Jule Član
Pridružen-a: Sob 27 Okt 2007 12:48 Prispevkov: 2533 Aktiv.: 11.79 Kraj: Ajdovščina
Objavljeno: Pet Maj 08, 2009 6:07 pm Naslov sporočila: Mini osciloskop s PIC12f675 |
http://www.dos4ever.com/uscope/uscope_e.html
Pravi, da se priklopi na scart. Vendar je le en video out izhod. Kam se priklopi? Na antenski vhod? _________________ lp Jure |
bungee Član
Objavljeno: Pet Maj 08, 2009 7:42 pm Naslov sporočila: |
Scart nima antenskega vhoda ima pa vide vhod, torej ....  |
Jule Član
Objavljeno: Pet Maj 08, 2009 8:01 pm Naslov sporočila: |
Pin 1 Audio output (right)
Pin 2 Audio input (right)
Pin 3 Audio output (left/mono)
Pin 4 Audio ground
Pin 5 RGB Blue ground (pin 7 ground)
Pin 6 Audio input (left/mono)
Pin 7 RGB Blue up
S-Video C down1)
Component Pb up2)
Pin 8 Status & Aspect Ratio up3) [0-0.4V → off, 5-8V → 16:9, 9.5-12V → on/4:3]
Pin 9 RGB Green ground (pin 11 ground)
Pin 10 Clock / Data 24)
Control bus (AV.link)
Pin 11 RGB Green up
Component Y up2)
Pin 12 Reserved / Data 14)
Pin 13 RGB Red ground (pin 15 ground)
Pin 14 pin 12 & pin 16 ground
Pin 15 RGB Red up S-Video C up
Component Pr up2)
Pin 16 Blanking signal up
RGB-selection voltage up [0-0.4V → composite, 1-3V → RGB]
Pin 17 Composite video output ground (pin 19 ground)
Pin 18 Composite video input ground (pin 20 ground)
Pin 19 Composite video output
S-Video Y output
Pin 20 Composite video input
S-Video Y input
Pin 21 pin 8 & pin 10 ground
Se pravi med 18 in 20 pin? _________________ lp Jure |
Azrael Član
Pridružen-a: Čet 29 Jan 2009 19:46 Prispevkov: 4432 Aktiv.: 22.22 Kraj: Gorje
Objavljeno: Pet Maj 08, 2009 8:42 pm Naslov sporočila: |
Tako je. |
PrimozL Član
Pridružen-a: Tor 21 Mar 2006 10:55 Prispevkov: 404 Aktiv.: 1.72 Kraj: okolica Vipave
Objavljeno: Pet Maj 08, 2009 9:40 pm Naslov sporočila: Re: Mini osciloskop s PIC12f675 |
Jule je napisal/a: |
http://www.dos4ever.com/uscope/uscope_e.html |
Tale osciloskop poznaš? Priklopi se na USB.
http://www.semifluid.com/?p=24
LP Primož. |
Jule Član
Objavljeno: Sob Maj 09, 2009 9:16 am Naslov sporočila: |
Ne poznam. Ma tega mojega bom naredil bolj za hec kot kaj resnega.. Imam vse dele doma pa veliko prostega časa..  _________________ lp Jure |
Jule Član
Objavljeno: Sob Maj 09, 2009 5:20 pm Naslov sporočila: |
A to mojo reč lahko priklopim na "činč" (RCA) priključek na TV? _________________ lp Jure |
jjakob Član
Objavljeno: Sob Maj 09, 2009 8:46 pm Naslov sporočila: |
Da. |
zažigalec Član
Pridružen-a: Sre 17 Dec 2008 21:19 Prispevkov: 174 Aktiv.: 0.87 Kraj: Vipavski Križ (blizu)
Objavljeno: Sob Maj 09, 2009 9:43 pm Naslov sporočila: Re: Mini osciloskop s PIC12f675 |
Pravi, da se priklopi na scart. Vendar je le en video out izhod. Kam se priklopi? Na antenski vhod? |
waw waw to moram tud jaz provat napravit zanimivo zanimivo samo pic moram dobit  |
tibi Član
Pridružen-a: Tor 16 Dec 2003 11:08 Prispevkov: 253 Aktiv.: 1.07 Kraj: bukovje
Objavljeno: Pon Maj 11, 2009 6:48 am Naslov sporočila: |
Jaz pa sem se ogrel za osciloskop z grafičnim prigazovalnikom, pa še en KS0108 mi leži doma v predalu Doma sicer imam navadni osciloskop, tega pa bi lahko izdelal kot prenosnega.
http://www.semifluid.com/?cat=10 |
drVrh Član
Pridružen-a: Sre 20 Feb 2008 20:17 Prispevkov: 918 Aktiv.: 4.35 Kraj: Slovenija-Koroska-Prevalje-Lese
Objavljeno: Pon Maj 11, 2009 12:12 pm Naslov sporočila: |
Ima še kdo kakšen ''ibržen'' odveč LCD KS0108, ga odkupim. _________________ Iz dneva v dan sem se spraševal kaj je to elektrika, vendar nisem našel odgovora ... in še vedno si postavljam to vprašanje
Grega |
Glitch Član
Pridružen-a: Pet 07 Apr 2006 11:40 Prispevkov: 1477 Aktiv.: 6.32
Objavljeno: Pon Maj 11, 2009 12:41 pm Naslov sporočila: |
Hm... jaz imam nek grafični s touchem, ki smo ga nabavli preko foruma. Stvar sem naredil, probal, dela... Bom pobrskal, če te zanima mi pošlji ZS. _________________ Answers: $1, Short: $5, Correct: $25, dumb looks are still free. |
Azrael Član
Objavljeno: Tor Jan 05, 2010 8:27 pm Naslov sporočila: |
Vem, da je tema iz naftalina, toda, že nekaj časa me muči naslednje vprašanje okoli uC, ki je bil uporabljen v projektu osciloskopa, ki se priklopi na SCART.
Po specifikacijah ima 12F675 1.75KB flash pomnilnika, hex datoteka tega projekta pa je več kot 3x večja (5804B). Je to normalno in hex vsebuje tudi morebitne parametre za programsko opremo programatorja?
Verjamem, da se bo vprašanje mogoče komu zdelo butasto, toda nisem se še ukvarjal z uC, rad pa bi se naučil kaj novega. |
Objavljeno: Tor Jan 05, 2010 8:32 pm Naslov sporočila: |
V datoteki so podatki, ki jih potrebuje software za programiranje. V sam mikrokontroler pa se ne vpisujejo. Recimo lokacije, postavljeni fuse biti... _________________ lp
Azrael Član
Objavljeno: Tor Jan 05, 2010 11:03 pm Naslov sporočila: |
Hvala, potemtakem sem prav sklepal.
Še vprašanje, je mogoče kdo ta osciloskop sestavil? Je napravica uporabna, ali gre samo za zanimivo tehnično igračo? |
