vilko Član
Pridružen-a: Pet 13 Feb 2004 10:26 Prispevkov: 3362 Aktiv.: 14.18 Kraj: Dragomer
Objavljeno: Pet Feb 25, 2011 3:58 pm Naslov sporočila: SMD upor formata 1206 koliko moči prenese? |
SMD upor formata 1206 koliko toplotne moči prenese?
Desetinko vata? Manj? |
Obelix Član
Pridružen-a: Pon 19 Maj 2008 13:59 Prispevkov: 1881 Aktiv.: 9.04 Kraj: Maribor
Objavljeno: Pet Feb 25, 2011 4:01 pm Naslov sporočila: |
0,25 W.
LpA |
GregorN Član
Pridružen-a: Tor 20 Nov 2007 7:48 Prispevkov: 1162 Aktiv.: 5.43 Kraj: Maribor
Objavljeno: Pet Feb 25, 2011 4:02 pm Naslov sporočila: |
Rectangular passive components (mostly resistors and capacitors):
* 01005 (0402 metric) : 0.016" × 0.008" (0.4 mm × 0.2 mm) Typical power rating for resistors 1/32 watt
* 0201 (0603 metric) : 0.024" × 0.012" (0.6 mm × 0.3 mm) Typical power rating for resistors 1/20 watt
* 0402 (1005 metric) : 0.04" × 0.02" (1.0 mm × 0.5 mm) Typical power rating for resistors 1/16 watt
* 0603 (1608 metric) : 0.063" × 0.031" (1.6 mm × 0.8 mm) Typical power rating for resistors 1/16 watt
* 0805 (2012 metric) : 0.08" × 0.05" (2.0 mm × 1.25 mm) Typical power rating for resistors 1/10 or 1/8 watt
* 1206 (3216 metric) : 0.126" × 0.063" (3.2 mm × 1.6 mm) Typical power rating for resistors 1/4 watt
* 1210 (3225 metric) : 0.126" × 0.1" (3.2 mm × 2.5 mm) Typical power rating for resistors 1/2 watt
* 1808 (4516 metric) : 0.177" × 0.063" (4.5 mm × 1.6 mm)
* 1812 (4532 metric) : 0.18" × 0.12" (4.5 mm × 3.2 mm) Typical power rating for resistors 1/2 watt
* 2010 (5025 metric) : 0.2" × 0.1" (5.0 mm × 2.5 mm) Typical power rating for resistors 1/2 watt
* 2512 (6332 metric) : 0.25" × 0.12" (6.35 mm × 3.0 mm) Typical power rating for resistors 1 watt
Vir:Wikipedia _________________ LP! Gregor |
vilko Član
Objavljeno: Pet Feb 25, 2011 4:03 pm Naslov sporočila: |
Se mi zdi ker precej, glede na drobcenost zrnca, ki predstavlja upor.
Hvala!
Bo že držalo, če wikipedija tako piše. |
reber Član
Pridružen-a: Pon 26 Maj 2003 12:20 Prispevkov: 2279 Aktiv.: 9.61 Kraj: Bled
Objavljeno: Pet Feb 25, 2011 4:25 pm Naslov sporočila: |
Glede na to, da se upor zaradi direktne montaže na vezje, hladi kar v vezje, se mi napisane moči ne zdijo pretirane. Če je vezje pravilno dimenzionirano in ni prevelika gostota obremenjenih uporov, se tudi vezje ne bo pregrevalo. V primeru, da imamo več uporov, ki so blizu polne obremenitve, je smiselno vezje načrtovati z več bakra in razmak med upori povečati, seveda pa je smiselna tudi paralelna ali serijska vezava uporov, za porazdelitev disipacije in tudi napetosti, kadar nastopajo nekoliko višje napetosti na uporu. _________________ Obiščite me na www.reber.si ali www.elektron.si |
Uptime: 498 dni
