Projektor - na prostem in podnevi?
Prispevkov: 1035
Aktiv.: 5.60
PrispevekObjavljeno: Sre Jun 02, 2010 6:27 pm    Naslov sporočila:   Odgovori s citatom
bosko je napisal/a:
Ja Ziga, slucajno se mi sanja malo... Enkrat pojdi v kako trgovino, kjer imajo plazme in LCD-je pa probaj kateri je toplejši. Boš presenečen... Da se razumemo,. Vsaka tehnologija ima prednosti, tako v plus kot v minus. Samo mi pa gre na živec, ko ljudje nekaj vzamejo zdravo za gotovo brez razmislit. Pomisli. Žarnica v LCD-ju skozi sveti, piksli v plazmi pa se prižigajo po potrebi. ??? Je kje logika da je plazma peč ?? Tele primerjave so delane cca 3 leta nazaj.. Glej porabljeno energijo, ne pa priključno moč.
Samsung plasma:
standby: 1 watt, 0.06 amps
black screen: 65 watts, 0.58 amps
white screen: 256 watts, 2.23 amps
red screen: 232 watts, 2.02 amps
blue screen: 231 watts, 2.13 amps
green screen: 208 watts, 1.80 amps
static: 311 watts, 2.71 amps
Atanarjuat (2 hr 30 min): 0.69 kilowatt hours
Battlestar Galactica (2 hr): 0.49 kilowatt hours
CNN (overnight): 4.3 kilowatt hours
Samsung plasma (super power saver mode):
white screen: 203 watts, 1.76 amps
red screen: 191 watts, 1.7 amps
blue screen: 190 watts, 1.67 amps
green screen: 180 watts, 1.56 amps
static: 251 watts, 2.21 amps
Atanarjuat (3 hr): 0.64 kilowatt hours
Battlestar Galactica (3+ hr): 0.67 kilowatt hours
CNN (overnight): 3.97 kilowatt hours
Samsung LCD
standby: 10 watts, 0.17 amps
black screen: 200 watts, 2.55 amps
white screen: 199, 2.58 amps
red screen: 199 watts, 2.57 amps
blue screen: 198 watts, 2.57 amps
green screen: 198 watts, 2.96 amps
static: 264 watts, 3.23 amps
Atanarjuat (2 hr 30 min): 0.57 kilowatt hours
CNN (overnight): 3.41 kilowatt hours
Samsung LCD (lower-brightness mode)
black screen: 196 watts, 2.50 amps
white screen: 195 watts, 2.52 amps
red screen: 196 watts, 2.51 amps
blue screen: 196 watts, 2.52 amps
green screen: 195 watts, 2.51 amps
static: 235 watts, 3.0 amps
Atanarjuat (3 hr): 0.65 kilowatt hours
Battlestar Galactica (3 hr+): 0.72 kilowatt hours
CNN (overnight): 3.84 kilowatt hours
No daj še kaj bolj pametnega napiši.
Kje ti piše velikost diagonale? Pa daj ti komu drugemu buče prodajaj. Poglej spodnja linka, lcd porabi 90W, plazma pa 200W(42") Pa ne mi rečt da to ni razlika. Poleg tega nikjer ne piše model televizije, pa ne se z mene norca delati, ker se tudi jaz nekaj spoznam na to.
Pa če se že 100W pozna pri 42" modelu, kaj bo šele razlika pri 60" modelu.
http://www.moj-tv.com/home.php?sortiraj=proizvajalec&IDK=2&artikel=6943&filter=49&___page=#open
http://www.moj-tv.com/home.php?sortiraj=proizvajalec&IDK=1&artikel=6823&filter=51&___page=#open
EDIT:
Glede hlajenja je pa tako, verjetno veš na kaj dela plazma in na kaj lcd. Plazma ga na plin lcd pa na kristale (po splošeno). A si morda kdaj pogledal v trgovini hrbtni del plazme? Kar nekaj plazem ima zadaj ventilatorje, lcd-ji tega ponavadi nimajo. Daj enkrat ko greš v trgovino z zabavno elektroniko, pošlataj eno plazmo od zadaj in boš vedel o čem govorim. Sicer je pa res da so nove panasonicove plasme že kar izboljšane, vendar je še vedno velika poraba v primerjavi z lcd.
