mosqito Član
Pridružen-a: Čet 07 Apr 2016 23:22 Prispevkov: 3533 Aktiv.: 31.40
Objavljeno: Čet Avg 18, 2022 7:17 am Naslov sporočila: |
Za uporabo HAL knjižnice rabimo še konfiguracijsko datoteko. Predlogo najdemo v
.stm32g0xx_hal_driver\Inc pod imenom "stm32g0xx_hal_conf_template.h".
To skopiramo v svoj "inc" in spremenimo ime v stm32g0xx_hal_conf.h
na začetku kode zakomentiramo vse module, razen tistih, ki jih bomo potrebovali v naši aplikaciji:
HAL_MODULE_ENABLED
HAL_I2C_MODULE_ENABLED
HAL_RTC_MODULE_ENABLED
HAL_UART_MODULE_ENABLED
HAL_GPIO_MODULE_ENABLED
HAL_EXTI_MODULE_ENABLED
HAL_DMA_MODULE_ENABLED
HAL_RCC_MODULE_ENABLED
HAL_FLASH_MODULE_ENABLED
HAL_PWR_MODULE_ENABLED
HAL_CORTEX_MODULE_ENABLED
Vsebina datoteke:
Koda: |
* @file stm32g0xx_hal_conf.h
* @author MCD Application Team
* @brief HAL configuration file.
* @attention
* Copyright (c) 2018 STMicroelectronics.
* All rights reserved.
* This software is licensed under terms that can be found in the LICENSE file
* in the root directory of this software component.
* If no LICENSE file comes with this software, it is provided AS-IS.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef STM32G0xx_HAL_CONF_H
#define STM32G0xx_HAL_CONF_H
#ifdef __cplusplus
extern "C" {
#endif
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* ########################## Module Selection ############################## */
* @brief This is the list of modules to be used in the HAL driver
#define HAL_MODULE_ENABLED
/* #define HAL_ADC_MODULE_ENABLED */
/* #define HAL_CEC_MODULE_ENABLED */
/* #define HAL_COMP_MODULE_ENABLED */
/* #define HAL_CRC_MODULE_ENABLED */
/* #define HAL_CRYP_MODULE_ENABLED */
/* #define HAL_DAC_MODULE_ENABLED */
/* #define HAL_EXTI_MODULE_ENABLED */
/* #define HAL_FDCAN_MODULE_ENABLED */
/* #define HAL_HCD_MODULE_ENABLED */
#define HAL_I2C_MODULE_ENABLED
/* #define HAL_I2S_MODULE_ENABLED */
/* #define HAL_IWDG_MODULE_ENABLED */
/* #define HAL_IRDA_MODULE_ENABLED */
/* #define HAL_LPTIM_MODULE_ENABLED */
/* #define HAL_PCD_MODULE_ENABLED */
/* #define HAL_RNG_MODULE_ENABLED */
#define HAL_RTC_MODULE_ENABLED
/* #define HAL_SMARTCARD_MODULE_ENABLED */
/* #define HAL_SMBUS_MODULE_ENABLED */
/* #define HAL_SPI_MODULE_ENABLED */
/* #define HAL_TIM_MODULE_ENABLED */
#define HAL_UART_MODULE_ENABLED
/* #define HAL_USART_MODULE_ENABLED */
/* #define HAL_WWDG_MODULE_ENABLED */
#define HAL_GPIO_MODULE_ENABLED
#define HAL_DMA_MODULE_ENABLED
#define HAL_RCC_MODULE_ENABLED
#define HAL_FLASH_MODULE_ENABLED
#define HAL_PWR_MODULE_ENABLED
#define HAL_CORTEX_MODULE_ENABLED
/* ########################## Register Callbacks selection ############################## */
* @brief This is the list of modules where register callback can be used
#define USE_HAL_ADC_REGISTER_CALLBACKS 0u
#define USE_HAL_CEC_REGISTER_CALLBACKS 0u
#define USE_HAL_COMP_REGISTER_CALLBACKS 0u
#define USE_HAL_CRYP_REGISTER_CALLBACKS 0u
#define USE_HAL_DAC_REGISTER_CALLBACKS 0u
#define USE_HAL_FDCAN_REGISTER_CALLBACKS 0u
#define USE_HAL_HCD_REGISTER_CALLBACKS 0u
#define USE_HAL_I2C_REGISTER_CALLBACKS 0u
#define USE_HAL_I2S_REGISTER_CALLBACKS 0u
#define USE_HAL_IRDA_REGISTER_CALLBACKS 0u
#define USE_HAL_LPTIM_REGISTER_CALLBACKS 0u
#define USE_HAL_PCD_REGISTER_CALLBACKS 0u
#define USE_HAL_RNG_REGISTER_CALLBACKS 0u
#define USE_HAL_RTC_REGISTER_CALLBACKS 0u
#define USE_HAL_SMBUS_REGISTER_CALLBACKS 0u
#define USE_HAL_SPI_REGISTER_CALLBACKS 0u
#define USE_HAL_TIM_REGISTER_CALLBACKS 0u
#define USE_HAL_UART_REGISTER_CALLBACKS 0u
#define USE_HAL_USART_REGISTER_CALLBACKS 0u
#define USE_HAL_WWDG_REGISTER_CALLBACKS 0u
/* ########################## Oscillator Values adaptation ####################*/
* @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
* This value is used by the RCC HAL module to compute the system frequency
* (when HSE is used as system clock source, directly or through the PLL).
