BorisK Član
Pridružen-a: Sre 02 Apr 2008 23:43 Prispevkov: 278 Aktiv.: 1.33 Kraj: Ljubljana
s56al Član
Pridružen-a: Pon 19 Sep 2005 12:03 Prispevkov: 788 Aktiv.: 3.32 Kraj: JN66SI & JN76TM
Objavljeno: Čet Jul 29, 2010 2:37 pm Naslov sporočila: |
Popravkom frekvence v majhnem območju okoli nazivne vrednosti. Lahko se izrabi za trimanje ali kakšno bolj napredno funkcijo (npr. PLL regulacija, modulacija,...). Kako in koliko, piše v data-sheetu na linku, ki si ga pripel.
LP, S. |
BorisK Član
Objavljeno: Čet Jul 29, 2010 8:17 pm Naslov sporočila: |
Hvala za odgovor. Medtem sem prejel tudi obširen odgovor proizvajalca, spodaj sem ga prilepil, če si še kdo želi razširiti obzorje.
Frequency from Quartz Crystal Qscillator like an OCXO is always drifting according time and temperature
Oscillators are utilize as a Slave or a Master
OCXOV-AV5
For the “Slave” application (PLL Loop) the oscillator is part of a system were the frequency is compare with an absolute frequency reference such as a Cesium clock or GPS Synch.
The frequency is continuously corrected by the loop, in this case the external frequency pulling must be sufficient to control the unit for at least 10 years, and sometime it goes up to 20 years
This is to compensate the aging and for some application they will even do the compensation of the external temperature influence.
OCXOV-BR1
This is for “Master” application; in this case the oscillator is the master clock of a system.
Frequency is drifting according time and need to be calibrated over the year.
This is a typical application for “instruments” |