Pyr0Beast
Prispevkov: 4969
Aktiv.: 23.93
PrispevekObjavljeno: Sre Jun 02, 2010 9:19 pm    Naslov sporočila:   Odgovori s citatom
Merjeno pa z navadnim watt-metrom za 10€.
CRT pa na barve a ne.
Naj nabavi kar če. Neko zezanje v porabi je irelevantno. Če hoče šparati naj ne kupi televizorja, pa je.
Unknown_User
Pridružen-a: Tor 03 Nov 2009 13:31
Prispevkov: 481
Aktiv.: 2.52
Kraj: UFO iz Butal pri T''minu
PrispevekObjavljeno: Sre Jun 02, 2010 11:26 pm    Naslov sporočila:   Odgovori s citatom
bosko je napisal/a:
SlavkoP.
Malo bo treba pogooglat:
-pa videt da je Plazma hitrejša, kontrastnejša, temnejša kot LCD. Ter zato primerna za VIDEO!!! Prav tako je še vedno prisoten efekt Burn-In-a.
-Da je LCD primernejši za statično, računalniško sliko.. Kjer ni hitrih sprememb v sliki...
Moč. V Lcd-ju so žarnice ki svetijo STALNO. V plazmi Pixli svetijo po potrebi.
42" LCD ter 42" Plazma bosta za povprečen film porabila približno enako število KWh.
Tako, da vsaka tehnologija ima svoj + ter -, le da je tole z porabo za lase privlečeno.
Pa dajmo tu notri vmešati še LED LCD. Kakšne so izkušnje z temi?
Prispevkov: 1035
Aktiv.: 5.60
PrispevekObjavljeno: Čet Jun 03, 2010 8:43 am    Naslov sporočila:   Odgovori s citatom
CRT, televizija ima katodo.
Drugače pa ja, led je ena izmed best rešitev. Boljši kontrast in črna barva od lcd-ja
Olaf
Pridružen-a: Tor 14 Nov 2006 20:09
Prispevkov: 127
Aktiv.: 0.56
PrispevekObjavljeno: Čet Jun 03, 2010 10:15 am    Naslov sporočila:   Odgovori s citatom
Živjo
Samo update...
So prišli pogledat, pa smo se dogovorili da prinesejo te dni kar projektor in platno in bomo zadevo preizkusili. Poročam kakšen bo rezultat.
To mi deli!
Unknown_User
Prispevkov: 481
Aktiv.: 2.52
PrispevekObjavljeno: Čet Jun 03, 2010 12:11 pm    Naslov sporočila:   Odgovori s citatom
ziga555 je napisal/a:
No sicer je tu govora o velikih formatih, ampak jaz bi pa potreboval precej manjšo predusem pa zelo ugodno TV z DVB-T MPEG-4 dekoderjem, z nekje diagonale 60cm.
Lojz
Prispevkov: 668
Aktiv.: 2.81
Kraj: Koroška
PrispevekObjavljeno: Čet Jun 03, 2010 12:35 pm    Naslov sporočila:   Odgovori s citatom
bosko je napisal/a:
Samsung LCD
Kje pa je tukaj logika?
200watts - 2,55 amps
198watts - 2,96 amps
Pri manj W, več A? Boo hoo!
Pa še nekaj: na kolikšno napetost pa je sploh priključeno?
standby: 10 watts, 0.17 amps - to pomeni nekje 59V.
