upor_nik Član
Pridružen-a: Ned 11 Jan 2009 13:00 Prispevkov: 450 Aktiv.: 2.24 Kraj: vipavska dolina
Objavljeno: Sob Dec 22, 2012 9:22 pm Naslov sporočila: |
Pozdrav, ..
ELSAK, SPRIJAZNI SE Z DEJSTVOM, KI SEM GA OBČUTIL TUDI SAM, DA, KO DIGITALNI FOTOAPARAT PADE NA OBJEKTIV, NI NOBENE REŠITVE ZA NJEGA.
SAM SEM RAZKOPAL VSAJ 4X SVOJ APARAT, ZALEPIL VSE VODILA NA SVOJA MESTA, ČEPRAV SO BILA SAMO 3, PA VSEENO. ČE NI TO UŠTIMANO V FABRIKI. KJER VEJO KAKO SE STVARI STREŽE, NE BO RATALO. TOLERANCE SO TAKO MAJHNE, DA TUDI ČE SE TI NE TRESE ROKA, NE BO ŠLO.
NAJBOLJŠA REŠITEV JE NABAVA DO 70€ DRAGEGA FOTOAPARATA.
SAM IMAM PO TISTEM ZA 400€, KI SEM GA RAZBIL ZDAJ ENEGA ZA 59€ IN DRUGEGA IMA ŽENA ZA 62e Z DOSTAVO VRED. JA , .. ZADOVOLJEN SEM Z OBEMA.
PA NAJ VSAK PRESODI PO SVOJE!
POZDRAV
5ER
_________________ Sanja svinja o koruzi, ... |
elsak Član
Pridružen-a: Čet 30 Sep 2010 22:55 Prispevkov: 571 Aktiv.: 3.18 Kraj: Koroška
Objavljeno: Sob Dec 22, 2012 9:52 pm Naslov sporočila: |
ZGLEDA DA SI SPREGLEDAL. JAZ IMAM DRUG FOTIČ, KI JE VREDEN BIL 250€, SEDAJ PA JE ŽE ZGUBIL NA VREDNOSTI ZARADI LET. TEGA SEM MISLIL KOLEGU PRODAT, KI JE ŽE KUPU POLNILEC IN BATERIJE ZA TA FOTIČ. POL SEM GA PA KLICU IN MU POVEDAL, JE BIL PA ŽALOSTEN. LAHKO PA MOJGA KUP KI JE PA ŽE NA MEJI MED KOMPAKTNIM IN DSLR. ZA MENE JE POSTAL IGRAČA IN EKRAN JE PREMAJHEN IN NE VIDIM ČRK GOR. ZATO SLIKAM NA PAMET.
ČE NI SKRIVNOST, NAPIŠ KATERE APARATE IMATA IN KAJ SI UNIČU.
TEGA BOM PA PROBAL NEKAK V PROMET SPRAVT, KER IMA ŠE VSE DELE IN SAMA TORBICA JE NEKAJ VREDNA, KABLI. ČE BI VEDEL, KAKO SE RAZDRE, BI GA JAZ SAM PREGLEDAL.
NISEM ŠE POPRAVLJAL APARATOV, MAM PA IZUNJE Z PODOBNIMI REČMI. NAZADNJE SEM POPRAVLJAL ROČNO DIGITALNO URO IN USPEŠNO POOPRAVIL DVI KAMERO.
JAZ ŽE NEKAJ ČASA KUPUJEM DSLR, KER KOT SEM REKEL, JE POSTAL TA MOJ FUJIFILM IGRAČA, ČEPRAV DELA ZELO LEPE SLIKE.
SE KAJ SPOZNAŠ NA FOTIČE? SEM ŽE OGROMNO ROBE IN TESTOV PREGLEDAL, PA ŠE SEDAJ NE VEM KAJ BI BILO OK, DA BI KUPIL ENKRAT IN IMEL ZA SKOZ.
_________________ TUDI ZELO SLABOVIDNI SE UKVARJAMO Z ELEKTRONIKO. |
SamoR Član
Pridružen-a: Ned 24 Jan 2010 3:58 Prispevkov: 393 Aktiv.: 2.09 Kraj: Koper
Objavljeno: Sob Dec 22, 2012 10:38 pm Naslov sporočila: |
ODVISNO KOLIKO DENARJA SI PRIPRAVLJEN ZAPRAVITI. TAM DO 600€ NIKON 5100 ALI KAJ PODOBNEGA. PA DA NE BOŠ RAZOČARAN. NOBEN OD DSLR APARATOV IZ PRVE NE NAREDI "DOBRE" SLIKE. GA MORAŠ KAR MALO POGRUNTAT. PAR STO SLIK, DA GA SPOZNAŠ IN POGRUNTAŠ NASTAVITVE. PA NA SUPER DUPER DELUX ULTRA ZOOM TUDI LAHKO POZABIŠ. OBJEKTIV 55 - 108 MM TI MORA ZADOSTOVATI. ZA KAJ VEČ BO TREBA TUDI GLOBJE V ŽEP. OPTIKA STANE.
