Inicializacija LCD displaya
denis18
Pridružen-a: Pet 24 Maj 2013 16:26
Prispevkov: 6
Aktiv.: 0.04
Kraj: Celje
PrispevekObjavljeno: Pet Maj 24, 2013 5:12 pm    Naslov sporočila:  Inicializacija LCD displaya Odgovori s citatom
Zdravo!
Napisal sem program, ki inicializira display in izpiše nekaj črk, vendar ne deluje.
Kontrast na LCD je vredu. Uporabljam pa LCD DEM 16212 SYH-LY ver.2 in Atmega32. Prosim, če mi lahko poveste kaj je narobe.
To je pa koda:
Koda:
//Zaglavje
#define F_CPU 4000000UL
#include <avr/io.h>
#include <util/delay.h>
#define   LCD_DATAP    PORTA            //Podatkovni pini
#define LCD_DATAD   DDRA            //Registri za podatkovne pine
#define LCD_CTRLP   PORTB            //Kontrolni pini
#define LCD_CTRLD   DDRB            //Registri za kontrolne pine
#define   RS         0               //RS---1->podatki---0->komande
#define   RW         1               //RW--read->1---write->0
#define E         2                 //E, ko pošiljamo->1, za procesiranje->0
#define LCD_CLR            0x01
#define LCD_HOME         0x03
#define LCD_ENTRY_MODE      0x06
#define LCD_ON            0x0C
#define LCD_OFF            0x08
#define LCD_FUNCTION_SET   0x38
void Lcd_Init(void);               //Inicializacija LCD
void Check_Busy(void);               //Preveri, če je LCD zaseden
void Enable_On_Off(void);            //postavi E na 1, nato pa nazaj  na 0
void Send_A_Command(unsigned char command);      //Pošlje komando
void Send_A_Character(unsigned char character);   //Pošlje črko
//Začetek glavne zanke
void main(void){
   Lcd_Init();
   Send_A_Character(0x44);  //Črka "D"
   Send_A_Character(0x65);  //Črka "e"
   Send_A_Character(0x6E);  //Črka "n"
   Send_A_Character(0x69);  //Črka "i"
   Send_A_Character(0x73);  //Črka "s"
void Lcd_Init(void){
   LCD_CTRLP = 0x00;               //Pini so low=0V
   LCD_CTRLD |= 1<<RS | 1<<RW | 1<<E;   //Pini so izhodi
   LCD_DATAP = 0x00;               //Pini so low = 0V
   LCD_DATAD = 0xFF;               //Pini so izhodi
   _delay_ms(60);
   Send_A_Command(0x38);   //FUNCTION SET-->2-line, 5x7 dots
   _delay_us(80);
   Send_A_Command(0x0E);   //DISP. ON/OFF CONTROL-->disp. on, cursor on, blink off
   _delay_us(80);
   Send_A_Command(0x01);   //DISPLAY CLEAR
   _delay_ms(3);
   Send_A_Command(0x06);   //ENTRY MODE SET-->increment right, shift off
void Check_Busy(void){
   LCD_CTRLD = 0;
   LCD_CTRLP |= 1<<RW;
   LCD_CTRLP &= ~1<<RS;
   LCD_CTRLP |= 1<<E;
   while(LCD_DATAP >= 0x80){//0b10000000--0x80
      Enable_On_Off();
   LCD_CTRLD = 0xFF; //0b11111111
void Enable_On_Off(){
   LCD_CTRLP |= 1<<E;
   asm volatile ("nop");
   LCD_CTRLP &= ~1<<E;
void Send_A_Command(unsigned char command){
   Check_Busy();
   LCD_DATAP = command;
   LCD_CTRLP &= ~( 1<<RW | 1<<RS );
   Enable_On_Off();
   LCD_DATAP = 0;
void Send_A_Character(unsigned char character){
   Check_Busy();
   LCD_DATAP = character;
   LCD_CTRLP &= ~( 1<<RW );
   LCD_CTRLP |= 1<<RS;
   Enable_On_Off();
   LCD_DATAP = 0;
matjazkariz
Pridružen-a: Sre 03 Nov 2004 18:09
Prispevkov: 1026
Aktiv.: 4.33
PrispevekObjavljeno: Pet Maj 24, 2013 5:24 pm    Naslov sporočila:   Odgovori s citatom
Poskusi najprej z drugim displayem. Mislim drugim modelom. Namreč ta tvoj ima nek kontroler, ki naj bi bil HD44780 kompatibilen, vendar se ponavadi izkaže, da je v detajlih hudič.
