Glitch Član
Pridružen-a: Pet 07 Apr 2006 11:40 Prispevkov: 1477 Aktiv.: 6.30
Objavljeno: Tor Jun 02, 2009 7:41 am Naslov sporočila: |
"Takrat" me ni preprical, mogoce tudi zato, ker mi niso delale skripte, ki sem jih mel za kontrolo kanalov oz. botov. _________________ Answers: $1, Short: $5, Correct: $25, dumb looks are still free. |
Objavljeno: Tor Sep 15, 2009 1:21 am Naslov sporočila: |
Evo še par naslovov Ircnet serverjev...
http://www.ircnet.com/index.php?&p=5 _________________ I'm going to stand outside, so if anyone asks, I'm outstanding  |
VolkD Član
Pridružen-a: Pet 24 Sep 2004 21:58 Prispevkov: 14228 Aktiv.: 59.90 Kraj: Divača (Kačiče)
Objavljeno: Sre Okt 07, 2009 11:19 pm Naslov sporočila: |
Kaj vse se da videti na IRC kanalu elektronik.si:
Koda: |
(23:09:00) (@VolkD) A good delphi programmer is JernejL
(23:09:11) (@VolkD) JernejL !
(23:09:12) (@VolkD) JernejL !
(23:09:13) (@VolkD) JernejL !
(23:09:25) (@VolkD) A question for you !!
(23:09:42) (+JernejL) i'm listening :D
(23:09:48) (+sphere) this is a Time problem , i know it is something silly but dont know what
(23:10:35) (+sphere) using TFrames in Delphi. I'm placing a few copies of the same Frame on a Form. The frames contain a display, formed by a TPanel, of which the value could be set using a TUpDown next to it.
(23:11:05) (+sphere) After displaying this form, both UpDowns in each Frame works fine. Their values are shown on the displays, the value of the UpDown in one frame hasn't any influence on the one in the other frame. So far so good, this is as I expected.
(23:11:35) (+sphere) The frames do own a TTimer component, defined in the TFrame Unit. The Timer1 procedure is supposed to count down, and refresh the value on the display. And here is the problem that occurs: both displays show the same counted-down times. Obviously, the Timer procedures don't act independantly, although they're defined as private in the TFrame
(23:12:01) (+sphere) Both frames on the Form are descendants of the same frame Class. At the moment, the only solution I see is to place the timer with it's procedure in the form that contains the frames, but by doing that I would loose much of the advantages of using frames in the first place. So I wouldn't like that..
(23:12:06) (+sphere) any ideas
(23:12:46) (+JernejL) you will have to write a custom component, there's no other way around this
(23:13:06) (+JernejL) because the frames themselves aren't exactly a copy of the elements.. but somewhat a mirror
(23:13:27) (+JernejL) and i never got this working quite correct
(23:13:32) (+sphere) they start off at differant times but then all become the same
(23:13:38) (+JernejL) frames are best avoided..
(23:14:27) (+sphere) so how best to work on the component
(23:15:47) (+JernejL) there's tutorials
(23:15:55) (+JernejL) there may be something like it already created
(23:16:07) (+sphere) best place to look
(23:18:54) (+sphere) thank you so much for the help, it saves me another 3 days trying to work out what i did wrong :)
(23:18:59) (+JernejL) torry.ru
(23:19:44) (+sphere) will have a look there thanx again
Objavljeno: Sre Feb 10, 2010 10:54 pm Naslov sporočila: |
update!
Kanal #elektronik.si je preseljen na nov server: IRC.SIOFF.NET.
+ Domač server, brez spama in zunanjih padalcev.
+ Brez splitanja in nedosegljivih serverjev.
