puscasvictor Član
Pridružen-a: Pet 17 Apr 2015 14:06 Prispevkov: 14 Aktiv.: 0.11 Kraj: TARGU-MURES ROMANIA
Objavljeno: Ned Apr 19, 2015 8:26 pm Naslov sporočila: Spajkalna postaja homemade |
Idea was taken from Cyfrowa stacja lutownicza,Kamil Szkutnik. Important should have controlled temperature and be powered by 24V not 230V.Soldering station controlled by Mikrocontroller ATMEGA8, zero phase detection crosing and MOC-3041.
Advantage low cost,program written in Bascom. Seting temperature there three buttons and temperature adjustment step is 10 celsius degrees(28-350)
The display enables viewing 2x16 marks.Important remember to press buttons UP and DOWN,at the same time to set 250 celsius degrees(after that with the soldering station is available)
Spoznal sem(zgradili smo)digitalno spajkalno postajo z ATMEGA8.Jaz sem zadovoljna z njo. Tam sem govoril slovenski jezik.
Iz spostovanja do vas, sem poskusil,kako lahko.Navdihnil me je kolega poljski.Ne vem,kako dobro ona prevod.Trudim se in anglescina
Roeka 24v/48W.Senzor za temperatero se nahaja v roeki.Semzorji za toploto tip K.
Temperatura nastavljena=temperature spodaj izmerjeni+/- 9 degree celsius
puscasvictor Član
Objavljeno: Ned Apr 19, 2015 8:42 pm Naslov sporočila: |
MadMax Član
Pridružen-a: Pet 09 Sep 2005 22:16 Prispevkov: 4743 Aktiv.: 19.97
Objavljeno: Ned Apr 19, 2015 8:47 pm Naslov sporočila: |
It's better that you write in English, we will probably understand more than GoogleTranslated text
Except if you want to learn Slovenian?
puscasvictor Član
Objavljeno: Ned Apr 19, 2015 8:49 pm Naslov sporočila: Spajkalna postaja homemade |
puscasvictor Član
Objavljeno: Ned Apr 19, 2015 9:05 pm Naslov sporočila: |
Excuse me,MadMax.
Zelim izvedeti slovasko(SLOVENA)
I am sorry. Sledi in drugi dodatki, PROGRAM BASCOM, HEX...
MadMax Član
Objavljeno: Ned Apr 19, 2015 9:13 pm Naslov sporočila: |
I don't really understand... You want to learn "slovasko" (Slovakia, half of ex-Czechoslovakia) ?
Well, in that case I have to dissapoint you: this is slovenian forum, not slovakian...
Slovakia wiki (original Slovenská republika)
Slovenia wiki (original Republika Slovenija)
Sometimes dificult to know the difference...
Anyway, good job, excellent project you made!
puscasvictor Član
Objavljeno: Ned Apr 19, 2015 9:58 pm Naslov sporočila: Spajkalna postaja homemade |
puscasvictor Član
Objavljeno: Ned Apr 19, 2015 10:19 pm Naslov sporočila: Spajkalna postaja homemade |
puscasvictor Član
Objavljeno: Ned Apr 19, 2015 10:39 pm Naslov sporočila: Spajkalna postaja homemade |
V samo roeko je vgrajen termoelement K.Roeka ima 5 pin speljanih do postaje.V dveh je napajanje 24V, v dveh signal za temperaturo v peti pa je ozemljitev-PENSOL SOLOMON 24V/48w.
P=UXI=48W=24VxI
I=2A current
puscasvictor Član
Objavljeno: Ned Apr 19, 2015 11:18 pm Naslov sporočila: Spajkalna postaja homemade |
SLOVENIJA(LIUBLIANA) je lepa dezela zlepimi ljudmi in delaven.
kose19 Član
Pridružen-a: Sre 02 Mar 2005 19:37 Prispevkov: 1228 Aktiv.: 5.17 Kraj: okolica Kobarida
Objavljeno: Ned Apr 19, 2015 11:19 pm Naslov sporočila: |
Welcome to forum Victor.
I'm intresting to this project. I have plan to do this for two years, but not started yet.
_________________ - Absens, carens -
- Tisti, ki ga ni, bo prikrajšan - |
puscasvictor Član
Objavljeno: Pon Apr 20, 2015 12:05 am Naslov sporočila: Spajkalna postaja homemade |
Konstruckje.....
puscasvictor Član
Objavljeno: Pon Apr 20, 2015 12:30 am Naslov sporočila: Spajkalna postaja homemade |
Kose19:
Thank you so much. Many thanks. Can I help You? Is there anything I can do for you?
I so novi.Zacetnik! Jaz zmorem tezko
puscasvictor Član
Objavljeno: Pon Apr 20, 2015 8:18 am Naslov sporočila: Spajkalna postaja homemade |
Slika je vredna tisoc besed....Faze..gradnje
puscasvictor Član
Objavljeno: Tor Apr 21, 2015 4:46 pm Naslov sporočila: Hex Bascom |
Hex Bascom
Ime datoteke: |
Statie de Lipit cu Atmega8.rar |
515.87 KB |
Downloadano: |
33 krat |
Ime datoteke: |
Kamil szkutnik.txt |
2.57 KB |
Downloadano: |
22 krat |
