marko11 Član
Pridružen-a: Ned 14 Dec 2003 17:47 Prispevkov: 893 Aktiv.: 3.77 Kraj: Dobrepolje
Objavljeno: Čet Jan 06, 2005 6:32 pm Naslov sporočila: Velikost spremenljivk |
Koliksne so preostale spremenljivke - Bascom
Dim B1 As Bit ' 0 ali 1
Dim A As Byte ' 0-255
Dim C As Integer ' -32767 - +32768
Dim B As Word
Dim L As Long
Dim S As Single
LP,marko _________________ Če ne veš kam greš, se ne moreš zgubiti. |
G-Lab Član
Pridružen-a: Sob 12 Jul 2003 9:44 Prispevkov: 179 Aktiv.: 0.76 Kraj: Jesenice
Objavljeno: Čet Jan 06, 2005 10:59 pm Naslov sporočila: |
Še string ti ostane.
Uporabi Help pa napiši: Language Fundamentals
tam notri imaš lepo razloženo.
LP |
strobos Član
Pridružen-a: Sre 24 Sep 2003 12:19 Prispevkov: 726 Aktiv.: 3.06 Kraj: Brežice
Objavljeno: Čet Jan 06, 2005 11:50 pm Naslov sporočila: |
Elementary Data Types
· Bit (1/8 byte). A bit can hold only the value 0 or 1.
A group of 8 bits is called a byte.
· Byte (1 byte).
Bytes are stores as unsigned 8-bit binary numbers ranging in value from 0 to 255.
· Integer (two bytes).
Integers are stored as signed sixteen-bit binary numbers ranging in value from -32,768 to +32,767.
· Word (two bytes).
Words are stored as unsigned sixteen-bit binary numbers ranging in value from 0 to 65535.
· Long (four bytes).
Longs are stored as signed 32-bit binary numbers ranging in value from -2147483648 to 2147483647.
· Single.
Singles are stored as signed 32 bit binary numbers. Ranging in value from
1.5 x 10^–45 to 3.4 x 10^38
· String (up to 254 bytes).
Strings are stored as bytes and are terminated with a 0-byte.
A string dimensioned with a length of 10 bytes will occupy 11 bytes. |
Uptime: 492 dni
