Vlado Član
Pridružen-a: Sre 03 Mar 2004 21:35 Prispevkov: 563 Aktiv.: 2.28 Kraj: Ljubljana
Objavljeno: Pon Avg 13, 2012 6:52 pm Naslov sporočila: |
Denis,
obstaja še bolj enostavna rešitev,
v Helpu poglej ukaz OVERLAY.
LP |
tezo Član
Pridružen-a: Sob 19 Sep 2009 10:44 Prispevkov: 40 Aktiv.: 0.20 Kraj: Zgornji brnik
Objavljeno: Sob Okt 13, 2012 10:05 am Naslov sporočila: I2c slave |
Lep pozdrav!
Izdelujem QuadCopter z Atmega8, pa se je zataknilo pri hitrosti, Namreč če hočem vse narediti z enim mikrokontrolerjem, je stvar zelo počasna. Zato sem se odločil da PWM servo signal generiram z še eno Atmega8, ki bo uporabljal BASCOM slave TWI knjižnico za prejemanje podatkov preko I2C.
MASTER koda
| Koda: |
$lib "i2c_twi.lbx" ' we do not use software emulated I2C but the TWI
Config Scl = Portc.5 ' we need to provide the SCL pin name
Config Sda = Portc.4 ' we need to provide the SDA pin name
I2cinit ' we need to set the pins in the proper state
Config Twi = 100000 'clock speed
Do
Pulsein Motor1 , Pinb , 1 , 1 ' Na portb prejema PWM vrednosti
Pulsein Motor2 , Pinb , 2 , 1
Pulsein Motor3 , Pinb , 3 , 1
Pulsein Motor4 , Pinb , 4 , 1
'in jih nato pošlje po I2c
I2cstart
I2cwbyte &H70 ' Slave address
I2cwbyte Motor1
I2cwbyte Motor2
I2cwbyte Motor3
I2cwbyte Motor4
I2cstop
Loop
SLAVE koda
| Koda: |
Config Twislave = &H70 , Btr = 1 , Bitrate = 100000 'Slave Address, clock speed
Const Timer2reload = 156 'Timer, ki vsakih 20ms Generira pulz za PWM servo signal
Config Timer2 = Timer , Prescale = 1024
Load Timer2 , Timer2reload
On Ovf2 Timer2_isr
Enable Ovf2
Start Timer2
Enable Interrupts
Do
Loop
Timer2_isr: 'Generira PWM servo signal
Portb.1 = 1
For I = 0 To Motor1
Waitus 10
Next
Portb.1 = 0
Portb.2 = 1
For I = 0 To Motor2
Waitus 10
Next
Portb.2 = 0
Portb.3 = 1
For I = 0 To Motor3
Waitus 10
Next
Portb.3 = 0
Portb.4 = 1
For I = 0 To Motor4
Waitus 10
Next
Portb.4 = 0
Return
Twi_stop_rstart_received:
Return
Twi_addressed_goread:
Return
Twi_addressed_gowrite:
Return
Twi_gotdata:
Select Case Twi_btw
Case 1 : Motor1 = Twi - 40 ' Spremenljivke napolni z vrednosti, ki jih prejme po i2c
Case 2 : Motor2 = Twi - 40
Case 3 : Motor3 = Twi - 40
Case 4 : Motor4 = Twi - 40
End Select
Print Motor1 'In jih pošlje po uart
Print Motor2
Print Motor3
Print Motor4
Return
Twi_master_needs_byte:
Return
Twi_master_need_nomore_byte:
Return
Problem pa je da zato da preko i2c prenese 4byte za motorje porabi "na uč" 50ms.
Je to normalno? Ali ni i2c hitrost nekaj Mbytov/s ? |
tezo Član
Objavljeno: Sob Okt 13, 2012 9:44 pm Naslov sporočila: |
Sem ugotovil , da je master ustavljen dokler program v SLAVEu ne doseže ukaza return, tako da sem izbrisal vrstice print in je sedaj vse veliko hitreje. Bom verjetno še branje iz sprejemnika prestavil na slave čip, da se glavni nebo matral z branjem PWMja.
