Malo za šalo XV
Pojdi na stran Prejšnja  1, 2, 3 ... , 41, 42, 43  Naslednja
SimonS
Prispevkov: 4769
Aktiv.: 20.13
Kraj: Kobarid
PrispevekObjavljeno: Sre Dec 11, 2024 6:16 pm    Naslov sporočila:   Odgovori s citatom
Evo, tako pa chatGPT nariše shemo na ukaz uporabe low-side mosfeta. Meni je jasno... nič!
A simple electronics circuit diagram illustrating the connection of an N-channel MOSFET for low-side switching to control a 3V device. The diagram inc.jpg
 Velikost datoteke:  332.87 KB
Lep dan
Simon
Prispevkov: 3531
Aktiv.: 31.56
PrispevekObjavljeno: Ned Dec 15, 2024 2:37 pm    Naslov sporočila:   Odgovori s citatom
Sem mu dal isti tekst, pa ga potem okaral, da trosi neumnosti. Pa je vrnil tole:
Koda:
from matplotlib import pyplot as plt
import matplotlib.patches as patches
# Create a new figure for the circuit
def draw_circuit_diagram():
    fig, ax = plt.subplots(figsize=(8, 6))
    # Power Supply
    ax.text(0.1, 0.9, "3V Power Supply", fontsize=12, ha="center")
    ax.plot([0.1, 0.4], [0.85, 0.85], color='black', lw=2)
    ax.plot([0.4, 0.4], [0.85, 0.7], color='black', lw=2)
    # Load (e.g., LED or Motor)
    ax.text(0.45, 0.75, "Load (3V Device)", fontsize=10, ha="left")
    ax.plot([0.4, 0.6], [0.7, 0.7], color='black', lw=2)
    ax.plot([0.6, 0.6], [0.7, 0.55], color='black', lw=2)
    # N-channel MOSFET
    ax.text(0.65, 0.6, "N-channel MOSFET", fontsize=10, ha="left")
    ax.add_patch(patches.Rectangle((0.6, 0.35), 0.1, 0.3, edgecolor='black', facecolor='none'))
    ax.plot([0.65, 0.65], [0.35, 0.3], color='black', lw=2, linestyle='--')  # Arrow for Source
    # Source to Ground
    ax.plot([0.65, 0.65], [0.35, 0.15], color='black', lw=2)
    ax.text(0.65, 0.1, "Ground", fontsize=10, ha="center")
    # Gate control signal
    ax.plot([0.75, 0.75], [0.55, 0.8], color='black', lw=2)
    ax.text(0.8, 0.75, "Control Signal", fontsize=10, ha="left")
    # Drain
    ax.plot([0.6, 0.65], [0.55, 0.55], color='black', lw=2)
    # Adjust plot limits and hide axes
    ax.set_xlim(0, 1)
    ax.set_ylim(0, 1)
    ax.axis('off')
    # Show the plot
    plt.show()
# Call the function to draw the circuit diagram
Lovro7
Pridružen-a: Pet 06 Sep 2024 18:31
Prispevkov: 27
Aktiv.: 2.87
PrispevekObjavljeno: Ned Dec 15, 2024 7:37 pm    Naslov sporočila:   Odgovori s citatom
2 dni nazaj sem delal nekaj z tkinterjem in plot. Nekaj nisem znal narediti in sem vprašal chat. Prilepim kodo v VS code, kliknem run in napaka. Posljem chatu napako in napiše:
Oprostite, ker je prišlo do zmede. Napaka se je pojavila v funkciji update_plot(). Tukaj je popravljena koda:
Napiše novo kodo, ki je bila identična.
Nato sem mu ponovno napisal: “popravi napake v kodi + koda”
In dobim nazaj kodo, ki ji manjka 3/4 funkciji.
3x sem ponovil vprašanje in vsakič je bili slabše.
Vse je lahko žarnica, če je dovolj toka.
Ne mi zamerit, če se zmotim!
twom
Prispevkov: 986
Aktiv.: 4.16
PrispevekObjavljeno: Pet Jan 03, 2025 4:11 pm    Naslov sporočila:   Odgovori s citatom
 Velikost datoteke:  42.19 KB
 Pogledana:  11 krat
Prispevkov: 3531
Aktiv.: 31.56
PrispevekObjavljeno: Tor Feb 25, 2025 4:48 pm    Naslov sporočila:   Odgovori s citatom
https://m.youtube.com/watch?v=NrkaHV-ck-A
Prispevkov: 3531
Aktiv.: 31.56
PrispevekObjavljeno: Pet Apr 04, 2025 9:14 pm    Naslov sporočila:   Odgovori s citatom
Oma…
 Velikost datoteke:  137.29 KB
Prispevkov: 6732
Aktiv.: 28.42
PrispevekObjavljeno: Ned Apr 06, 2025 8:39 am    Naslov sporočila:   Odgovori s citatom
Pogajanja ...
 Velikost datoteke:  76.95 KB
Dober_Dan
Pridružen-a: Ned 27 Mar 2022 20:13
Prispevkov: 38
Aktiv.: 0.97
PrispevekObjavljeno: Tor Apr 08, 2025 3:00 pm    Naslov sporočila:   Odgovori s citatom
Kaj reče elektron, ko ga vprašajo, zakaj je tako negativen?
"To je samo moja narava!"
Ivor
Pridružen-a: Pet 15 Feb 2008 19:49
Prispevkov: 213
Aktiv.: 1.01
PrispevekObjavljeno: Sre Apr 09, 2025 11:32 am    Naslov sporočila:   Odgovori s citatom
"Varovalka"
 Velikost datoteke:  90.94 KB
Mirno spim na lovorikah že 17 let.
Ivor
Prispevkov: 213
Aktiv.: 1.01
PrispevekObjavljeno: Sre Apr 09, 2025 11:35 am    Naslov sporočila:   Odgovori s citatom
Limiter
 Velikost datoteke:  39.58 KB
Ivor
Prispevkov: 213
Aktiv.: 1.01
PrispevekObjavljeno: Sre Apr 09, 2025 11:38 am    Naslov sporočila:   Odgovori s citatom
Kondenzator
 Velikost datoteke:  17.95 KB
mateik
Prispevkov: 261
Aktiv.: 7.50
PrispevekObjavljeno: Sre Apr 16, 2025 7:23 am    Naslov sporočila:   Odgovori s citatom
Very Happy
 Velikost datoteke:  40.96 KB
 Pogledana:  10 krat
jozkoc
Prispevkov: 589
Aktiv.: 3.23
PrispevekObjavljeno: Sre Apr 16, 2025 1:18 pm    Naslov sporočila:   Odgovori s citatom
hysterical
@mateik, car humorja.
Ivor
Prispevkov: 213
Aktiv.: 1.01
PrispevekObjavljeno: Čet Apr 17, 2025 10:53 am    Naslov sporočila:   Odgovori s citatom
Poroka je zveza, v kateri ima ena oseba vedno prav, druga oseba je pa mož. Very Happy
Ivor
Prispevkov: 213
Aktiv.: 1.01
PrispevekObjavljeno: Čet Apr 17, 2025 11:20 am    Naslov sporočila:   Odgovori s citatom
Mož in žena vedno sklepata kompromise; mož prizna, da se je zmotil, žena pa se z njim strinja. Very Happy
 Velikost datoteke:  105.92 KB
Stran 42 od 43
