xsyt Član
Pridružen-a: Sre 28 Maj 2008 22:19 Prispevkov: 1346 Aktiv.: 6.48 Kraj: Slov.Bistrica
Objavljeno: Pet Jun 24, 2011 3:50 pm Naslov sporočila: Atmel AVR Studio 5 final |
Izšla je final različica AVR Studio 5;
Koda: |
New Integrated Development Environment (IDE) for developing and debugging embedded Atmel® AVR® applications.
The AVR Studio® 5 editor simplifies code editing and lets you write code more efficiently. It supports all 8- and 32-bit AVR microcontrollers, and connects seamlessly to Atmel AVR debuggers and development kits.
The AVR Studio 5 IDE gives you a seamless and easy-to-use environment to write, build, and debug your C/C++ and assembler code.
What's new in AVR Studio 5:
One environment for 8- and 32-bit
Integrated C Compiler
New Project Wizard
A Better Editor
Atmel AVR Software Framework
Support for JTAGICE3 in-system debugger
What's new in version 5.0:
AVR Software Framework updated to 2.5.1
AVR Toolchain updated to 3.2.3
Added support for STK500
Added support for HVSP/HVPP programming in AVR Dragon
Added "start without debugging" support for programmers and kits.
!!!NOTE:
AVR Studio 5.0 cannot be upgraded from its beta versions. Please uninstall any beta versions of AVR Studio 5.0 from Add/Remove programs and reinstall.
Download: LINK
xsyt Član
Objavljeno: Pet Jun 24, 2011 3:50 pm Naslov sporočila: |
Ali deluje s programatorjem od Darkota še nisem testiral. |
luka1995 Član
Pridružen-a: Sob 17 Apr 2010 21:42 Prispevkov: 614 Aktiv.: 3.33 Kraj: Ljubljana
Objavljeno: Pet Jun 24, 2011 4:47 pm Naslov sporočila: |
Super, že inštaliram!  |
Pridružen-a: Pon 24 Feb 2003 17:09 Prispevkov: 14673 Aktiv.: 61.93 Kraj: Koroška-okolica Dravograda
Objavljeno: Pet Jun 24, 2011 7:03 pm Naslov sporočila: |
Če ga je kdo instaliral naj preveri, če ima editor možnost vklopa številčenja vrstic. (kot ima to recimo microchipov MPLAB oz. razni drugi editorji, ki so namenjeni programiranju) Do sedaj tvorci programa očitno še niso pogruntali, da je to zelo dobrodošla, če že ne nujna oprema editorja. _________________ lp
xsyt Član
Objavljeno: Pet Jun 24, 2011 8:51 pm Naslov sporočila: |
Silvo; seveda ima! (smešno kako hitro sem to nastavitev našel; po defaultu je izključeno!)
Objavljeno: Pet Jun 24, 2011 9:36 pm Naslov sporočila: |
Super. Hvala. Zaradi te zadeve ga bom verjetno poinstaliral. Dela z darkotovim programatorjem? _________________ lp
JamesQ Član
Pridružen-a: Čet 16 Nov 2006 12:05 Prispevkov: 362 Aktiv.: 1.60 Kraj: Novo mesto/Ljubljana
Objavljeno: Sob Jun 25, 2011 8:19 am Naslov sporočila: |
Lep pozdrav.
Darkov programatorček je iz družine klonov STK500, tako da pomoje deluje. AVRStudio podpira STK500.
UPDATE: LINK
LDŽ _________________ Baje sem inteligentna baraba ... FAE@Silica Slovenia (= |
Tomazp Član
Pridružen-a: Sob 02 Feb 2008 13:24 Prispevkov: 559 Aktiv.: 2.64 Kraj: Ljubljana
Objavljeno: Sob Jun 25, 2011 1:15 pm Naslov sporočila: |
Beta program sem preizkusil in nisem bil preveč navdušen. Program je narejen na drugačni osnovi in tako bistveno počasnejši kot 4. Je verzija 5 kaj hitrejša? |
Objavljeno: Sob Jun 25, 2011 4:47 pm Naslov sporočila: |
Nainstaliral. Instalacija traja, traja.... Tudi zagon programa je kar dolg, če prav nimam ne vem kako počasno mašino, na katero sem program instaliral. Editor ima tisto, kar sem pogrešal pri prejšnih verzijah (številčenje vrstic). Darktovega programatorja nisem uspel zagnati. Tako, da bom ostal kar na predhodni verziji. _________________ lp
tozir Član
Pridružen-a: Pon 17 Mar 2008 19:10 Prispevkov: 187 Aktiv.: 0.89 Kraj: Celje
protoncek Član
Pridružen-a: Sre 31 Jan 2007 9:41 Prispevkov: 9573 Aktiv.: 42.79 Kraj: Mengeš
Objavljeno: Pon Jun 27, 2011 8:48 am Naslov sporočila: |
Pa so uradno trdili da bo finalna verzija podpirala stk500---no, zdaj pa to. Če je temu tako, potem bomo pač ostali na štirici (razen če bo Darko spremenil software... ).
Bom tudi jaz popoldne poskusil, če gre.
EDIT: Nope, neuspešno. Novi studio že leti dol...očitno so se tako usmerili da podpira samo ORIGINALNI stk500... barabe... |
program_er Član
Pridružen-a: Sob 08 Mar 2008 13:47 Prispevkov: 2173 Aktiv.: 10.33 Kraj: Maribor (Pohorje)
Objavljeno: Čet Mar 01, 2012 12:35 am Naslov sporočila: |
AVR Studio 5.1 ne podpira več nobenih programatorjev stila "mkII Clone", ampak samo njihove originalne... Enako Atmel Studio 6.
Pravkar zgroženo opazil, ko sem na drugem računalniku kot ponavadi iz spletne strani downloadal AVR Studio 5, nato pa videl, da je v resnici 5.1 Še sreča, da imam shranjeno namestitveno datoteko za 5.0, ki še podpira več programatorjev/debuggerjev. |
kobranka Član
Pridružen-a: Sob 24 Jul 2010 19:37 Prispevkov: 3403 Aktiv.: 18.76 Kraj: nekje v zgornjem posočju
Objavljeno: Čet Mar 01, 2012 11:07 am Naslov sporočila: |
Potem mi ga boš veretno moral tudi meni priskrbeti, ker tudi nimam original programatorja ali pa bom moral oditi na travnik. |
protoncek Član
Objavljeno: Čet Mar 01, 2012 11:30 am Naslov sporočila: |
Jaz ga (zaenkrat) itak uporabljam samo za pošiljanje HEX datoteke v AVR, zato sem še veselo na štirici...
BTW...je kakšna "lažja" varianta za programiranje z Darkotovim programatorjem? |
lojzek Član
Objavljeno: Čet Mar 01, 2012 11:43 am Naslov sporočila: |
Če je pa kaj lažjega od nekaj klikov na miško... Edino da kdo drug namesto tebe na gumbe pritiska  |