Lojz
Prispevkov: 1035
Aktiv.: 5.60
PrispevekObjavljeno: Čet Jun 03, 2010 1:24 pm    Naslov sporočila:   Odgovori s citatom
Saj pravim da je škoda da je to sploh limal gor. Ker se verjetno ravno tolko spozna da je fan plazme in da buče prodaja. Mi smo imeli plazmo, sedaj imam lcd. (oziroma lcd-je), pri vseh so plusi in minusi, vendar gredo plazme počasi v zaton. Tukaj jim delajo veliko konkurenco led lcd tv-ji. In ja ekran plazme je hladen zaradi plina, plin pa je hladen. Se pa zato toliko več segreva plazma od zadaj. Toliko od presenečenja
UNKNOWN USER, predlagam tole: http://www.bigbang.si/slika/tv-sprejemniki/lcd-tv-sprejemniki/460721-philips-26pfl3404h-12-tv-lcd
Ali pa tale led tv: http://www.bigbang.si/slika/tv-sprejemniki/led-tv-sprejemniki/470395-lg-26le3300-tv-led
Sicer je teh malih led lcd ekranov bolj malo.
Na kakšno razdaljo pa boš gledal, ter ali boš še kaj drugega kot televizijo gledal?
Pyr0Beast
Prispevkov: 4969
Aktiv.: 23.93
PrispevekObjavljeno: Čet Jun 03, 2010 1:34 pm    Naslov sporočila:   Odgovori s citatom
Lojz je napisal/a:
bosko je napisal/a:
Samsung LCD
Ni je. Ta test je lari-fari, ker vidiš da so zafrknili že pri merilni opremi in izračunih.
mucek4
Prispevkov: 2952
Aktiv.: 12.42
PrispevekObjavljeno: Čet Jun 03, 2010 1:41 pm    Naslov sporočila:   Odgovori s citatom
LG xxLHyyyy serije se da nadgraditi da se gleda HD filme neporedno iz USB diska.
xx je velikost zaslona
yyyy oznaka TVja (8000 že omogoča gledanje, za ostale pa http://lgusb.wikispaces.com/)
Prispevkov: 1035
Aktiv.: 5.60
PrispevekObjavljeno: Čet Jun 03, 2010 1:55 pm    Naslov sporočila:   Odgovori s citatom
Ja saj tudi philipsi 9 serije podpirajo mkv.
Tole je meni še všeč:
http://www.consumer.philips.com/c/cinema-21-9/30849/cat/gb/
21:9, Predvsem pa ambilight.
Unknown_User
Prispevkov: 481
Aktiv.: 2.52
PrispevekObjavljeno: Čet Jun 03, 2010 3:45 pm    Naslov sporočila:   Odgovori s citatom
Cirka 2-5m oddaljenosti. Glede priklopa pa raznorazna periferija, od DVDja, posledično lahko tudi HDDja, igralnih konzol, računalnika, itd.
Prispevkov: 1035
Aktiv.: 5.60
PrispevekObjavljeno: Čet Jun 03, 2010 11:15 pm    Naslov sporočila:   Odgovori s citatom
Za to bi priporočal najmanj 32"
Prispevkov: 1035
Aktiv.: 5.60
PrispevekObjavljeno: Ned Jun 06, 2010 3:29 pm    Naslov sporočila:   Odgovori s citatom
http://dne.enaa.com/prikaziCL.asp?clID=32608
Čeprav dvomim da bo to res.
Olaf
Prispevkov: 127
Aktiv.: 0.56
PrispevekObjavljeno: Ned Jun 06, 2010 7:30 pm    Naslov sporočila:   Odgovori s citatom
Fantje so prišli in ste imeli kar prav. V oblačnem vremenu, se je slika videla zelo, zelo slabo. Za kolikor toliko dobro sliko bi bilo treba zagrnit vse za paltnom ter dobršen del ob straneh. In zavese pod kozolec pač ne pašejo.
Torej plazma. Mi lahko kdo svetuje kje naj pogledam za čimvečje plazme? Na netu sem našel velikosti do 60". Kje naj pogledam za večje?
To mi deli!
Stran 2 od 3
Uptime: 10 dni