#if !defined (HSE_VALUE)
#define HSE_VALUE (8000000UL) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
#if !defined (HSE_STARTUP_TIMEOUT)
#define HSE_STARTUP_TIMEOUT (100UL) /*!< Time out for HSE start up, in ms */
#endif /* HSE_STARTUP_TIMEOUT */
* @brief Internal High Speed oscillator (HSI) value.
* (when HSI is used as system clock source, directly or through the PLL).
#if !defined (HSI_VALUE)
#define HSI_VALUE (16000000UL) /*!< Value of the Internal oscillator in Hz*/
#endif /* HSI_VALUE */
#if defined(STM32G0C1xx) || defined(STM32G0B1xx) || defined(STM32G0B0xx)
* @brief Internal High Speed oscillator (HSI48) value for USB FS, SDMMC and RNG.
* This internal oscillator is mainly dedicated to provide a high precision clock to
* the USB peripheral by means of a special Clock Recovery System (CRS) circuitry.
* When the CRS is not used, the HSI48 RC oscillator runs on it default frequency
* which is subject to manufacturing process variations.
#if !defined (HSI48_VALUE)
#define HSI48_VALUE 48000000U /*!< Value of the Internal High Speed oscillator for USB FS/SDMMC/RNG in Hz.
The real value my vary depending on manufacturing process variations.*/
#endif /* HSI48_VALUE */
#endif
* @brief Internal Low Speed oscillator (LSI) value.
#if !defined (LSI_VALUE)
#define LSI_VALUE (32000UL) /*!< LSI Typical Value in Hz*/
#endif /* LSI_VALUE */ /*!< Value of the Internal Low Speed oscillator in Hz
The real value may vary depending on the variations
in voltage and temperature.*/
* @brief External Low Speed oscillator (LSE) value.
* This value is used by the UART, RTC HAL module to compute the system frequency
#if !defined (LSE_VALUE)
#define LSE_VALUE (32768UL) /*!< Value of the External oscillator in Hz*/
#endif /* LSE_VALUE */
#if !defined (LSE_STARTUP_TIMEOUT)
#define LSE_STARTUP_TIMEOUT (5000UL) /*!< Time out for LSE start up, in ms */
#endif /* LSE_STARTUP_TIMEOUT */
* @brief External clock source for I2S1 peripheral
* This value is used by the RCC HAL module to compute the I2S1 clock source
* frequency.
#if !defined (EXTERNAL_I2S1_CLOCK_VALUE)
#define EXTERNAL_I2S1_CLOCK_VALUE (12288000UL) /*!< Value of the I2S1 External clock source in Hz*/
#endif /* EXTERNAL_I2S1_CLOCK_VALUE */
* @brief External clock source for I2S2 peripheral
* This value is used by the RCC HAL module to compute the I2S2 clock source
* frequency.
