Tda1562q
jjedat
Pridružen-a: Ned 17 Avg 2014 13:57
Prispevkov: 104
Aktiv.: 0.78
Kraj: Vojnik
PrispevekObjavljeno: Sre Maj 27, 2015 5:51 pm    Naslov sporočila:  Tda1562q Odgovori s citatom
Pozdravljeni.
Izdelal sem tiskanino iz sledeče strani:http://320volt.com/tda1562q-ile-70watt-subwoofer-anfi-devresi/.Sedaj pa me zanima glede priključkov JP3 in sicer ali pride na priključka 3 in 4 led dioda,ki signalizira napako, priključek 1 in 2 pa moram skleniti ali kako?
ro-bi
Prispevkov: 3580
Aktiv.: 15.95
PrispevekObjavljeno: Sre Maj 27, 2015 5:58 pm    Naslov sporočila:   Odgovori s citatom
Mode select input (pin MODE)
This pin has 3 modes:
1. LOW for standby: the complete circuit is switched off,
the supply current is very low
2. MID for mute: the circuit is switched on, but the input
signal is suppressed
3. HIGH for on: normal operation, the input signal is
amplified by 26 dB.
3 x 3 = 9
Uptime: 7 dni