_________________ ISF
Boljše je sovražnik dobrega! |
elsak Član
Objavljeno: Sob Dec 22, 2012 11:58 pm Naslov sporočila: |
VZEL BI TAM DO 500€ IN ČE PO MOŽNOSTI DOBIM KIT Z DVEMA OBJEKTIVOMA. JAZ VIDIM MANJ K 5% IN NE MISLM NE VEM KAJ KUPOVAT, KER LAHKO SEM ŽE ČEZ PAR LET SLEP. TUDI NE SLIKAM OGROMNO KOT KAK PROFIČ. ČE PA KAM GREM, PA MORA BIT DOBRA ROBA. DODATNO BI ŠE DOKUPIL EN MAKRO OBJEKTIV. PREBIRAM TESTE NOVEJŠIH APARATOV IN TO KAR BI BILO ZA MENE. FILMOV NE MISLIM SNEMAT Z FOTIČEM, KER IMAM HD KAMERO ZA TA NAMEN. MORA PA IMET ZASLON , KI PRIKAZUJE BELO NA ČRNEM ČRKE IN MENIJE.
ČAS ZASLONKE NE MOREM NATAVLJAT PREKO ŠTEVILK, KER NIČ NE VIDIM. NAREIM PREJ PAR SLIK IN VIDIM, KOLIKO JE TEMNO ALI SVETLO. ZA ISO SE [slovenščina je zame španska vas] BOLJ MATRAT. PRB. VEM KJE SE NAHAJA IN POTEM ŠTEJEM PO VSAKEM PISKU. FAJN BI BILO, ČE BI BILA TIPKA SAMO ZA ISO, SVETOBA, PRESTAVLJANJE GORIŠNICE IN OPDOBNO. V BISTVU BLIŽNJICE. SEM PA VIDEL V TESTIH, DA IMA PAR APARATOV KAR DOBRE NASTAVITVE, KAR MI MOJ SEDANJI NE OMOGOČA. V MISLIH IMAM USER SET.
VEŠ KA BI TE PROSU, ČE MI POVEŠ. ZA NASTAVITEV SVETLOBE IMAM ENE 6 ALI 7 NASTAVITEV RAZLIČNE SVETLOBE IN AVTO. JAZ IMAM SKOZ NA AVTO, KER JE PAR PODOBNIH SVETIL FLUROSCENT IN NE VEM NA KERO DAT. OSTRENJE IMAM NA AF IN KO ZAPISKA SLIKAM. PREDOGLEDNIKA NE UPORABLJAM.
igo Član
Pridružen-a: Sre 11 Okt 2006 19:11 Prispevkov: 3641 Aktiv.: 15.96
Objavljeno: Ned Dec 23, 2012 12:34 am Naslov sporočila: |
elsak je napisal/a: |
FAJN BI BILO, ČE BI BILA TIPKA SAMO ZA ISO, SVETOBA, PRESTAVLJANJE GORIŠNICE IN OPDOBNO. V BISTVU BLIŽNJICE. |
ALI IMA KATERI FOTOAPARAT MOŽNOST DO OMENJENIH FUNKCIJ DOSTOPATI S KAŠNIM DALJINSKIM UPRAVLJALNIKOM ALI Z NEKIM ŽIČNIM PROTOKOLOM (USB,...)
POTEM SE NAREDI VMESNIK Z GUMBI, KI JIH @ELSAK NAJBOLJ POTREBUJE.
