erbi Član
Pridružen-a: Pon 24 Okt 2011 16:40 Prispevkov: 213 Aktiv.: 1.28 Kraj: Celje
Objavljeno: Ned Feb 14, 2016 11:09 am Naslov sporočila: LibreOffice vs. OpenOffice |
Zanima me, če je že kdo naredil primerjavi med LibreOffice in OpenOffice. Kakšne so razlike?
Sprašujem za XP varianto.... |
Highlag Član
Objavljeno: Ned Feb 14, 2016 2:35 pm Naslov sporočila: |
Razlika je, a ne zelo velika. Libre je rahlo izboljšan OpenOffice. Predvsem zato, ker je Open nekaj let stagniral. V bistvu se še vedno precej počasi obračajo. Pri Libre so očistili kodo starine in dodajajo nove funkcionalnosti, ki jo Open nima. _________________ If at first you don't succeed, destroy all evidence that you tried. |
Dorijan Član
Pridružen-a: Ned 22 Jun 2008 10:48 Prispevkov: 2564 Aktiv.: 12.36 Kraj: južnoprimorska
Objavljeno: Pon Feb 15, 2016 10:33 am Naslov sporočila: |
Težava je razlika v open source licencah kar omogoča libre office, da jemlje dele kode iz open offica obratno pa ni možno.
The Apache OpenOffice project uses the Apache License, while the LibreOffice uses a dual LGPLv3 / MPL license. The practical result is LibreOffice can take OpenOffice’s code and incorporate it into LibreOffice — the licenses are compatible.
On the other hand, LibreOffice has some features — like font embedding — that don’t appear in OpenOffice. This is because the two different licenses only allow a one-way transfer of code. LibreOffice can incorporate OpenOffice’s code, but OpenOffice can’t incorporate LibreOffice’s code. This is the result of the different licenses the projects chose.
In the long run, this means that big improvements to OpenOffice can be incorporated into LibreOffice, while big improvements to LibreOffice can’t be incorporated into OpenOffice. This clearly gives a big advantage to LibreOffice, which will develop quicker and incorporate more features and improvements. |
_________________ Če nekaj deluje, razstavi in ugotovi zakaj. |
Spajky Član
Pridružen-a: Ned 27 Jun 2010 0:05 Prispevkov: 1095 Aktiv.: 5.98 Kraj: Obala
Objavljeno: Pon Feb 15, 2016 12:09 pm Naslov sporočila: |
Po netu je ogromno ms kompatible "office" paketov, tudi free, ki so nekajkrat manjša in hitrejša kot tale dva navedena za starejše kompe ... samo je treba malo poiskat ... |
Jaka57 Moderator
Pridružen-a: Ned 12 Dec 2004 21:47 Prispevkov: 5824 Aktiv.: 24.52 Kraj: Grosuplje
Objavljeno: Pon Feb 15, 2016 2:48 pm Naslov sporočila: |
Spajky, preberi še enkrat vprašanje!
Dorijan je odgovoril točno tisto, kar se sprašuje! _________________ Lp, Jaka |
Uptime: 9 dni
