označevanje diod
simygh
Pridružen-a: Ned 10 Maj 2015 16:53
Prispevkov: 10
Aktiv.: 0.08
PrispevekObjavljeno: Ned Maj 10, 2015 4:57 pm    Naslov sporočila: icon_idea označevanje diod Odgovori s citatom
Ali zna kdo razložiti označevanje diod? Razložiti moram naslednje primere:
1N4007
1N5603
BA 513
BY 602
Prispevkov: 3476
Aktiv.: 14.64
PrispevekObjavljeno: Ned Maj 10, 2015 6:05 pm    Naslov sporočila:   Odgovori s citatom
Prve dve sta po ameriškem JEDEC sistemu. 1N pomeni dioda.
Zadnji dve sta po Pro Electron sistemu.
B pomeni silicijev element. A je signalna dioda, Y usmerniška.
simygh
Prispevkov: 10
Aktiv.: 0.08
PrispevekObjavljeno: Ned Maj 10, 2015 6:21 pm    Naslov sporočila:   Odgovori s citatom
Hvala za odgovor.
Kaj pa pomenijo številke na koncu?
simygh
Prispevkov: 10
Aktiv.: 0.08
PrispevekObjavljeno: Ned Maj 10, 2015 6:24 pm    Naslov sporočila:   Odgovori s citatom
Serijske številke?
Slowfly
Prispevkov: 4082
Aktiv.: 17.18
Evo čitaj!
5.1 Diode identification
European diodes are marked using two or three letters and a number. The first letter is used to identify the material used in manufacturing the component (A - germanium, B - silicon), or, in case of letter Z, a Zener diode.
The second and third letters specify the type and usage of the diode. Some of the varities are:
A - low power diode, like the AA111, AA113, AA121, etc. - they are used in the detector of a radio receiver; BA124, BA125 : varicap diodes used instead of variable capacitors in receiving devices, oscillators, etc., BAY80, BAY93, etc. - switching diodes used in devices using logic circuits. BA157, BA158, etc. - these are switching diodes with short recovery time.
B - two capacitive (varicap) diodes in the same housing, like BB104, BB105, etc.
Y - regulation diodes, like BY240, BY243, BY244, etc. - these regulation diodes come in a plastic packaging and operate on a maximum current of 0.8A. If there is another Y, the diode is intended for higher current. For example, BYY44 is a diode whose absolute maximum current rating is 1A. When Y is the second letter in a Zener diode mark (ZY10, ZY30, etc.) it means it is intended for higher current.
G, G, PD - different tolerance marks for Zener diodes. Some of these are ZF12 (5% tolerance), ZG18 (10% tolerance), ZPD9.1 (5% tolerance).
The third letter is used to specify a property (high current, for example).
American markings begin with 1N followed by a number, 1N4001, for example (regulating diode), 1N4449 (switching diode), etc.
Japanese style is similar to American, the main difference is that instead of N there is S, 1S241 being one of them.
simygh
Prispevkov: 10
Aktiv.: 0.08
PrispevekObjavljeno: Ned Maj 10, 2015 6:29 pm    Naslov sporočila:   Odgovori s citatom
Hvala!
Zanima me še kaj dosežemo z vzporedno in kaj z zaporedno vezavo večjega števila diod?
Ne najdem nikjer na internetu.
Slowfly
Prispevkov: 4082
Aktiv.: 17.18
PrispevekObjavljeno: Ned Maj 10, 2015 6:38 pm    Naslov sporočila:   Odgovori s citatom
Ne najdeš nikjer na internetu! Bejž no!
Evo, da podprem tvojo lenobo. Je pa res, da to ni servirano na srebrnem pladnju kot si pričakoval. Malo se boš moral potruditi in prebrati. Mogoče pa se še kaj naučiš zraven. Čeprav v slednje močno dvomim. Tebe zanima smo to, kako dobiti pozitivno oceno s čim manj napora.
http://scp.s-scptuj.mb.edus.si/~murkos/Teorija%20in%20vaje/Elektronika/Elektronska%20vezja%20in%20elementi.pdf
simygh
Prispevkov: 10
Aktiv.: 0.08
PrispevekObjavljeno: Ned Maj 10, 2015 7:40 pm    Naslov sporočila:   Odgovori s citatom
Ja oprosti ker sprašujem. Zakaj pa so takšni forumi?
Nimam veliko časa zato pa vprašam tu.
Slowfly
Prispevkov: 4082
Aktiv.: 17.18
PrispevekObjavljeno: Ned Maj 10, 2015 9:08 pm    Naslov sporočila:   Odgovori s citatom
simygh je napisal/a:
Gotovo ne za tak namen kot ti misliš.
Aha, in kaj si počel do danes?
Uptime: 9 dni
