s53al Član
Pridružen-a: Pon 18 Okt 2010 19:44 Prispevkov: 1123 Aktiv.: 6.29 Kraj: Bela krajina
Objavljeno: Čet Dec 02, 2021 12:50 pm Naslov sporočila: |
Modem je star en mesec, prenosnik pa 10 let. Z kablom gre 70/30. Rabim ga pa 10m, če hočem to spravit po vogalih.
Preden sprobam tisto iz linka. Kaj naj bi tista orodja naredila? Poiskala kakšne napake ali navlečem še kaj gori, da bo vse skupaj še počasneje
 _________________ Vremenska postaja Doblička gora |
qwertz Član
Pridružen-a: Ned 01 Jun 2008 11:57 Prispevkov: 2742 Aktiv.: 13.22 Kraj: Vrhnika
Objavljeno: Čet Dec 02, 2021 1:01 pm Naslov sporočila: |
Koda: |
What is iPerf / iPerf3 ?
iPerf3 is a tool for active measurements of the maximum achievable bandwidth on IP networks. It supports tuning of various parameters related to timing, buffers and protocols (TCP, UDP, SCTP with IPv4 and IPv6). For each test it reports the bandwidth, loss, and other parameters. This is a new implementation that shares no code with the original iPerf and also is not backwards compatible. iPerf was orginally developed by NLANR/DAST. iPerf3 is principally developed by ESnet / Lawrence Berkeley National Laboratory. It is released under a three-clause BSD license. |
s53al Član