LP |
zok Član
Pridružen-a: Pet 02 Jan 2009 23:59 Prispevkov: 1115 Aktiv.: 5.30 Kraj: Ponikva
Objavljeno: Pon Okt 15, 2012 10:00 am Naslov sporočila: |
za PWM poskusi raje tole:
| Koda: |
$regfile = "m8def.dat"
$prog &HFF , &HE1 , &HD9 , &H00
Config Servos = 2 , Servo1 = Portc.1 , Servo2 = Portc.2 , Reload = 10 'konfiguriras servota
Config Portc.1 = Output
Config Portc.2 = Output
Enable Interrupts
Servo(1) = 10 '10 times 10 = 100 uS on
Servo(2) = 10
dim podatek1 as word 'za primer sem dolocil dve spremenljivki
dim podatek2 as word
podatek1 = 25 'spremenljivkama sem dolocil dve vrednosti (samo za primer, da ve kam postaviti servota ob inicializaciji)
podatek2= 135
do 'malo bomo ponavljali
'tu vmes pride vsa logika - skaliranje, mix komand, itd
'za prvi preizkus pa sem zaenkrat napisal samo naslednji sestavek:
incr podatek1 'premakni servo za en delcek
incr podatek2
if podatek1=210 then 'ce servo pride do skrajne tocke (vsaj pri mojih servotih je 210 ena skrajna tocka)
podatek1 = 25 'ga postavi v drugo skrajno tocko
endif
if podatek2=210 then
podatek2 = 25
endif
Servo(1) = podatek1 'vrednost posljes na servo, in ti ni potrebno uporabljati waitus komand - tako program tece naprej, PWM pa se izvaja v ozadju
Servo(2) = podatek2
Loop |
upam da pomaga. Tako lahko uporabis samo en mikrokontroler in prihranis na kompleksnosti, na masi in ceni.
edit: ah se nekaj:
LP!
| Koda: |
'Servo's need a pulse in order to operate
'with the config statement CONFIG SERVOS we can specify how many servo's we
'will use and which port pins are used
'A maximum of 16 servos might be used
'The SERVO statements use one byte for an interrupt counter and the TIMER0
'This means that you can not use TIMER0 anymore
'The reload value specifies the interval of the timer in uS
'we use 2 servos with 10 uS resolution(steps) |
tezo Član
Objavljeno: Tor Okt 30, 2012 3:57 pm Naslov sporočila: |
Sem ugotovil, da je branje vhodov z pulsein tudi prepočasno. Mogoče kdo ve kako brati PWM vhode na hitrejši način?
MOJ POIZKUS:
Naročil sem atmego88 ki ima "pin change interrupte", In naredil program da vsakič ko se pojavi pulz, se sproži interrupt. V interruptu sprožim timer0 , in ob koncu pulza spet sproži interrupt v katerem preberem vrednost timerja in spremenim PCMSK (da bo interrupt zaznaval na naslednjem pinu). To lepo bere pwm če se spreminja le en pwm naenkrat, ostali pa imajo sredinsko vrednost. Če vrednosti večih PWM vhodov spreminjam hkrati , začnejo vplivati eden na drugega, in vse prebrane vrednosti so čudne. Že 3 dni iščem napako, ampak se vse zdi vredu.
