nakamichi Član
Pridružen-a: Pon 21 Avg 2006 18:51 Prispevkov: 845 Aktiv.: 3.69 Kraj: Nova Gorica
Objavljeno: Pon Nov 02, 2009 4:29 pm Naslov sporočila: UART problem |
Upadam se z implementacijo UARTa v Xilinxa. Uporabil sem uart module, ki pridejo z KCPSM procesorjem.
Moja koda:
Koda: |
entity uart_test is
Port ( clk_50MHz : in STD_LOGIC;
TxD : out STD_LOGIC;
tipka : in STD_LOGIC);
end uart_test;
architecture uart of uart_test is
COMPONENT uart_tx
PORT(
data_in : IN std_logic_vector(7 downto 0);
write_buffer : IN std_logic;
reset_buffer : IN std_logic;
en_16_x_baud : IN std_logic;
clk : IN std_logic;
serial_out : OUT std_logic;
buffer_full : OUT std_logic;
buffer_half_full : OUT std_logic
END COMPONENT;
signal data : std_logic_vector(7 downto 0);
signal wb : std_logic;
signal rb : std_logic;
signal Tx_int : std_logic;
signal baud : std_logic;
signal buff_full : std_logic;
signal buff_hfull : std_logic;
signal divider : integer range 0 to 2;
signal q1 : std_logic;
signal q2 : std_logic;
begin
Inst_uart_tx: uart_tx PORT MAP(
data_in => data,
write_buffer => wb,
reset_buffer => rb,
en_16_x_baud => baud,
serial_out => Tx_int,
buffer_full => buff_full,
buffer_half_full => buff_hfull,
clk => clk_50Mhz
TxD <= Tx_int;
data <= "10101010";
rb <= '0';
--baud <= '1';
baud_gen:
process(clk_50Mhz, divider)
begin
if rising_edge(clk_50MHz) then
if divider = 2 then
divider <= 0;
baud <= '1';
else
divider <= divider + 1;
baud <= '0';
end if;
end if;
end process;
tipka_imp:
process(tipka, clk_50MHz)
begin
if falling_edge(clk_50MHz) then
q1 <= tipka;
q2 <= q1;
wb <= q1 xor q2;
end if;
end process;
end uart; |
Zadeva se lepo kompajla, problem je ker Tx noče in noče delat, ne glede na to kam dam en_16_x_baud. Vse seveda teče v simulatorji.
Prilagam še navodila:
Ime datoteke: |
UART_Manual.pdf |
110.76 KB |
Downloadano: |
3 krat |
Nazadnje urejal/a nakamichi Pon Nov 02, 2009 5:57 pm; skupaj popravljeno 1 krat |
aly Član
Pridružen-a: Tor 28 Sep 2004 14:51 Prispevkov: 9407 Aktiv.: 39.72 Kraj: Kranj - struževo
Objavljeno: Pon Nov 02, 2009 5:53 pm Naslov sporočila: |
Na signalu en_16_x_baud mora bit 16x višja frekvenca kot je dejanski baudrate.
Za test spelji še ta signal ven na en pin in ga pomeri z osciloskopom.
Enako še za WB signal.
Lokacije pinov na čipu imaš sigurno pravilno definirane?
Preglej še kompleten compile report, pri Warningih včasih kaj zanimivega piše (in se kljub temu lepo prevede).
nakamichi Član
Objavljeno: Pon Nov 02, 2009 5:59 pm Naslov sporočila: |
Dejansko stvar za zdej teče v simulatorju kjer vse deluje kot more...samo TX pin je mrzel...nekaj časa H...in po določenem času postane X..v simulatorju. Kar sem gledal zadeve noče spravit v FIFO register kljub impulzu na WB.
L.P.,
Miha
surla Član
Pridružen-a: Ned 14 Dec 2003 15:22 Prispevkov: 722 Aktiv.: 3.05 Kraj: Ljubljana
Objavljeno: Pon Nov 02, 2009 6:01 pm Naslov sporočila: |
Kaj pa CTS pa RTS iz partnerjeve strani?
nakamichi Član
Objavljeno: Pon Nov 02, 2009 6:18 pm Naslov sporočila: |
Poglej datasheet
aly Član
Objavljeno: Pon Nov 02, 2009 7:24 pm Naslov sporočila: |
Timingi so ustrezni?
Printscreen iz simulatorja?
Sicer pa - napiši svojega. Par ur dela. Fifo-ta ponavadi sploh ne rabiš. Če pa že, pa ga vzameš iz CoreGeneratorja.
