IR receiver (RC5) v Bascom AVR z ATMega8
tilz0R
Pridružen-a: Čet 31 Maj 2012 15:39
Prispevkov: 898
Aktiv.: 5.65
Kraj: Črnomelj
PrispevekObjavljeno: Čet Jul 26, 2012 2:06 pm    Naslov sporočila:  IR receiver (RC5) v Bascom AVR z ATMega8 Odgovori s citatom
Zdravo!
Ker sem slabo podkovan za napredno tehnologijo v bascom-avr, sem za sprejem IR signala pregledal kar help ki ga bascom ponuja, in našel kodo:
Koda:
'name                     : rc5.bas
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : based on Atmel AVR410 application note
'micro                    : 90S2313
'suited for demo          : yes
'commercial addon needed  : no
$regfile = "m8def.dat"                                   ' specify the used micro
$crystal = 1000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
$hwstack = 32                                               ' default use 32 for the hardware stack
$swstack = 10                                               ' default use 10 for the SW stack
$framesize = 40                                             ' default use 40 for the frame space
'use byte library for smaller code
$lib "mcsbyte.lbx"
Config Rc5 = Pind.2
'the interrupt routine is inserted automatic but we need to make it occur
'so enable the interrupts
Enable Interrupts
'reserve space for variables
Dim Address As Byte , Command As Byte
Print "Waiting for RC5..."
Do
'now check if a key on the remote is pressed
'Note that at startup all pins are set for INPUT
'so we dont set the direction here
'If the pins is used for other input just unremark the next line
'Config Pind.2 = Input
Getrc5(address , Command)
'we check for the TV address and that is 0
If Address = 0 Then
  'clear the toggle bit
  'the toggle bit toggles on each new received command
  'toggle bit is bit 7. Extended RC5 bit is in bit 6
   Command = Command And &B01111111
  Print Address ; "  " ; Command
End If
Loop
End
Shema, za priklop na ATMego je tukaj
Zadeva gre na INT0 pin na čipu.
IR sprejemnik je od LG hišnega kina (delujoč), daljinec je pa prav tako od tistega hišnega kina (za test uporabljeno, da je zagotovo usklajeno, oddajnik => sprejemnik).
Pač ko tisto kodo izvedem, dodal sem še kodo za lcd, da mi na njem izpiše "address" in "command", ampak sta obe VEDNO 255.
Uporabljam 1MHz quartz (interni). Sem pa nekje zasledil, da je zgornja koda namenjena 12MHz kristalu zunanjemu. Ali to drži, če dam 12MHz kristal, bi potem tole moralo delati?
Hvala za odgovor!
Knowledge sharing is caring.
majerle.eu | stm32f4-discovery.net
Nazadnje urejal/a tilz0R Čet Jul 26, 2012 2:29 pm; skupaj popravljeno 1 krat
MadMax
Prispevkov: 4743
Aktiv.: 20.02
PrispevekObjavljeno: Čet Jul 26, 2012 2:22 pm    Naslov sporočila:   Odgovori s citatom
Kje si zasledil to o 12MHz?
Ti ukaz $crystal = 4000000 v programu kaj pomeni? Vsaj po ZKP?
Pa katero mego sploh imaš - in spet, $regfile = "2313def.dat" pove kaj?
Nazadnje urejal/a MadMax Čet Jul 26, 2012 2:25 pm; skupaj popravljeno 1 krat
tilz0R
Prispevkov: 898
Aktiv.: 5.65
Kraj: Črnomelj
PrispevekObjavljeno: Čet Jul 26, 2012 2:26 pm    Naslov sporočila:   Odgovori s citatom
Se opravičujem za to, ampak sem ta program sedaj kopiral iz bascom helpa na internetu.
Torej, doma imam $crystal = 1000000, in pa $regfile = "m8def.dat"
prebral sem pa tukaj: http://www.svet-el.si/phpBB2/viewtopic.php?t=138&highlight=getrc5
MadMax
Prispevkov: 4743
Aktiv.: 20.02
PrispevekObjavljeno: Čet Jul 26, 2012 2:29 pm    Naslov sporočila:   Odgovori s citatom
Lahko da je 1MHz prepočasno.
Sem ravno 2 dni nazaj razbijal glavo, ko sem iz Mega32 selil program za senzor vlage DHT11 na Mega8. V trenutku odčitavanja je zmrznil. Po povišanju takta na 8MHz je speljalo kot raketa.
Seveda ni dovolj le dodati kvarc, spremenit moraš še ustrezne fuse bite, kar verjetno že veš.
tilz0R
Prispevkov: 898
Aktiv.: 5.65
Kraj: Črnomelj
PrispevekObjavljeno: Čet Jul 26, 2012 2:31 pm    Naslov sporočila:   Odgovori s citatom
Sem popravil sedaj zgornjo kodo.