- Dostop preko web bo malo bolj težaven (treba vpisat eno polje več).
web dostop:
http://www.mibbit.com/chat/
In ne pozabite kliknit na Charset in nastavit na "UTF-8" (sicer naj bi bila to že privzeta nastavitev). _________________ I'm going to stand outside, so if anyone asks, I'm outstanding  |
Branez Moderator
Pridružen-a: Pon 14 Apr 2003 7:21 Prispevkov: 7831 Aktiv.: 32.97 Kraj: Koprivnica HR
Objavljeno: Pet Feb 12, 2010 9:03 pm Naslov sporočila: |
Pojma nimam za kaj gre! Bi lahko kdo malo razsvetlil pojme enemu staremu sitnemi dedcu? Nismo vsi otroci interneta.
Še najpametnejša stvar je klepetalnik na forumu _________________ The true sign of intelligence is not knowledge but imagination.
Albert Einstein |
mirkatmir Član
Pridružen-a: Pet 25 Jul 2003 9:14 Prispevkov: 1876 Aktiv.: 7.90 Kraj: Ribnica (JN75IR)
Objavljeno: Pet Feb 12, 2010 9:33 pm Naslov sporočila: |
Branez je napisal/a: |
Pojma nimam za kaj gre! Bi lahko kdo malo razsvetlil pojme enemu staremu sitnemi dedcu? Nismo vsi otroci interneta. |
 _________________ lp, Miran (Miro - S51SK) |
Branez Moderator
Objavljeno: Pet Feb 12, 2010 9:36 pm Naslov sporočila: |
Sem vsaj odkritosrčen. Moram pa napisati še vztrajnem. Našel sem!!!!!! _________________ The true sign of intelligence is not knowledge but imagination.
Albert Einstein |
RUros Član
Pridružen-a: Čet 09 Mar 2006 22:26 Prispevkov: 1031 Aktiv.: 4.38
Objavljeno: Pet Feb 12, 2010 11:40 pm Naslov sporočila: |
Ki se pa ne uporablja, zakaj  |
Branez Moderator
Objavljeno: Pet Feb 12, 2010 11:41 pm Naslov sporočila: |
Ker nihče ne pogleda tja! Še vidva sta zginila za par sekund.  _________________ The true sign of intelligence is not knowledge but imagination.
Albert Einstein |
RUros Član
Objavljeno: Pet Feb 12, 2010 11:48 pm Naslov sporočila: |
Pogledam večkrat, pa sem ponavadi sam tam, in potem debata nekako ne steče  |
Sibica Član
Pridružen-a: Sob 02 Maj 2009 15:24 Prispevkov: 1097 Aktiv.: 5.57 Kraj: Vremska Dolina
Objavljeno: Tor Jan 25, 2011 10:22 pm Naslov sporočila: |
Hmm...trudim se priti na IRC a mi nikakor ne uspe. DOstopam z Mibbit-om.
Problem je ker irc.sioff.net nikjer ne najdem. Kako to?  _________________ Slabih pilotov ni. So dobri ali pokojni. |
Objavljeno: Tor Jan 25, 2011 10:53 pm Naslov sporočila: |
kanal: #elektronik.si
pa bo šlo. _________________ I'm going to stand outside, so if anyone asks, I'm outstanding  |
Pridružen-a: Pon 24 Feb 2003 17:09 Prispevkov: 14677 Aktiv.: 61.79
Objavljeno: Tor Jan 25, 2011 11:08 pm Naslov sporočila: |
Port port 6697 _________________ lp
sars Član
Pridružen-a: Tor 05 Jan 2010 20:40 Prispevkov: 671 Aktiv.: 3.56 Kraj: Vransko
Objavljeno: Tor Maj 03, 2011 10:55 pm Naslov sporočila: |
... urejeno _________________ Ko misliš, da nimaš sreče v življenju, pomisli na voznike Renaultov.  |
Objavljeno: Sob Mar 24, 2012 12:39 am Naslov sporočila: |
Glede na to, da je trenutno kar živahno na forumskem klepetu - sem dvignil tole staro temo na plan. Za tiste, ki ne veste-že dolgo časa obratuje tudi irc kanal elektronik.si _________________ lp
