TRICOPTER
Prispevkov: 1035
Aktiv.: 5.62
PrispevekObjavljeno: Tor Feb 15, 2011 8:38 pm    Naslov sporočila:  TRICOPTER Odgovori s citatom
Meni je zelo všeč tricopter.Ga je morda kdo že naredil? Vsebuje atmelov atmega 32 mikrokontroler.
Klik 1
Ma morda kdo še shemo samega vezja in program? Sam sem nekaj našel
Koda:
modify AeroQuad Module)
// If throttle in minimum position, don't apply yaw
if (transmitterCommand[THROTTLE] < MINCHECK) {
for (motor = FRONT; motor < LASTMOTOR; motor++)
motorCommand[motor] = minCommand;
// If motor output disarmed, force motor output to minimum
if (armed == 0) {
switch (calibrateESC) { // used for calibrating ESC's
case 1:
motorCommand[motor] = MAXCOMMAND;
break;
case 3:
motorCommand[motor] = limitRange(testCommand, 1000, 1200);
break;
case 5:
motorCommand[motor] = limitRange(remoteCommand[motor], 1000, 1200);
safetyCheck = 1;
break;
default:
motorCommand[motor] = MINCOMMAND;
to:
for (motor = REAR ; motor < LASTMOTOR; motor++) <<<<<<<<<<<<< here
if (armed == 0) {
case 1:
for (motor = REAR; motor < LASTMOTOR; motor++) <<<<<<<<<<< here
break;
case 3:
for (motor = REAR; motor < LASTMOTOR; motor++) <<<<<<<<<<<<< here
break;
case 5:
for (motor = REAR; motor < LASTMOTOR; motor++) <<<<<<<<<<<<<< here
safetyCheck = 1;
break;
default:
modify (Motors Module):
// Sends commands to all motors
void commandAllMotors(int motorCommand) {
#ifdef ServoControl
frontMotor.write(motorCommand);
rearMotor.write(motorCommand);
rightMotor.write(motorCommand);
leftMotor.write(motorCommand);
#endif
to:
#ifdef ServoControl
// frontMotor.write(motorCommand); <<<<<<<<<<<<< comment it
#endif
L.P
ŽIGA
Nazadnje urejal/a . Tor Feb 15, 2011 8:54 pm; skupaj popravljeno 1 krat
Prispevkov: 5530
Aktiv.: 24.05
PrispevekObjavljeno: Tor Feb 15, 2011 8:53 pm    Naslov sporočila:   Odgovori s citatom
Ček dis aut! Smile
http://shrediquette.blogspot.com/
LP, g
...lahko pa se tudi motim ...
Prispevkov: 1035
Aktiv.: 5.62
PrispevekObjavljeno: Sre Feb 16, 2011 9:49 am    Naslov sporočila:   Odgovori s citatom
Si morda ti naredil ta tricopter? Kako je leteti znjim?
WaterBoy
Pridružen-a: Ned 26 Sep 2010 19:39
Prispevkov: 73
Aktiv.: 0.41
Kraj: Šoštanj
PrispevekObjavljeno: Sre Feb 16, 2011 11:46 pm    Naslov sporočila:   Odgovori s citatom
Pomoje je bolje da glede tega povprašaš na forumu www.modelarji.com
Prispevkov: 1035
Aktiv.: 5.62
PrispevekObjavljeno: Čet Feb 17, 2011 12:02 am    Naslov sporočila:   Odgovori s citatom
Ja, ampak se mi nekako zdi da je tukaj glavna stvar elektronika in ne ogrodje Wink
A.B.
Pridružen-a: Sob 24 Jan 2009 14:50
Prispevkov: 91
Aktiv.: 0.46
PrispevekObjavljeno: Čet Feb 17, 2011 12:24 am    Naslov sporočila:   Odgovori s citatom
LINK , LINK
Prispevkov: 1035
Aktiv.: 5.62
PrispevekObjavljeno: Čet Feb 17, 2011 12:27 am    Naslov sporočila:   Odgovori s citatom
Tole pa ni poceni špas Rolling Eyes
mcride
Pridružen-a: Tor 27 Okt 2009 22:36
Prispevkov: 788
Aktiv.: 4.14
PrispevekObjavljeno: Čet Feb 17, 2011 12:43 am    Naslov sporočila:   Odgovori s citatom
ziga555 je napisal/a:
Ne ga "srat" , kolega ga je prodajal pred časom sicer "home made" za 200€
