kefaja Član
Pridružen-a: Tor 31 Jul 2012 3:08 Prispevkov: 18 Aktiv.: 0.11
Objavljeno: Sre Avg 01, 2012 10:44 pm Naslov sporočila: Program za par tracker (žage) |
Najprej se opravičujem za slabo Slovensko, ne govorijo Slovensko in prevod Google Prevajalnik
če ima kdo vzorec komercialni ali iskalec najbolj podoben par tem
Torej, če mi pošlje ali objavi, če je mogoče
Hvala vnaprej
igo Član
Objavljeno: Sre Avg 01, 2012 11:07 pm Naslov sporočila: |
Please write in English language.
You can also write in your native language, but strictly correct, without dialect and without internet short words.
I hope your language is not too exotic.
LP, Igor |
kefaja Član
Objavljeno: Pet Avg 03, 2012 11:55 pm Naslov sporočila: |
I need schematics of cable tracer (fox/hound) some commercial unit
receiver and transmitter
or something like that
so if someone can post it or send
thanks
igo Član
Objavljeno: Sob Avg 04, 2012 1:14 pm Naslov sporočila: |
I do not think that anyone has schematic.
If there are transmitter and reciever, then you probably want schematic of device for searching underground cables in an open teritory
Transmitter is an oscillator with selectable power and frequencies (in some steps between 5kHz ... 100kHz). You connect wires somewhere around house main fuses and start transmitting. Signal is pushed into 3f 400VAC net through capacitors. High frequency of signal is (0% / 100%) modulated with about 2kHz pulses so actual output is for example 20kHz signal in 2kHz pulses
Power supply could be done with accu. or through 400/230/xxV transformer.
Reciever has selectable resonance frequencies at the same values as transmitter. Another frequency filter brings those 2kHz pulses to the beeper.
Theoretically it is easy, practically you should combine technical solutions from differrent sources (metal detector, oscillators, band pass filters,...) and be careful with 230VAC !!
p.s.: I am not 100% sure about frequencies. It is not only one frequency because of differrent ground properties (sand, soil, dry/wet, ...), so you can select the most suitable frequency. They must not be the same as frequencies, that local electric distributtor uses for communication with your house energy monitor. You should check for allowed frequencies first !
LP, Igor |
kefaja Član
Objavljeno: Ned Jan 06, 2013 2:24 pm Naslov sporočila: |
Sorry for not being here for some time
No I need schematics of device like phone tehnicians use
something like on this image but some comercial unit
I managed to found scheme of TEMPO 200EP but only for receiver
29.93 KB |
1 krat |
