LibreOffice vs. OpenOffice
erbi
Pridružen-a: Pon 24 Okt 2011 16:40
Prispevkov: 213
Aktiv.: 1.28
Kraj: Celje
PrispevekObjavljeno: Ned Feb 14, 2016 11:09 am    Naslov sporočila:  LibreOffice vs. OpenOffice Odgovori s citatom
Zanima me, če je že kdo naredil primerjavi med LibreOffice in OpenOffice. Kakšne so razlike?
Sprašujem za XP varianto....
Highlag
Prispevkov: 4034
Aktiv.: 16.98
Kraj: Črnuče
PrispevekObjavljeno: Ned Feb 14, 2016 2:35 pm    Naslov sporočila:   Odgovori s citatom
Razlika je, a ne zelo velika. Libre je rahlo izboljšan OpenOffice. Predvsem zato, ker je Open nekaj let stagniral. V bistvu se še vedno precej počasi obračajo. Pri Libre so očistili kodo starine in dodajajo nove funkcionalnosti, ki jo Open nima.
Dorijan
Prispevkov: 2564
Aktiv.: 12.36
Kraj: južnoprimorska
PrispevekObjavljeno: Pon Feb 15, 2016 10:33 am    Naslov sporočila:   Odgovori s citatom
Težava je razlika v open source licencah kar omogoča libre office, da jemlje dele kode iz open offica obratno pa ni možno.
The Apache OpenOffice project uses the Apache License, while the LibreOffice uses a dual LGPLv3 / MPL license. The practical result is LibreOffice can take OpenOffice’s code and incorporate it into LibreOffice — the licenses are compatible.
On the other hand, LibreOffice has some features — like font embedding — that don’t appear in OpenOffice. This is because the two different licenses only allow a one-way transfer of code. LibreOffice can incorporate OpenOffice’s code, but OpenOffice can’t incorporate LibreOffice’s code. This is the result of the different licenses the projects chose.
In the long run, this means that big improvements to OpenOffice can be incorporated into LibreOffice, while big improvements to LibreOffice can’t be incorporated into OpenOffice. This clearly gives a big advantage to LibreOffice, which will develop quicker and incorporate more features and improvements.
Spajky
Prispevkov: 1095
Aktiv.: 5.99
Kraj: Obala
PrispevekObjavljeno: Pon Feb 15, 2016 12:09 pm    Naslov sporočila:   Odgovori s citatom
Po netu je ogromno ms kompatible "office" paketov, tudi free, ki so nekajkrat manjša in hitrejša kot tale dva navedena za starejše kompe ... samo je treba malo poiskat ...
Prispevkov: 5824
Aktiv.: 24.52
PrispevekObjavljeno: Pon Feb 15, 2016 2:48 pm    Naslov sporočila:   Odgovori s citatom
Spajky, preberi še enkrat vprašanje!
Dorijan je odgovoril točno tisto, kar se sprašuje!