#if !defined (EXTERNAL_I2S2_CLOCK_VALUE)
#define EXTERNAL_I2S2_CLOCK_VALUE 48000U /*!< Value of the I2S2 External clock source in Hz*/
#endif /* EXTERNAL_I2S2_CLOCK_VALUE */
#endif
/* Tip: To avoid modifying this file each time you need to use different HSE,
=== you can define the HSE value in your toolchain compiler preprocessor. */
/* ########################### System Configuration ######################### */
* @brief This is the HAL system configuration section
#define VDD_VALUE (3300UL) /*!< Value of VDD in mv */
#define TICK_INT_PRIORITY 3U /*!< tick interrupt priority */
#define USE_RTOS 0U
#define PREFETCH_ENABLE 1U
#define INSTRUCTION_CACHE_ENABLE 1U
/* ################## SPI peripheral configuration ########################## */
/* CRC FEATURE: Use to activate CRC feature inside HAL SPI Driver
* Activated: CRC code is present inside driver
* Deactivated: CRC code cleaned from driver
#define USE_SPI_CRC 0U
/* ################## CRYP peripheral configuration ########################## */
#define USE_HAL_CRYP_SUSPEND_RESUME 1U
/* ########################## Assert Selection ############################## */
* @brief Uncomment the line below to expanse the "assert_param" macro in the
* HAL drivers code
/* #define USE_FULL_ASSERT 1U */
/* Includes ------------------------------------------------------------------*/
* @brief Include modules header file
#ifdef HAL_RCC_MODULE_ENABLED
#include "stm32g0xx_hal_rcc.h"
#endif /* HAL_RCC_MODULE_ENABLED */
#ifdef HAL_GPIO_MODULE_ENABLED
#include "stm32g0xx_hal_gpio.h"
#endif /* HAL_GPIO_MODULE_ENABLED */
#ifdef HAL_DMA_MODULE_ENABLED
#include "stm32g0xx_hal_dma.h"
#endif /* HAL_DMA_MODULE_ENABLED */
#ifdef HAL_CORTEX_MODULE_ENABLED
#include "stm32g0xx_hal_cortex.h"
#endif /* HAL_CORTEX_MODULE_ENABLED */
#ifdef HAL_ADC_MODULE_ENABLED
#include "stm32g0xx_hal_adc.h"
#include "stm32g0xx_hal_adc_ex.h"
#endif /* HAL_ADC_MODULE_ENABLED */
#ifdef HAL_CEC_MODULE_ENABLED
#include "stm32g0xx_hal_cec.h"
#endif /* HAL_CEC_MODULE_ENABLED */
#ifdef HAL_COMP_MODULE_ENABLED
#include "stm32g0xx_hal_comp.h"
#endif /* HAL_COMP_MODULE_ENABLED */
#ifdef HAL_CRC_MODULE_ENABLED
#include "stm32g0xx_hal_crc.h"
#endif /* HAL_CRC_MODULE_ENABLED */
#ifdef HAL_CRYP_MODULE_ENABLED
#include "stm32g0xx_hal_cryp.h"
#endif /* HAL_CRYP_MODULE_ENABLED */
#ifdef HAL_DAC_MODULE_ENABLED
#include "stm32g0xx_hal_dac.h"
#endif /* HAL_DAC_MODULE_ENABLED */
#ifdef HAL_EXTI_MODULE_ENABLED
#include "stm32g0xx_hal_exti.h"
#endif /* HAL_EXTI_MODULE_ENABLED */
#ifdef HAL_FLASH_MODULE_ENABLED
#include "stm32g0xx_hal_flash.h"
#endif /* HAL_FLASH_MODULE_ENABLED */
#ifdef HAL_FDCAN_MODULE_ENABLED
#include "stm32g0xx_hal_fdcan.h"
#endif /* HAL_FDCAN_MODULE_ENABLED */
#ifdef HAL_HCD_MODULE_ENABLED
#include "stm32g0xx_hal_hcd.h"
#endif /* HAL_HCD_MODULE_ENABLED */
#ifdef HAL_I2C_MODULE_ENABLED
#include "stm32g0xx_hal_i2c.h"
#endif /* HAL_I2C_MODULE_ENABLED */
#ifdef HAL_I2S_MODULE_ENABLED
#include "stm32g0xx_hal_i2s.h"
#endif /* HAL_I2S_MODULE_ENABLED */
#ifdef HAL_IRDA_MODULE_ENABLED
#include "stm32g0xx_hal_irda.h"
#endif /* HAL_IRDA_MODULE_ENABLED */
#ifdef HAL_IWDG_MODULE_ENABLED
#include "stm32g0xx_hal_iwdg.h"
#endif /* HAL_IWDG_MODULE_ENABLED */
#ifdef HAL_LPTIM_MODULE_ENABLED
#include "stm32g0xx_hal_lptim.h"
#endif /* HAL_LPTIM_MODULE_ENABLED */
#ifdef HAL_PCD_MODULE_ENABLED
#include "stm32g0xx_hal_pcd.h"
#endif /* HAL_PCD_MODULE_ENABLED */
#ifdef HAL_PWR_MODULE_ENABLED
#include "stm32g0xx_hal_pwr.h"
#endif /* HAL_PWR_MODULE_ENABLED */
#ifdef HAL_RNG_MODULE_ENABLED
#include "stm32g0xx_hal_rng.h"
#endif /* HAL_RNG_MODULE_ENABLED */
#ifdef HAL_RTC_MODULE_ENABLED
#include "stm32g0xx_hal_rtc.h"
#endif /* HAL_RTC_MODULE_ENABLED */
#ifdef HAL_SMARTCARD_MODULE_ENABLED
#include "stm32g0xx_hal_smartcard.h"
#endif /* HAL_SMARTCARD_MODULE_ENABLED */
#ifdef HAL_SMBUS_MODULE_ENABLED
#include "stm32g0xx_hal_smbus.h"
#endif /* HAL_SMBUS_MODULE_ENABLED */
#ifdef HAL_SPI_MODULE_ENABLED
#include "stm32g0xx_hal_spi.h"
#endif /* HAL_SPI_MODULE_ENABLED */
#ifdef HAL_TIM_MODULE_ENABLED
#include "stm32g0xx_hal_tim.h"
#endif /* HAL_TIM_MODULE_ENABLED */
#ifdef HAL_UART_MODULE_ENABLED
#include "stm32g0xx_hal_uart.h"
#endif /* HAL_UART_MODULE_ENABLED */
#ifdef HAL_USART_MODULE_ENABLED
#include "stm32g0xx_hal_usart.h"
#endif /* HAL_USART_MODULE_ENABLED */
#ifdef HAL_WWDG_MODULE_ENABLED
#include "stm32g0xx_hal_wwdg.h"
#endif /* HAL_WWDG_MODULE_ENABLED */
/* Exported macro ------------------------------------------------------------*/
#ifdef USE_FULL_ASSERT
* @brief The assert_param macro is used for functions parameters check.