| Koda: |
On Pcint2 Isr_pcint0
Pcmsk2.6 = 1 'določim na katerem pinu bo prvič PCINT
Enable Pcint2
Config Timer0 = Timer , Prescale = 64
Enable Interrupts
Do
Waitms 100
Print In3
Loop
Isr_pcint0:
If Pind.t = 1 Then 'preveri če je interrupt sprožen na prednjem ali zadnjem robu pulza
Goto Naprej 'če je na prdnjem, potem samo resetira timer0 in se vrne
End If
'Če je na zadnjem robu, potem gre naprej v program za branje vrednosti timerja
Select Case T
Case 4 : In1 = Timer0 'izbere pravo spremenljivko in jo napolni z vrednsostjo timerja
Case 5 : In2 = Timer0
Case 6 : In3 = Timer0
Case 7 : In4 = Timer0
End Select
T = T + 1 'spremenljivko t vsakič poveča za 1
If T > 7 Then
T = 4
End If
Pcmsk2 = 0 'spremenljivka t določi na katerem pinu bomo čakali pulz
Pcmsk2.t = 1
Naprej: 'resetiranje timerja
Timer0 = 0
Return |
Če nebo šlo drugače bi lahko na pwm vhode dal rc filter, in bral vrednosti z ADC, samo nevem kakšna bi bila natančnost. |
linel Član
Pridružen-a: Čet 06 Mar 2008 21:14 Prispevkov: 178 Aktiv.: 0.81 Kraj: prekmurje
Objavljeno: Sre Feb 27, 2013 9:56 pm Naslov sporočila: Programiranje v bascom avr |
Rad bi povezal mikrokontrolerja med sabo, in sicer tako da bi na uc1 (oddajni) pritisnil tipko 1 za vklop oz. 2 za izklop led diode. led dioda bi pa bila na uc2 (sprejemni).
Komunikacija z terminalom deluje, ko pritisnem tipko 1 pošlje na terminal znak A ko pa tipko 2 pa znak B.
Tudi ko iz terminala pošiljam znak A se vključi led dioda, če pa kaj ostalega se pa izključi.
Tx povežem z RX. prilagam programa. zanima me pa kaj je narobe.
| Koda: |
oddajni mikrokontroler
$baud = 4800
$hwstack = 32
$swstack = 8
$framesize = 24
Config Portb.0 = Input
Config Portb.1 = Input
Config Portb.2 = Output
Dim A As String * 1
Dim B As String * 1
A = Chr(65)
B = Chr(66)
Do
If Pinb.0 = 1 Then
Waitms 150
Print A
Set Portb.2
End If
If Pinb.1 = 1 Then
Waitms 150
Print B
Reset Portb.2
End If
Loop
| Koda: |
sprejemni mikrokontroler
$baud = 4800
$hwstack = 32
$swstack = 8
$framesize = 24
Config Portd = Output
Dim A As String * 1
Do
A = Waitkey()
If A = "{065}" Then
Set Portd.7
Else
Reset Portd.7
End If
Loop
protoncek Član
Pridružen-a: Sre 31 Jan 2007 9:41 Prispevkov: 9573 Aktiv.: 40.92 Kraj: Mengeš
Objavljeno: Sre Feb 27, 2013 10:20 pm Naslov sporočila: |
IF stavek v sprejemnem delu. Ti imaš narejeno če je sprejem 65 potem vklopi portd.7, sicer ga izklopi. Torej karkoli drugega dobi RAZEN 65 ga izklopi. Imeti moraš na način:
If A = "{065}" Then Set Portd.7
If A = "{066}" Then Reset Portd.7
loop
Tako bo 65 vklopil, 66 izklopil, ostalo pa ignorira. |
linel Član
Objavljeno: Sre Feb 27, 2013 10:37 pm Naslov sporočila: Programiranje v bascom avr |
| saj to glih hočem, zato sem dal vse kar nebo 65 izklopi led. ( tipka dva je 66 (ker ni 65 izkopi led)), mislim da je drugje nekaj narobe |
protoncek Član
Objavljeno: Sre Feb 27, 2013 11:28 pm Naslov sporočila: |
| hm...potem pa ne razumem, kaj je narobe, oziroma, kaj dela, kar ne bi smelo? |
Cule Član
Pridružen-a: Sob 28 Maj 2011 14:50 Prispevkov: 114 Aktiv.: 0.63 Kraj: Šentjur
Objavljeno: Pon Mar 04, 2013 10:29 pm Naslov sporočila: |
Imam težavo v Bascomu.