LP, Igor |
elsak Član
Objavljeno: Ned Dec 23, 2012 12:59 am Naslov sporočila: |
NIKONA LAHKO UPRAVLJAŠ PREKO DALJINCA, SAMO JE KAR DRAG APARAT. NE VEM A JE D700 AL D800. PA MOGOČE BI SE NAŠEL TUDI KAKŠEN CANON, ZA OSTALE FIRME PA NE VEM. DANES JE TAKO TEHNOLOGIJA NAPREDNA, DA SE LAHKO UPRAVLJA MARSIKAJ IN MARSIKJE.
elsak Član
Objavljeno: Ned Dec 23, 2012 1:23 am Naslov sporočila: |
KAR SE TIČE BLJIŽNIC, JIH PODPIRAJO TUDI CENEJŠI RAZRED FOTOAPARATOV. JAZ SEM VEČINOMA GLEDAL NIKONE, KER NISO TAKE CENE, KAR JE BOLJ ZA AMATERJE, NEPROFESIONALCE.
SamoR Član
Objavljeno: Ned Dec 23, 2012 1:51 am Naslov sporočila: |
AHA. POGLEJ NIKON Z DVEMA (D70, D90) IN TREMI ŠTEVILKAMI (D700, D800)...
SO PROFESIONALNI ALI POLPROFI. NO IZJEMA JE D7000, KI JE ZAMENJAVA ZA D90.
ZA AMATERSKO UPORABO SO D3100, D3200, D5100. NAČELOMA IMAJO VSI OPCIJSKO
DALJINSKI SPROŽILEC. TILE ZADNJI SO VEČKRAT V KAKŠNI AKCIJI Z DVEMA OBJEKTIVOMA TAM DO 500 - 600 €. NEKATERI MODELI IMAJO TUDI DVA ALI TRI GUMBE , KI JIM LAHKO DOLOČIŠ FUNKCIJO.
NA TVOJE VPRAŠANJE O AUTO-FOCUSU IN ISO NASTAVITVAH, JE NAJBOLJE, DA PRI TVOJEM [slovenščina je zame španska vas], PUSTIŠ NA AVTOMATIKI. TUDI NASTAVITEV BELINE PREPUSTI AVTOMATIKI. TUDI CANON 600 JE NEKJE V TEM RANGU IN ZNA BITI OD ČASA DO ČASA V AKCIJI. BI BILO PA DOBRO, DA STOPIŠ DO KAKŠNEGA ZNANCA, KI SE BAVI S FOTOGRAFIJO IN MU ZAUPAŠ TVOJE ŽELJE IN ZAHTEVE, JASNO MU MORAŠ ZAUPATI, IN SE SKUPAJ ODPRAVITA DO LOKALNEGA PRODAJALCA FOTOAPARATOV, V TVOJIH KRAJIH JE TUDI TALE KLUB http://www.foto-koroska.net/ IN JIH POVPRAŠAŠ PO PRIMERNEM FOTOAPARATU.
ro-bi Član
Pridružen-a: Ned 28 Jan 2007 16:53 Prispevkov: 3580 Aktiv.: 15.94
Objavljeno: Ned Dec 23, 2012 11:51 am Naslov sporočila: |
MAKRO PRVO SPROBAJ SLIKAT NA SPOSOJENEM APARATU, DA BOŠ VIDEL, KAKO TO GRE IN DA BOŠ VIDEL, KAKI BODO REZULTATI. NAMREČ DVOMIM, DA BI Z VIDOM, KOT GA OPISUJEČ, SPLOH IMEL KAKO SLIKO OSTRO. DOF JE TAKO MANJHEN, DA Z AVTOFOKUSOM NE NAREDIŠ NIČ. SE MALO POZIBAŠ NAPREJ NAZAJ IN JE VSE MEGLENO.
SAMO OPOZARJAM, DA NE BOŠ PO NEPOTREBNEM TROŠIL ZA MAKRO OBJEKTIV, KI JE ČISTO SPECIFIČNO UPORABEN.
SVETUJEM BOLJ ŠIROKOKOTNE, POGLEJ PA KAK NIKON V1 IN PODOBNE, KI IMAJO OGROMNE ZASLONE.
_________________ 3 x 3 = 9 |
elsak Član
Objavljeno: Pon Dec 24, 2012 12:04 am Naslov sporočila: |
NISEM VEDEL, DA OBSTAJA PRI NAS KAK KLUB. NE POZNAM KOGA, DA BI LAHKO SPROBAL. SEM ŠEL V FOTOATELJE IN MALO POGLEDAL. ČE BI PA HOTEL RESNO, BI PA RES MORAL NEKOGA DOBIT, DA NAREDIM TEST IN GLEDE FUNKCIJ.
ČE BI TEGA VZEL NIKON D320.
A SI TI RO-BI IZ ČRNE?