* @param expr If expr is false, it calls assert_failed function
* which reports the name of the source file and the source
* line number of the call that failed.
* If expr is true, it returns no value.
* @retval None
#define assert_param(expr) ((expr) ? (void)0U : assert_failed((uint8_t *)__FILE__, __LINE__))
/* Exported functions ------------------------------------------------------- */
void assert_failed(uint8_t *file, uint32_t line);
#else
#define assert_param(expr) ((void)0U)
#endif /* USE_FULL_ASSERT */
#ifdef __cplusplus
#endif
#endif /* STM32G0xx_HAL_CONF_H */
mosqito Član
Objavljeno: Čet Avg 18, 2022 7:20 am Naslov sporočila: |
Sedaj se bi moralo prevesti brez napak:
Program Size: Code=308 RO-data=208 RW-data=0 ZI-data=1632
".\Objects\forumvaja1.axf" - 0 Error(s), 0 Warning(s).
Build Time Elapsed: 00:00:42 |
S tem je vse pripravljeno za bolj resno delo.
Najprej bomo inicializirali periferijo.
mosqito Član
Objavljeno: Čet Avg 18, 2022 11:11 pm Naslov sporočila: |
Tale STM32 HAL je na prvo žogo malo čuden, ampak ko se stvari navadiš, je sila enostavno in uporabno.
Dajmo zdaj za vajo inicializirati I2C.
Najprej preimenujmo grupo, kjer imamo datoteko main.c v "Aplikacija". Dodajmo še eno grupo in jo poimenujmo "STM32G031" (slika spodaj).
V grupo "STM32G01" dodajmo novo datoteko init.c. Ne pozabiti na lokacijo v direktoriju "src" (druga slika spodaj).
18.2 KB |
1257 krat |
63.33 KB |
1 krat |
mosqito Član
Objavljeno: Čet Avg 18, 2022 11:43 pm Naslov sporočila: |
Sedaj lahko napišemo kodo, ki bo inicializirala I2C. Do te kode sicer lahko pridemo tudi povsem avtomatično s pomočjo CUBE generatorja kode, samo pri tem nastane škoda, saj nimamo blage veze, kaj in kako deluje. Za nekoga, ki se s tem prvič srečuje, je najbolje uporabiti CUBE, vendar tu bom opisal malo bolj podrobno in predvsem brez nepotrebno nasmetene kode (s komentarji "user code start" in "user code end" ter podobnim).