| Koda: |
Dim Os_x As Dword
Dim Kot_x As Dword
Dim Ux_skal As Dword
Dim Adc_x As Dword
Dim Ux As Dword
Dim X_vred As Single
Dim X As Single
Adc_x = Getadc(4)
Adc_y = Getadc(3)
Adc_z = Getadc(2)
Ux_skal = Adc_x * 1000
Ux = Ux_skal / 1023
Ux = Ux * 500
Kot_x = Ux - 165000
X_vred = Kot_x / 80000
X_vred = Kot_x : X = Asin(x_vred)
X = Deg2rad(x) |
To je le del programa, program deluje, težava pa je v vrstici: " X_vred = Kot_x / 80000" , saj nevem kako naj definiram spremenljivko X_vred.
Spremenljivka Ux ima lahko vrednost med 165000 pa 245000, torej bo X_vred med 0 in 1.
Iz teh vrednosti bom izračunal asin (v radijanih) in jih spremenil v stopinje in s tem dobil kot med 0 in 90°
Torej kako naj spremenim program, da bo delovalo pribljižno tako kot je napisano zgoraj. |
davyd1994 Član
Pridružen-a: Sob 17 Okt 2009 21:26 Prispevkov: 53 Aktiv.: 0.26 Kraj: Šentjur pri Celju-Ponikva
Objavljeno: Sob Mar 09, 2013 5:58 pm Naslov sporočila: |
Imam eno tažavo. Na mikrokrmilnik bi moral naložiti iz Bascoma program ki je za demo prevelik. Dobil sem neko starejšo krekano različico, ampak ta različica mi pa noče naložiti oz. neka napaka pri povezavi. Čip je ATmega32, nalagam preko ISP, s programatorjem pololu AVR ISP. _________________ Ko misliš da ne zmoreš več pa mal pospeši.
Lp. David |
mucek Član
Pridružen-a: Tor 01 Avg 2006 10:47 Prispevkov: 5625 Aktiv.: 23.43 Kraj: Domzale
Objavljeno: Sob Mar 09, 2013 6:11 pm Naslov sporočila: |
a) Kupiš licenco za program (ki je, mimogrede, res presneto poceni glede na lifetime support)
b) Pošlješ komu, ki licenco ima, pa ti skompajla. To narediš, če res programiraš 1x na leto.
LP, g
(p.s. Za B opcijo lahko pošlješ tudi meni  _________________ ...lahko pa se tudi motim ... |
program_er Član
Pridružen-a: Sob 08 Mar 2008 13:47 Prispevkov: 2173 Aktiv.: 9.85 Kraj: Maribor (Pohorje)
Objavljeno: Sob Mar 09, 2013 11:17 pm Naslov sporočila: |
| davyd1994 je napisal/a: |
| Imam eno tažavo. Na mikrokrmilnik bi moral naložiti iz Bascoma program ki je za demo prevelik. Dobil sem neko starejšo krekano različico, ampak ta različica mi pa noče naložiti oz. neka napaka pri povezavi. Čip je ATmega32, nalagam preko ISP, s programatorjem pololu AVR ISP. |
Pošlji mi .bas kodo (v .zip pod ZS) in ti jo brez problema scompilam z najnovejšo verzijo Bascoma (imam kupljeno licenco) ter pošljem nazaj.
Pa tudi če boš rabil kdaj kaj za urediti, ni problem ta minuta dela. Če pa hočeš dejansko programirati, pa je res najbolje kupiti licenco.
EDIT: Pravkar videl, da se je že mucek ponudil za compilat. |
program_er Član
Objavljeno: Sob Mar 09, 2013 11:24 pm Naslov sporočila: |
| Cule je napisal/a: |
Kaj točno pa ne dela? Ti javi error (kakšen), ti narobe računa? |
Cule Član
Objavljeno: Ned Mar 10, 2013 9:19 am Naslov sporočila: |
| program_er je napisal/a: |
Je že v redu. Sem popravil. Narobe sem definiral spremenljivke pa mi je javljalo napako. |
Uptime: 233 dni