Preberi tudi datasheet LCDja in preveri, če se tvoja inicializacija pokriva z zahtevami za ta display.
Kaj se ti prikaže na ekranu? V prvi vrsti kvadratki?
LP, Matjaž
denis18
Prispevkov: 6
Aktiv.: 0.04
Kraj: Celje
PrispevekObjavljeno: Pet Maj 24, 2013 7:02 pm    Naslov sporočila:   Odgovori s citatom
Drugega LCDja trenutno nimam.
Inicializacijo sem naredil tako, kot piše v datasheetu, tako da bi mogla biti pravilna.
Če preizkusim simulacijo v Proteusu, mi pokaže na prvem mestu na LCD črtico(-), če pa na ploščici pa imam črne kvadratke.
int47
Prispevkov: 2104
Aktiv.: 8.88
PrispevekObjavljeno: Pet Maj 24, 2013 7:55 pm    Naslov sporočila:  Re: Inicializacija LCD displaya Odgovori s citatom
denis18 je napisal/a:
Koda:
Si nastavil smer v DDRx in začetne vrednosti PORTx ?
Edit:
Moja napaka, sem iskal DDRB, namesto LCD_CTRLD.
Imaš vključeno optimizacijo ? Brez tega delay.h ne deluje prav.
matjazkariz
Prispevkov: 1026
Aktiv.: 4.33
PrispevekObjavljeno: Pet Maj 24, 2013 8:10 pm    Naslov sporočila:   Odgovori s citatom
Če imaš na LCDju črne kvadratke, pomeni, da nisi pravilno izvedel inicializacije LCDja. Poskusi se poigrati s timingi. Navadno, če časovna baza ni dobra, zna delovanje nagajati. Seveda, kot je že int47 namignil, tudi preveri, da imaš vse I/O pravilno priklopljene in skonfigurirane.
LP, Matjaž
denis18
Prispevkov: 6
Aktiv.: 0.04
Kraj: Celje
PrispevekObjavljeno: Pet Maj 24, 2013 8:11 pm    Naslov sporočila:   Odgovori s citatom
@int47:Kakšno optimizacijo misliš?
@matjazkariz: S timingi sem že poizkušal, vendar brez uspeha. Bom preveril še vse enkrat.
matjazkariz
Prispevkov: 1026
Aktiv.: 4.33
PrispevekObjavljeno: Pet Maj 24, 2013 8:21 pm    Naslov sporočila:   Odgovori s citatom
Če uporabljaš AVRStudio, imaš pod Project -> Configuration Options -> zavihek General opcijo (drop down lista) za nastavitev optimizacije. Na podlagi te nastavitve prevajalnik različno intenzivno optimira končno sliko programa. Tako se navadno zgodi, da umetno narejene zakasnitve razpozna kot odvečno kodo in jih v procesu optimizacije izloči.
LP, Matjaž
int47
Prispevkov: 2104
Aktiv.: 8.88
PrispevekObjavljeno: Pet Maj 24, 2013 8:23 pm    Naslov sporočila:   Odgovori s citatom
Če uporabljaš AVR Studio z WinAvr, so nastavitve v Project -> Configuration Options. "Optimization" nastavi na karkoli razen "-O0".
denis18
Prispevkov: 6
Aktiv.: 0.04
Kraj: Celje
PrispevekObjavljeno: Pet Maj 24, 2013 8:27 pm    Naslov sporočila:   Odgovori s citatom
Optimizacija je nastavljena na -Os.
denis18
Prispevkov: 6
Aktiv.: 0.04
Kraj: Celje
PrispevekObjavljeno: Ned Jun 02, 2013 12:42 pm    Naslov sporočila:   Odgovori s citatom
Še ima kdo kakšno idejo, kaj bi bilo narobe, ker jaz res ne vem kaj bi lahko bilo?