Najprej vključimo nujne headerje:
Koda: |
#include "stm32g0xx.h" // Device header
#include "stm32g0xx_hal.h"
Za I2C (kot tudi za vse ostale periferne enote) je definirana specifična struktura, kjer so shranjene vse nastavitve in ostali podatki. Za I2C se imenuje I2C_HandleTypeDef, najdemo jo pa v HAL knjižnici v datoteki "stm32g0xx_hal_i2c.h". Polja strukture so:
Koda: |
typedef struct __I2C_HandleTypeDef
I2C_TypeDef *Instance; /*!< I2C registers base address */
I2C_InitTypeDef Init; /*!< I2C communication parameters */
uint8_t *pBuffPtr; /*!< Pointer to I2C transfer buffer */
uint16_t XferSize; /*!< I2C transfer size */
__IO uint16_t XferCount; /*!< I2C transfer counter */
__IO uint32_t XferOptions; /*!< I2C sequantial transfer options, this parameter can
be a value of @ref I2C_XFEROPTIONS */
__IO uint32_t PreviousState; /*!< I2C communication Previous state */
HAL_StatusTypeDef(*XferISR)(struct __I2C_HandleTypeDef *hi2c, uint32_t ITFlags, uint32_t ITSources);
/*!< I2C transfer IRQ handler function pointer */
DMA_HandleTypeDef *hdmatx; /*!< I2C Tx DMA handle parameters */
DMA_HandleTypeDef *hdmarx; /*!< I2C Rx DMA handle parameters */
HAL_LockTypeDef Lock; /*!< I2C locking object */
__IO HAL_I2C_StateTypeDef State; /*!< I2C communication state */
__IO HAL_I2C_ModeTypeDef Mode; /*!< I2C communication mode */
__IO uint32_t ErrorCode; /*!< I2C Error code */
__IO uint32_t AddrEventCount; /*!< I2C Address Event counter */
} I2C_HandleTypeDef;
V init.c definiramo spremenljivko hi2c1:
Koda: |
I2C_HandleTypeDef hi2c1;
Funkcija za inicializacijo I2C1 zgleda potem nekako takole:
Koda: |
* @brief I2C1 Initialization Function
* @param None
* @retval None
static int I2C1_Init(void)
hi2c1.Instance = I2C1;
hi2c1.Init.Timing = 0x00602173;
hi2c1.Init.OwnAddress1 = 0;
hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
hi2c1.Init.OwnAddress2 = 0;
hi2c1.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
if (HAL_I2C_Init(&hi2c1) != HAL_OK)
return -1;
/** Configure Analogue filter
if (HAL_I2CEx_ConfigAnalogFilter(&hi2c1, I2C_ANALOGFILTER_ENABLE) != HAL_OK)
return -1;
/** Configure Digital filter
if (HAL_I2CEx_ConfigDigitalFilter(&hi2c1, 0) != HAL_OK)
return -1;
return 0;
Nekaj stvari je samoumevnih, nekaj pa potrebuje razlago.
Najprej je timing register. V oknu s projektom kliknemo na "Books" in odpremo datoteko "STM32G0x1 Reference Manual". V poglavju 32.7.5 I2C timing register (I2C_TIMINGR) je opisan ta register.
Vsi časi se nanašajo na tPRESC, ki je definiran z biti 31:28. To je delilnik takta, ki napaja I2C enoto. Če malo podpiramo lenobo in se nam ne ljubi računat iz binarne vrednosti, lahko vrednost registra določimo s pomočjo CUBE_MX.
Tu se pa sedaj srečamo še z enim taktom (oz. periodo) tI2CCLK. O sami "napeljavi" takta znotraj mikrokontrolerja nismo še nič rekli. To bom opisal takoj v nadaljevanju.
Če se vrnemo na inicializacijo I2C... naslavljanje pustimo najbolj klasično (7 bitna adresa, lahko bi bila tudi 10-bitna), brez sekundarnega naslavljanja, naprava deluje kot master in ne rabi lastnega naslova, clock streching-a tudi ne rabimo, general call (adresa s samimi enicami) naj ne bo aktiven in to je to.
V nadaljevanju je še konfiguracija analognega in digitalnega filtra na samih I2C linijah.
Če pogledamo blok shemo I2C, vidimo da je analogni filter izven I2C enote in je med GPIO logiko (stikali, ki priklopijo pin na I2C enoto) in samo I2C enoto. Digitalni filter pa se nahaja znotraj same periferne enote. Sama filtra sta uporabno orodje za večjo imunost I2C, a ob napačni konfiguraciji lahko naredimo več škode kot koristi.
Analogni filtzer načeloma poreže špice nad 50ns. Digitalni filter pa je nastavljiv od 1 do 15 taktov vhodnega takta v I2C enoto. Vedeti moramo tudi to, da nastavljanje filtrov ni možno, če je I2C aktiven. Pred spreminjanjem moramo I2C najprej deaktivirati.
Tu bomo obravnavali le master način dela, seveda pa lahko I2C deluje tudi kot slave. Več podrobnosti je v RM v poglavju 32, če bi koga zanimalo.
