7]=0;
HID_Write(write,1);
/*Blok, ki pošlje da je tipka sproščena*/
write[0]=0;
write[1]=0;
write[2]=0;
write[3]=0;
write[4]=0;
write[5]=0;
write[6]=0;
write[7]=0;
HID_Write(write,1);
Kje sem ga polomil? Prosil bi za pomoč, ker sedaj res nevem kaj naj naredim.
Lp, Klemen |
kle-man Član
Objavljeno: Pet Apr 09, 2010 11:35 am Naslov sporočila: |
Zadeva je rešena!  |
klemen88 Član
Pridružen-a: Tor 01 Jan 2008 17:37 Prispevkov: 747 Aktiv.: 3.51 Kraj: Slovenj Gradec
Objavljeno: Pet Apr 09, 2010 11:55 am Naslov sporočila: |
kle-man je napisal/a: |
Zadeva je rešena!  |
Lep pozdrav!
Lepo bi bilo če bi napisal kje je bila težava, da bodo lahko drugi uporabniki videli, če bodo imeli podobno težavo! |
kle-man Član
Objavljeno: Pet Apr 09, 2010 1:58 pm Naslov sporočila: |
Se opravičujem:D
Težava je bila v HID_Write(write,1); ukazu.
Torej pošiljav sem samo en byte namesto vseh osem. Torej samo spremeniš ukaz HID_Write(write,1); v HID_Write(write,8); in zadeva deluje
Lp, Klemen |
