iggy Član
Pridružen-a: Pon 15 Avg 2005 13:38 Prispevkov: 247 Aktiv.: 1.04 Kraj: LJ/ng
Objavljeno: Pet Apr 14, 2006 12:39 pm Naslov sporočila: Če to ni zanimivo... |
Video je 10Meg, gre pa za uporabo LED kot fotosenzorja, zadnje čase razmišljam, da bi ukinil tipke.
http://mrl.nyu.edu/~jhan/ledtouch/ledtouch.mpg _________________ LP
Iggy |
oversc0re Član
Pridružen-a: Tor 13 Sep 2005 15:20 Prispevkov: 460 Aktiv.: 1.94 Kraj: Radomlje
Objavljeno: Pet Apr 14, 2006 12:45 pm Naslov sporočila: |
Pa je znano na kakšnem principu to deluje? So to čisto navadne ledice? Zraven .mpg-ja nisem zasledil zvoka. _________________ The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' but 'That's funny ...'
Isaac Asimov (1920 - 1992) |
iggy Član
Objavljeno: Pet Apr 14, 2006 12:48 pm Naslov sporočila: |
Ja, zvoka ni. Princip je, da se vsako LED diodo lahko v zapornem področju uporabi kot fotosenzor. Sicer se temu še nisem posvetil ampak uporabnih aplikacij bo veliko. Osebno bom skušal izkoristiti to idejo za daljinca. Ja, gre za čisto navadne ledice. _________________ LP
Iggy |
oversc0re Član
Objavljeno: Pet Apr 14, 2006 1:23 pm Naslov sporočila: |
Malo sem pobrskal, pa ne kaže tako zelo dobro...
The problem with using LEDs as human interface sensors is they are extremely sensitive to noise and interference. Jeff's video was shot in a dark room, and I have done much of my development in a similar dark room - this is because with a moderate to high level of ambient lighting, the sensitivity of the LEDs is greatly diminished. This really is a death blow for their use in any sort of mainstream applications. |
... what I ended up doing was performing one of two simple alogrythims ... the first was a an attemp to 'subtract out' the ambient light, subtracting the current reading from a contanstly updated "no object" reading. the second method involves subtracting one reading from the previous reading of that sensor, looking for a "big enough" change.
both of these methods worked to some degree, but only to a point, indoors under low to moderate lighting. neither would work outdoors, where even a cloudy day was so bright that the sensors were swamped and always read 0 - ok, I didn't actually go outdoors, but I tried it in a very sunny room, which I'd equate in brightness to a cloudy outdoor day - same result. |
Edino IR ledice čez optični IR filter, pa še to zunaj ne bi delovalo, ker je v soncu mnogo IR spektra  _________________ The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' but 'That's funny ...'
NeoTO Član
Pridružen-a: Pon 28 Mar 2005 19:19 Prispevkov: 2752 Aktiv.: 11.59 Kraj: Trzic
Objavljeno: Pet Apr 14, 2006 4:22 pm Naslov sporočila: |
Pred kakim letom sem tudi sam naredil nekaj podobnega. Imel sem 4 LED-ice priključene na mikrokontroler. Ko si dal prst nad eno izmed njih, se je prižgala.
Ko bi videli, kako so se ljudje čudili, ko sem to na faksu kolegom (sošolcem) pokazal...  |
iggy Član
Objavljeno: Pet Apr 14, 2006 7:42 pm Naslov sporočila: |
Ja, zagotovo ni lahko zadevo narediti, da bo delovala pod vsemi pogoji. Kako hude so ovire pa sam ne vem, ker, kot že rečeno, zadeve še nisem preštudiral. Vem pa da bo za mojo napravico zagotovo zelo uporabno. Meni je zadeva strašansko všeč. _________________ LP
Iggy |
oversc0re Član
Objavljeno: Pet Apr 14, 2006 7:53 pm Naslov sporočila: |
Tudi meni... Če ti kaj uspe, sporoči!
Še nekaj: Kolikor sem razumel zadevo, je treba imeti matriko tako da se potem svetloba sosednjih ledic odbija in bere? To pomeni da bi rabil najmanj 2? Ali je možno svetlobo oddajat iz iste ledice katero bi potem bral?
Lp, M@ic _________________ The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' but 'That's funny ...'
NeoTO Član
Objavljeno: Pet Apr 14, 2006 8:02 pm Naslov sporočila: |
Se komu sanja, kako bi npr. 16 LED diod 'bidirekcijsko' povezal? 4 LEDice sem jaz povezal tako, da sem dal vsak pin diode na posamezen I/O pin mikrokontrolerja...
In na kakšnem principu mislite, da tole deluje? Kaj meri s temi diodami? Namreč za fotosenzor potrebuješ izvor svetlobe, tukaj pa ne razumem čisto, kako bi delovalo!? Prižge vse LED-ice v okolici senzorja in meri, kakšen je odboj?
edit: vidim, da me je že nekdo prehitel, medtem ko sem tole pisal...  |
iggy Član
Objavljeno: Pet Apr 14, 2006 8:17 pm Naslov sporočila: |
oversc0re je napisal/a: |
Lp, M@ic |
Nisem prebiral teksta, sem pa 100% da ne moreš hkrati svetiti z LED in odčitavati zaporni tok le-te. Ko Meriš zaporni tok je LED zaporno polarizirana, ko svetiš pa pač ne. Lahko uporabljaš eno LED, ne moreš pa početi dveh stvari hkrati. Bom malo prebral zadevo.
EDIT: Na filemanagerju v mapi "Diode" sem upload-al zanimiv *.pdf Za vse zainteresirane je to obvezno čtivo. _________________ LP
Iggy |
Uptime: 6 dni