68.91 KB |
3 krat |
mosqito Član
Objavljeno: Pet Avg 19, 2022 12:11 am Naslov sporočila: |
Takole, zdaj gremo en korak nazaj in poglejmo, kaj je v funkciji iz HAL_Init HAL knjižnice:
Koda: |
HAL_StatusTypeDef HAL_Init(void)
HAL_StatusTypeDef status = HAL_OK;
/* Configure Flash prefetch, Instruction cache */
/* Default configuration at reset is: */
/* - Prefetch disabled */
/* - Instruction cache enabled */
#if (INSTRUCTION_CACHE_ENABLE == 0U)
__HAL_FLASH_INSTRUCTION_CACHE_DISABLE();
#endif /* INSTRUCTION_CACHE_ENABLE */
#if (PREFETCH_ENABLE != 0U)
__HAL_FLASH_PREFETCH_BUFFER_ENABLE();
#endif /* PREFETCH_ENABLE */
/* Use SysTick as time base source and configure 1ms tick (default clock after Reset is HSI) */
if (HAL_InitTick(TICK_INT_PRIORITY) != HAL_OK)
status = HAL_ERROR;
else
/* Init the low level hardware */
HAL_MspInit();
/* Return function status */
return status;
Tam na koncu vidimo en klic funkcije HAL_MspInit();
Ta je v osnovi "prazna", je pa to pravo mesto, da inicializiramo kakšne low-level zadeve. Tipičen primer je mapiranje pinov, vklop takta v določene enote in podobno.
V našem primeru moramo narediti "remap" pinov PA11 in PA12, saj bomo potrebovali PA9 (USART1 TX) namesto PA11 in PA10 (I2C1_SDA) namesto PA12.
Naša funkcija HAL_MspInit() zgleda takole:
Koda: |
void HAL_MspInit(void)
__HAL_RCC_SYSCFG_CLK_ENABLE();
__HAL_RCC_PWR_CLK_ENABLE();
HAL_SYSCFG_EnableRemap(SYSCFG_REMAP_PA11);
HAL_SYSCFG_EnableRemap(SYSCFG_REMAP_PA12);
Šreden lahko spreminjamo konfiguracijo povezave pinov, je seveda potrebno vklopiti takt.
V prispevku zgoraj smo videli, kako se nastavi parametre samemu I2C. Kako pa pripravimo pine, na katerih je I2C? Poglejmo, kaj je v HAL funkciji HAL_I2C_Init(). Nekje v init funkciji naletimo na klic funkcije HAL_I2C_MspInit():
Koda: |
/* Init the low level hardware : GPIO, CLOCK, CORTEX...etc */
HAL_I2C_MspInit(hi2c);
Komentar pove vse
Pa dajmo pogledat, kaj je potrebno narediti, da dobimo na pine I2C in da bodo ti prav skonfigurirani:
Koda: |
* @brief I2C MSP Initialization
* This function configures the hardware resources used by I2C
* @param hi2c: I2C handle pointer
* @retval None
void HAL_I2C_MspInit(I2C_HandleTypeDef* hi2c)
GPIO_InitTypeDef GPIO_InitStruct = {0};
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
if(hi2c->Instance==I2C1)
/** Initializes the peripherals clocks
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_I2C1;
PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
__asm__("BKPT #1");
__HAL_RCC_GPIOB_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**I2C1 GPIO Configuration
PB8 ------> I2C1_SCL
PA10 [PA12] ------> I2C1_SDA
GPIO_InitStruct.Pin = GPIO_PIN_8;
GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
GPIO_InitStruct.Alternate = GPIO_AF6_I2C1;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_10;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* Peripheral clock enable */
__HAL_RCC_I2C1_CLK_ENABLE();
/* I2C1 interrupt Init */
HAL_NVIC_SetPriority(I2C1_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(I2C1_IRQn);
Najprej preverimo, ali gre sploh za I2C1:
Koda: |
if(hi2c->Instance==I2C1) |
To funkcijo lahko kliče HAL_I2C_Init() tudi ob inicializaciji npr. I2C2 in to moramo seveda ločiti, saj je I2C2 na drugih pinih (pa I2C3, ... če seveda v izbranem ohišju mikrokontrolerja to obstaja).
Najpre vklopimo takt v enoto I2C in v GPIO enoti (port A in port B), kjer sta SDA in CLK pina.
Zgoraj sem dal primer, da se v slučaju neuspešnega konfiguriranja izvede
Koda: |
__asm__("BKPT #1");
To je asemblerski ukaz, ki povzroči prekinitev izvajanja - isto, kot bi imeli na tem mestu prekinitveno točko, le da se to izvede programsko. Na ta način lahko vidimo, kje je prišlo do napake. Če nimamo priključenega debuggerja, pa bo procesor končal v hard fault.
Na koncu sledi še konfiguracija pinov in inicializacije prekinitev za I2C. O samih prekinitvah bomo kakšno rekli tudi malo kasneje.
mosqito Član
Objavljeno: Sob Avg 27, 2022 6:51 pm Naslov sporočila: |
Sedaj lahko končamo I2C del, na vodilo priklopimo OLED in dodamo kodo za pogon OLED prikazovalnika.
