Server?
aljoš
Prispevkov: 3132
Aktiv.: 13.18
PrispevekObjavljeno: Pon Avg 04, 2008 5:40 pm    Naslov sporočila:  Server? Odgovori s citatom
Na mojem računalniku imam priklopljeno videokartico in nanjo priključeno eno kamer za nadzor...sedaj me pa zanima, kako bi naredil server, se pravi, da bi iz drugega računalnika videl svojo kamero?
Zraven sem dobil CD s pomočjo in raznim softverom, vse ok instalirano...ne znam pa postaviti serverja... v pomoči piše to za win98:
You may need to setup the Client and Server System for remote viewing, playback of archive video and recording if you are going to use the remote access function of this application. Please follow the installation and setup instruction belows.
Dial up client TCP/IP setup
TCP/IP Setup for dial up Client:
1. Double click "my computer" on the desktop, then double click dial-up networking icon;
2. Right click the specified dial-up networking connection, which will be used as your dial-up client connection;
3. Select the "Properties" option from the popup menu, the click on "Server Type" option;
4. Make sure the "PPP: Internet, Windows NT Server, Windows98 " item is selected from the "Type of Dial-up Server" combo box;
5. Make sure the "Log on to network" and "Enable software compression" are both checked in the "Advanced options" group option box;
6. Make sure "NetBEUI" and "TCP/IP" are both checked in the "Allowed network protocols:" group option box;
7. Click "TCP/IP Settings" command box, the "TCP/IP Settings" dialog box appears;
8. Check the "Specify the IP address" option, enter "192.168.55.2" to the IP address entry;
9. Click "OK" twice, return to dial-up networking window.
** Please refer to Section 4 of The installation guide for the detailed information about the TCP/IP setup for both SERVER and CLIENT.
kako to naredim na win XP?
airwolf
Prispevkov: 2222
Aktiv.: 10.67
Kraj: Polhov Gradec
PrispevekObjavljeno: Pon Avg 04, 2008 6:01 pm    Naslov sporočila:   Odgovori s citatom
Večina nastavitev je enakih, le Log on to network nisem našel. Ostalo je enako.
mucek4
Prispevkov: 2952
Aktiv.: 12.42
PrispevekObjavljeno: Pon Avg 04, 2008 7:57 pm    Naslov sporočila:   Odgovori s citatom
Definiraj kaj je to "drug računalnik". Če je v isti mreži ne vem če rabiš tako zakomplicirat Smile
robert
Prispevkov: 1908
Aktiv.: 8.03
Kraj: Tolmin
PrispevekObjavljeno: Pon Avg 04, 2008 8:42 pm    Naslov sporočila:   Odgovori s citatom
V nadzorni plosci>dodaj ali odstrani programe>dodaj/odstrani komponente programa Windows >obkljukas Internet information service(IIS)
Na C: disku se ti pojavi mapa Inetpub.
V mapo C\Inetpub\wwwroot moras dati naslovno datoteko index.html ali index.htm - naredis lahko tudi v Wordu in "save as"...
Pa na pozarnemu zidu (firewall) bo tudi treba odpirati porte.
Do svoje "spletne strani" dostopas enostavno z IP naslovom tvojega racunalnalnika.
Sedaj pa je odvisno ali hoces dostopati samo iz svojega domacega omrezja ali od koderkoli.Za povezavo preko spleta priporocam DYNDNS,kjer registriras "lastno domeno" in ti ni potrebno stalno gledati tvojega IP. Jaz imam klienta za to na routerju-firewallu.
Moj hisni server je p333 z 256Mb RAMa in dvemi diski 6Gb(sistemski) in 250Gb(Arhiv).Meri mi temperaturo z Dallasovimi senzorji- http://doma.selfip.net ,nanj je prikljucena tudi ena poceni USB kamera z programom WebcamXP in gor je instalirana "siva kosmata zival",ki mi stalno tovori "razne" stvari z neta.
LP Robert
aljoš
Prispevkov: 3132
Aktiv.: 13.18
PrispevekObjavljeno: Tor Avg 05, 2008 8:27 am    Naslov sporočila:   Odgovori s citatom
Dostopati bi želel s kjerkoli... ustvaril sem si domeno (mojinstitut.ath.cx) sedaj bom poskusil pa še druge stvari poštimat...
mucek4
Prispevkov: 2952
Aktiv.: 12.42
PrispevekObjavljeno: Tor Avg 05, 2008 8:35 am    Naslov sporočila:   Odgovori s citatom
Ti enostavno rabiš na routerju redirectat port na svoj računalnik, na svojem računalniku pa najbolje da postaviš HTTP ali HTTPS strežnik kjer boš lahko to gledal. In to je to.
Za razlago laikom bi pa potreboval cca 16M za tekst, da opišem vse možne variante za vse možne operacijske sisteme in routerje.
Če lahko omejiš izbor: Kakšno videokartico, kater OS, kater router, ....
aljoš
Prispevkov: 3132
Aktiv.: 13.18
PrispevekObjavljeno: Tor Avg 05, 2008 12:01 pm    Naslov sporočila:   Odgovori s citatom
Videokartica PICO 2000, Win XP, Router LINKSYS...
sundancer
Pridružen-a: Ned 08 Avg 2004 22:30
Prispevkov: 374
Aktiv.: 1.57
PrispevekObjavljeno: Tor Avg 05, 2008 8:58 pm    Naslov sporočila:   Odgovori s citatom
poskusi z www.videolan.org
Uptime: 10 dni