HeBird
Pridružen-a: Ned 16 Avg 2009 16:36
Prispevkov: 79
Aktiv.: 0.41
Kraj: Domžale
PrispevekObjavljeno: Pon Jun 03, 2013 12:20 pm    Naslov sporočila:   Odgovori s citatom
Jaz sem imel hude težave z LCD na začetku, dokler mi ni kolega pokazal, da sem potenciometer narobe vezal. V vrsticah sem imel črne kvadratke, kontrast je pa sicer delal.
Tako da, preveri, če imaš E, RS, maso in napajanje pravilno s potenciometrom povezano.
Gašper
S53DZ
Prispevkov: 951
Aktiv.: 5.53
PrispevekObjavljeno: Pon Jun 03, 2013 3:22 pm    Naslov sporočila:   Odgovori s citatom
Pravijo, da je pri LCD-jih dobra praksa inicializacije tale:
1. po pwr restartu čakati vsaj 100ms, da napajanje naraste nad 4,5V (če je LCD za 5V)
2. 3 x ponoviti vpis 0x30 z zakasnitvijo 15us med njimi in brez čekiranja busy bita!
3. vpisati 0x38 (8bit) ali 0x28 (4bit data)
4. nato pa 0x08 (display off), 0x01 (clr), 0x06 (incr.add.) in na primer 0x0c (display on)
EDIT: Meni se tako zaporedje izide za 3V in 5V LCD-je.
je pa res, da so nekateri LCD-ji nezanesljivi in ni nujno, da tisti najcenejši.
Ponavadi so nezanesljivi zaradi pomanjkanja pravih datasheet-ov zanje.
RGorazd
Prispevkov: 1714
Aktiv.: 7.24
Kraj: Ig
PrispevekObjavljeno: Pon Jun 03, 2013 9:32 pm    Naslov sporočila:   Odgovori s citatom
Poglej si TALE tutorial, pa še naslednja dva v vrstici, ki se nanašata na LCD in ti bo precej bolj jasno. Osebno mislim, da so tole eni boljših tutorialov za začetnike. Lahko tudi pišeš avtorju, je izredno prijazen in ponavadi odgovori v roku 48 ur.
LP G
._. _ _ ._. _.__. _|
[ (_](_)[ (_] /_(_]
._|
tilz0R
Pridružen-a: Čet 31 Maj 2012 15:39
Prispevkov: 898
Aktiv.: 5.65
Kraj: Črnomelj
PrispevekObjavljeno: Pon Jun 03, 2013 9:38 pm    Naslov sporočila:   Odgovori s citatom
RGorazd je napisal/a:
LP G
Sej ta koda je iz tiste strani. Ampak deluje (preizkušeno) samo na 1MHz.
Knowledge sharing is caring.
majerle.eu | stm32f4-discovery.net
RGorazd
Prispevkov: 1714
Aktiv.: 7.24
Kraj: Ig
PrispevekObjavljeno: Tor Jun 04, 2013 8:09 pm    Naslov sporočila:   Odgovori s citatom
LCDji so precej počasna stvar. Z višanjem clock-a je potrebno ustrezno popraviti tudi vse delay-e, še posebej take, ki niso v stilu wait_ms(3); ampak so narejene v stilu for zanke.
Pa še to. Kje je del kode, ki alternira E signal?
Če rabiš tole za učenje, pol nadaljuj, če pa potrebuješ delujočo knjižnico za LCD - za AVRje pisano v Cju, me kontaktiraj pod , da ne smetim teme.
LP G
[ (_](_)[ (_] /_(_]
._|