V projekt dodamo datoteko init.c s funkcijami za inicializacijo periferije.
Poleg I2C bomo inicializirali še UART1 in 2 (Rx in Tx pina sta tako postavljena, da rabimo oba, saj se drugače ne da skombinirat na 8 pinskem. Pa če RTC bomo sproti inicializirali.
Celotna datoteka init.c...
Koda: |
RTC_HandleTypeDef hrtc;
UART_HandleTypeDef huart1;
UART_HandleTypeDef huart2;
int SystemClock_Config(void);
static int GPIO_Init(void);
static int I2C1_Init(void);
static int USART1_UART_Init(void);
static int USART2_UART_Init(void);
int MCU_Init(void) {
int status = 0;
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
if (HAL_Init() != HAL_OK) status = -1;
/* Configure the system clock */
status += SystemClock_Config();
/* Initialize all configured peripherals */
status += GPIO_Init();
status += I2C1_Init();
//status += RTC_Init();
status += USART1_UART_Init();
status += USART2_UART_Init();
return status;
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Configure the main internal regulator output voltage
HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1;
RCC_OscInitStruct.PLL.PLLN = 8;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
return -1;
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
return -1;
return 0;
* @brief GPIO Initialization Function
* @param None
* @retval None
/* GPIO Ports Clock Enable */
return 0;
* @param None
* @retval None
return -1;
return -1;
return -1;
return 0;
* @brief USART1 Initialization Function
* @param None
* @retval None
huart1.Instance = USART1;
huart1.Init.BaudRate = 115200;
huart1.Init.WordLength = UART_WORDLENGTH_8B;
huart1.Init.StopBits = UART_STOPBITS_1;
huart1.Init.Parity = UART_PARITY_NONE;
huart1.Init.Mode = UART_MODE_RX;
huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart1.Init.OverSampling = UART_OVERSAMPLING_16;
huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
huart1.Init.ClockPrescaler = UART_PRESCALER_DIV1;
huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
if (HAL_HalfDuplex_Init(&huart1) != HAL_OK)
return -1;
if (HAL_UARTEx_SetTxFifoThreshold(&huart1, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
return -1;
if (HAL_UARTEx_SetRxFifoThreshold(&huart1, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
return -1;
if (HAL_UARTEx_DisableFifoMode(&huart1) != HAL_OK)
return -1;
return 0;
* @brief USART2 Initialization Function
* @param None
* @retval None
huart2.Instance = USART2;
huart2.Init.BaudRate = 115200;
huart2.Init.WordLength = UART_WORDLENGTH_8B;
huart2.Init.StopBits = UART_STOPBITS_1;
huart2.Init.Parity = UART_PARITY_NONE;
huart2.Init.Mode = UART_MODE_TX;
huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart2.Init.OverSampling = UART_OVERSAMPLING_16;
huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
huart2.Init.ClockPrescaler = UART_PRESCALER_DIV1;
huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
if (HAL_HalfDuplex_Init(&huart2) != HAL_OK)
return -1;
return 0;
/***** MSP initialization ---- HAL library calls these function during periphery init */
* Initializes the Global MSP.
* @retval None
__asm__("BKPT #1");
* @brief I2C MSP De-Initialization
* This function freeze the hardware resources used in this example
* @retval None
void HAL_I2C_MspDeInit(I2C_HandleTypeDef* hi2c)
/* Peripheral clock disable */
__HAL_RCC_I2C1_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOB, GPIO_PIN_8);
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_10);
/* I2C1 interrupt DeInit */
HAL_NVIC_DisableIRQ(I2C1_IRQn);
* @brief RTC MSP Initialization
* This function configures the hardware resources used in this example
* @param hrtc: RTC handle pointer
* @retval None
void HAL_RTC_MspInit(RTC_HandleTypeDef* hrtc)
if(hrtc->Instance==RTC)
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC;
PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
__asm__("BKPT #1");
__HAL_RCC_RTC_ENABLE();
__HAL_RCC_RTCAPB_CLK_ENABLE();
* @brief RTC MSP De-Initialization
* @retval None
void HAL_RTC_MspDeInit(RTC_HandleTypeDef* hrtc)
__HAL_RCC_RTC_DISABLE();
__HAL_RCC_RTCAPB_CLK_DISABLE();
* @brief UART MSP Initialization
* @param huart: UART handle pointer
* @retval None
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
if(huart->Instance==USART1)
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
__asm__("BKPT #1");
__HAL_RCC_USART1_CLK_ENABLE();
/**USART1 GPIO Configuration
PA9 [PA11] ------> USART1_TX
GPIO_InitStruct.Pin = GPIO_PIN_9;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Alternate = GPIO_AF1_USART1;
/* USART1 interrupt Init */
HAL_NVIC_SetPriority(USART1_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(USART1_IRQn);
else if(huart->Instance==USART2)
__HAL_RCC_USART2_CLK_ENABLE();
/**USART2 GPIO Configuration
PA2 ------> USART2_TX
GPIO_InitStruct.Pin = GPIO_PIN_2;
GPIO_InitStruct.Alternate = GPIO_AF1_USART2;
/* USART2 interrupt Init */
HAL_NVIC_SetPriority(USART2_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(USART2_IRQn);
* @brief UART MSP De-Initialization
* @retval None
void HAL_UART_MspDeInit(UART_HandleTypeDef* huart)
__HAL_RCC_USART1_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_9);
/* USART1 interrupt DeInit */
HAL_NVIC_DisableIRQ(USART1_IRQn);
__HAL_RCC_USART2_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_2);
/* USART2 interrupt DeInit */
HAL_NVIC_DisableIRQ(USART2_IRQn);
mosqito Član
Objavljeno: Sob Avg 27, 2022 7:33 pm Naslov sporočila: |
Za OLED imamo dva dela "gonilnika". V prvem so funkcije za nekaj osnovnegrafike, v drugem delu pa definicija fontov.