NE, ČE BI SE ODLOČIL ZA MAKRO, BI SEVEDA PREJ POIZKUSU, KER NE VEM KAKO JE KAJ ZAHTEVNO Z NJIM DELAT. PA SEVEDA, ČE BI JAZ LAHKO SLIKU, KOT SI REKEL. GREM POGLEDAT ZA TA DSLR. KOLK PA SO NAJVEČJI ZASLONI?
SamoR Član
Objavljeno: Pon Dec 24, 2012 1:14 am Naslov sporočila: |
HMMM... NIKON 1 V1 NI RAVNO CENOVNEM RANGU PA TUDI ZASLONA NIMA RAVNO OGROMNEGA 3"(TRI COLE). TEŽKO TI BO KAJ SVETOVATI. NAJBOLJE BO DA GREŠ Z NEKOM DO TRGOVINE IN SI OGLEDAŠ. TAKO NA PAMET LAHKO PAMETUJEMO KOLIKOR HOČEMO. MORAŠ PREIZKUSIT IN PIKA. ČE SI LAHKO BOLJ NATANČEN S KRAJEM BIVANJA, TI LAHKO POIŠČEM NAJBLJIŽJO TRGOVINO.
elsak Član
Objavljeno: Pon Dec 24, 2012 4:28 am Naslov sporočila: |
KAR SE TAKIH STVARI TIČE, MAMO PRI NAS SAMO, BIGBANG, COMSHOP IN MERKUR. V BIGBANGU ŠE NISEM BIL, KER JE SEDAJ NA NOVO ODPRT, COMSHOP IMA ENEGA ALI DVA MODELA. TO BI MORAL IT V SPECIALIZIRANO TRGOVINO, KJER LAHKO VSE SPROBAL.
PREVEČ NE BOM KOMPLICIRU.
MOGOČE VEŠ, KOLKO SO NAJVEČJI ZASLONI?
upor_nik Član
Objavljeno: Pon Dec 24, 2012 10:15 pm Naslov sporočila: |
POZDRAV, ..
TI BOM OPISAL ŠTORIJO Z MOJIM FOTOAPARATOM. KUPIL SEM GA ZA DENARNO NAGRADO OB 20. LETNICI DELA. TAKRAT ŠE V TOLARJIH, PRERAČUNANO DANES NEKJE 400€. SICER ZADOVOLJEN, KOT VSAK S SVOJIM PRVIM FOTOAPARATOM, ČEPRAV JE BIL TA OH IN SPLOH DIGITALNI. SUPER FOTKE, ZOOM 8X PLUS 5X DIGITALNI, PA KAJ BI ČLOVEK VEČ. IN KAJ BI MANJ? JA, DA NE BI PIL TOLIKO BATERIJ! HUDO POŽREŠNA STVAR! NAJVEČKRAT, KO SEM GA NUJNO RABIL, JE BIL SPOSOBEN NAREDITI NEKAJ POSNETKOV, NATO SO BILE BATERIJE FUČ.
SIN JE V DEVETEM LETNIKU OŠ ŠEL V LONDON. JA, APARAT PA Z NJIM. NAMESTO DA BI GA IMEL PRI SEBI, JE BIL V PRTLJAGI. REZULTAT - POČEN - UNIČEN LCD.
DALO SE JE ŠE SLIKATI PREK OKULARJA, VENDAR PREDOGLED NI BIL VEČ MOGOČ. TOREJ POČASI MI JE VSE PRESEDALO, REZULTATI SO ZNANI, ..
ČE SI GA KDO ŽELI ZA NOVOLETNO DARILO, MU GA POŠLJEM. PA ŠE POŠTNINO ČASTIM. AJA, ORIGINALNO SEM DOBIL ZDRAVEN SD KARTICO S 16MB, KAR JE ZADOŠČALO ZA 4-5 POSNETKOV V NAJVIŠJI KAKOVOSTI.
LP, ..
5ER
382.1 KB |
1 krat |
317.33 KB |
1 krat |
elsak Član
Objavljeno: Pon Dec 24, 2012 10:57 pm Naslov sporočila: |
RES KATASTROFA. A SE NE DA ZAMENJAT LCD? KA JE TO ZA ENA FIRMA? A IZ MOJGA SE NE BI DALO MENJAT, SEVEDA ČE SO ISTE MERE
MOJ SIN PA NIMA VOLE DO FOTOGRAFIRANJA. SEM MU REKEL, DA MU DAM TEGA MOJGA FUJI, PA NOČE. ČE NE, BOM PA PRIHRANU, ČE GA BO KDAJ ZANIMAL IN GA BO LAHKO IMEL.
Uptime: 11 dni
