UART problem
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> FPGA in CPLD programabilna vezja
nakamichi
Pridružen-a: Pon 21 Avg 2006 18:51
Prispevkov: 845
Aktiv.: 3.53
Kraj: Nova Gorica
PrispevekObjavljeno: Pon Nov 02, 2009 4:29 pm    Naslov sporočila:  UART problem Odgovori s citatom
Upadam se z implementacijo UARTa v Xilinxa. Uporabil sem uart module, ki pridejo z KCPSM procesorjem.
Moja koda:
Koda:
entity uart_test is
    Port (    clk_50MHz    : in  STD_LOGIC;
            TxD         : out STD_LOGIC;
            tipka         : in    STD_LOGIC);
end uart_test;
architecture uart of uart_test is
   COMPONENT uart_tx
   PORT(
      data_in : IN std_logic_vector(7 downto 0);
      write_buffer : IN std_logic;
      reset_buffer : IN std_logic;
      en_16_x_baud : IN std_logic;
      clk : IN std_logic;
      serial_out : OUT std_logic;
      buffer_full : OUT std_logic;
      buffer_half_full : OUT std_logic
   END COMPONENT;
signal data       : std_logic_vector(7 downto 0);
signal wb         : std_logic;
signal rb         : std_logic;
signal Tx_int      : std_logic;
signal baud         : std_logic;
signal buff_full   : std_logic;
signal buff_hfull   : std_logic;
signal divider      : integer range 0 to 2;
signal q1         : std_logic;
signal q2         : std_logic;
begin
   Inst_uart_tx: uart_tx PORT MAP(
      data_in => data,
      write_buffer => wb,
      reset_buffer => rb,
      en_16_x_baud => baud,
      serial_out => Tx_int,
      buffer_full => buff_full,
      buffer_half_full => buff_hfull,
      clk => clk_50Mhz
TxD <= Tx_int;
data <= "10101010";
rb <= '0';
--baud <= '1';
baud_gen:
process(clk_50Mhz, divider)
begin
   if rising_edge(clk_50MHz) then
      if divider = 2 then
         divider <= 0;
         baud <= '1';
      else
         divider <= divider + 1;
         baud <= '0';
      end if;
   end if;
end process;
tipka_imp:
process(tipka, clk_50MHz)
begin
   if falling_edge(clk_50MHz) then
      q1 <= tipka;
      q2 <= q1;
      wb <= q1 xor q2;
   end if;
end process;
end uart;
Zadeva se lepo kompajla, problem je ker Tx noče in noče delat, ne glede na to kam dam en_16_x_baud. Vse seveda teče v simulatorji.
Prilagam še navodila:
UART_Manual.pdf
 Ime datoteke:  UART_Manual.pdf
 Velikost datoteke:  110.76 KB
 Downloadano:  3 krat
Nazadnje urejal/a nakamichi Pon Nov 02, 2009 5:57 pm; skupaj popravljeno 1 krat
Aktiv.: 38.07
PrispevekObjavljeno: Pon Nov 02, 2009 5:53 pm    Naslov sporočila:   Odgovori s citatom
Na signalu en_16_x_baud mora bit 16x višja frekvenca kot je dejanski baudrate.
Za test spelji še ta signal ven na en pin in ga pomeri z osciloskopom.
Enako še za WB signal.
Lokacije pinov na čipu imaš sigurno pravilno definirane?
Preglej še kompleten compile report, pri Warningih včasih kaj zanimivega piše (in se kljub temu lepo prevede).
nakamichi
Prispevkov: 845
Aktiv.: 3.53
Kraj: Nova Gorica
PrispevekObjavljeno: Pon Nov 02, 2009 5:59 pm    Naslov sporočila:   Odgovori s citatom
Dejansko stvar za zdej teče v simulatorju kjer vse deluje kot more...samo TX pin je mrzel...nekaj časa H...in po določenem času postane X..v simulatorju. Kar sem gledal zadeve noče spravit v FIFO register kljub impulzu na WB.
L.P.,
Miha
surla
Pridružen-a: Ned 14 Dec 2003 15:22
Prispevkov: 723
Aktiv.: 2.93
PrispevekObjavljeno: Pon Nov 02, 2009 6:01 pm    Naslov sporočila:   Odgovori s citatom
Kaj pa CTS pa RTS iz partnerjeve strani?
nakamichi
Prispevkov: 845
Aktiv.: 3.53
Kraj: Nova Gorica
PrispevekObjavljeno: Pon Nov 02, 2009 6:18 pm    Naslov sporočila:   Odgovori s citatom
Poglej datasheet Think
Aktiv.: 38.07
PrispevekObjavljeno: Pon Nov 02, 2009 7:24 pm    Naslov sporočila:   Odgovori s citatom
Timingi so ustrezni?
Printscreen iz simulatorja?
Sicer pa - napiši svojega. Par ur dela. Fifo-ta ponavadi sploh ne rabiš. Če pa že, pa ga vzameš iz CoreGeneratorja.
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> FPGA in CPLD programabilna vezja Časovni pas GMT + 2 uri, srednjeevropski - poletni čas