Kode je kar nekaj, zato prilagam kar cel projekt.
Ime datoteke: |
OLED-vaja.zip |
1.04 MB |
Downloadano: |
4 krat |
Wrecker Član
Pridružen-a: Pet 11 Feb 2011 22:43 Prispevkov: 254 Aktiv.: 1.45
Objavljeno: Pet Sep 02, 2022 9:51 pm Naslov sporočila: |
Tole je super narejeno in upam, da bo šlo še naprej.
Malo se igram z 20 pinskom stm32g031, pa me zanima, če kdo ve kaj je razlika med uart1 in uart2? Inicializacijo imam narejeno podobno kot v tej temi.
Uart1 mi deluje odlično, uarta2 pa če vse napišem po enekem principu kot pri uart1 ga ne morem nikakor usposobiti. Sploh ne sproži prekinitve. Piše, da je treba nastaviti za uart2 frekvenco APB do max 36 Mhz ->APB prescaler na 2 a tudi to ne pomaga, očitno so še neke razlike ali kak detajl? Prosim za kakšno idejo kaj lahko še naredim.
mosqito Član
Objavljeno: Pet Sep 02, 2022 10:15 pm Naslov sporočila: |
Preveri, če so vsi takti vklopljeni pred inicializacijo: gpio port pinov (preveri tudi če je funkcija pinov nastavljena), uart clk enable, irq controller ...
mosqito Član
Objavljeno: Pon Sep 12, 2022 4:03 pm Naslov sporočila: |
Morda še par besed o hardveru, oz pinih. Sam MCU deluje na napajanju 3,3V. Vedno je treba preveriti datasheet. V sekciji "GPIO pins" je tabela z vsemi funkcijami pinov in tudi podatkom o tem, ali je določen pin "5V tolerant". Če je, to pomeni, da lahko direktno priklopimo periferijo, ki na svojem izhodu generira napetosti do 5V. Seveda sam mcu ne bo generiral 5V, če je pin skonfiguriran kot izhod. Isto velja tudi za alternativne funkcije pinov: npr. na Rx vhodni pin od UART lahko prupeljemo tudi 5V brez vsakega problema, na Tx izhodu pa bosta seveda le nivoja 0V ali 3,3V. Lahko pa pin tudi če ima drugo funkcijo kot GPIO skonfiguriramo kot npr. open drain in damo pullup na 5V. V tem lrimeru bo na izhodu nivo 5V. Paziti pa je seveda treba na parazitne kapacitivnosti, saj preprost pullup ne bo zmogel hitrih prehodov iz 0 na 5V, če bo "videl" kapacitivno breme.
Ravno te dni sem preizkušal max. hitrosti na UART na stm32g0, le da sem dal na izhodu še en NPN transistor, ki je dvignil nivo na 24V. Sam UART v STM32 ima tudi opcijo, da invertira Rx in/ali Tx, tako da na ven se ni nič spremenilo. Brez težav sem dosegel 4Mbaud s komunikacijo z 9 podatkovbimi biti (ja, UART je lahko tudi 9 bitni - data register je sicer 16 bitni, a vzame lahko spodnjih 9). Poleg obračanja polaritete ima možnost tudi zamebjave Rx/Tx in celo invertiranja data bitov (ne na nivoju pina, ampak samo pidatkov - start in stop tako nista invertirana).
Nekatere od teh opcij na seriji L0 niso na voljo....
Uptime: 7 dni