Aha, tako je to tudi res čist možno. Še dobro da kristali jutri pridejo Smile
Hvala ti za to Smile
MadMax
Prispevkov: 4743
Aktiv.: 20.02
PrispevekObjavljeno: Čet Jul 26, 2012 2:46 pm    Naslov sporočila:   Odgovori s citatom
Nja, sicer pa, a si prepričan, da daljinec sploh uporablja RC5? Lahko je kaj drugega, RC5 ni edini. Če program ne izpiše nič (255) v kolikor ne razbere RC5...
tilz0R
Prispevkov: 898
Aktiv.: 5.65
Kraj: Črnomelj
PrispevekObjavljeno: Čet Jul 26, 2012 2:52 pm    Naslov sporočila:   Odgovori s citatom
MadMax je napisal/a:
piše že tako. upam da ne lažejo Smile
Sicer pa...našel sem tole spletno stran za preračun bitov. Mi lahko ti prosim nastaviš glede na moje potrebe, se pravi 12MHz, ker se ne razumem čist v to zadevo?
MadMax
Prispevkov: 4743
Aktiv.: 20.02
PrispevekObjavljeno: Čet Jul 26, 2012 3:54 pm    Naslov sporočila:   Odgovori s citatom
Ext. crystal/resonator high freq. 16k ck + 64ms bi moral biti pomoje vredu.
Tu tudi sam nisem čisto doma, še zmeraj grem bolj po metodi poskušanja...
Mi je pa najenostavnje v AVR studiu najprej prebrat obstoječe stanje, potem pa spremenit samo kar rabim.
stursc
Prispevkov: 323
Aktiv.: 1.36
PrispevekObjavljeno: Čet Jul 26, 2012 8:12 pm    Naslov sporočila:   Odgovori s citatom
RC5 koda lepo deluje na notrnji oscilator
Preiskušeno vsaj na petih AVR-jih (Tiny13, 2313 in Mega8, 16,32)
LP, stursc
tilz0R
Prispevkov: 898
Aktiv.: 5.65
Kraj: Črnomelj
PrispevekObjavljeno: Čet Jul 26, 2012 8:25 pm    Naslov sporočila:   Odgovori s citatom
Se pravi, da je lahko problem samo v tem, da daljinec ne oddaja RC5.
Če torej razdrem daljinec in uporabim tisto IR diodo, ki jo vsebuje, in s čipom ATMega8 oddajam signal preko "RC5SEND".
Nato v drugi ATMegi8 sprejemam ta signal z IR sprejemnikom, ki je bil prav tako v hišnem kinu, z ukazom "GETRC5".
Ali bi potem zadeva delovala ?
Aktiv.: 61.94
PrispevekObjavljeno: Čet Jul 26, 2012 10:54 pm    Naslov sporočila:   Odgovori s citatom
RC5 je protokol. IR dioda nima nič skupnega z njim.
bolha95
Pridružen-a: Pet 14 Dec 2007 21:33
Prispevkov: 296
Aktiv.: 1.39
Kraj: Križe / Tržič
PrispevekObjavljeno: Pet Jul 27, 2012 7:10 am    Naslov sporočila:   Odgovori s citatom
tilz0R je napisal/a:
Jaz imam LG TV (42LW650), pa mi daljinec pošilja NEC kodo. Kako sem ugotovil? Sprejemno diodo sem priklopil na osciloskop.
LP,
Robi
Kjer se znanje konča, se domišljija začne
Highlag
Prispevkov: 4034
Aktiv.: 17.03
Kraj: Črnuče
PrispevekObjavljeno: Pet Jul 27, 2012 8:04 am    Naslov sporočila:   Odgovori s citatom
Za uspešen prenos potrebuješ IR diodo in sprejemnik, ki delujeta na enaki valovni dolžini svetlobe, ter enaki nosilni frekvenci. Potem se ti lahko pripeti še to, da je izhod sprejemnika invertiran.
ssdzkrez
Pridružen-a: Sre 12 Jan 2011 15:13
Prispevkov: 401
Aktiv.: 2.28
Kraj: Hrastnik
PrispevekObjavljeno: Pet Jul 27, 2012 12:19 pm    Naslov sporočila:   Odgovori s citatom
Poizkusi še s kakšnim drugim daljincem. Ko sem se pred časom igral z bascomom in RC5 sem imel doma 3 philipsove daljince in vsi so delali na RC5 protokolu.
tilz0R
Prispevkov: 898
Aktiv.: 5.65
Kraj: Črnomelj
PrispevekObjavljeno: Pet Jul 27, 2012 12:32 pm    Naslov sporočila:   Odgovori s citatom
Nekje sem zasledil, da gorenje uporablja RC5 protokol. Če je to res, potem bi daljinec od klime lahko deloval, bom poizkusil Smile
Edit:
Našel sem shemo za oddajnik RC5 kode za ATMego8:
"IN" se priključi na OC1A pin ATMege.
Ali je to pravilna shema priključitve?
Koda za oddajnik:
Koda:
$crystal = 1000000
$baud = 19200
$hwstack = 32
$swstack = 10
$framesize = 40
Dim Togbit As Byte , Command As Byte , Address As Byte
Command = 12                                               ' power on off
Togbit = 0                                                 ' make it 0 or 32 to set the toggle bit
Address = 0
Do
    Waitms 500
    Rc5send Togbit , Address , Command
Loop
End
PS: Koda za sprejemnik je na začetku teme, spodaj je prikazana shema za sprejemnik RC5 kode (vsaka zadeva na svoji ATMegi), priključen na INT0 pin uC-ja.
Uptime: 493 dni
