SMD upor formata 1206 koliko moči prenese?
vilko
Prispevkov: 3362
Aktiv.: 14.18
Kraj: Dragomer
PrispevekObjavljeno: Pet Feb 25, 2011 3:58 pm    Naslov sporočila:  SMD upor formata 1206 koliko moči prenese? Odgovori s citatom
SMD upor formata 1206 koliko toplotne moči prenese?
Desetinko vata? Manj?
Obelix
Prispevkov: 1881
Aktiv.: 9.04
PrispevekObjavljeno: Pet Feb 25, 2011 4:01 pm    Naslov sporočila:   Odgovori s citatom
0,25 W.
LpA
GregorN
Prispevkov: 1162
Aktiv.: 5.43
PrispevekObjavljeno: Pet Feb 25, 2011 4:02 pm    Naslov sporočila:   Odgovori s citatom
Rectangular passive components (mostly resistors and capacitors):
* 01005 (0402 metric) : 0.016" × 0.008" (0.4 mm × 0.2 mm) Typical power rating for resistors 1/32 watt
* 0201 (0603 metric) : 0.024" × 0.012" (0.6 mm × 0.3 mm) Typical power rating for resistors 1/20 watt
* 0402 (1005 metric) : 0.04" × 0.02" (1.0 mm × 0.5 mm) Typical power rating for resistors 1/16 watt
* 0603 (1608 metric) : 0.063" × 0.031" (1.6 mm × 0.8 mm) Typical power rating for resistors 1/16 watt
* 0805 (2012 metric) : 0.08" × 0.05" (2.0 mm × 1.25 mm) Typical power rating for resistors 1/10 or 1/8 watt
* 1206 (3216 metric) : 0.126" × 0.063" (3.2 mm × 1.6 mm) Typical power rating for resistors 1/4 watt
* 1210 (3225 metric) : 0.126" × 0.1" (3.2 mm × 2.5 mm) Typical power rating for resistors 1/2 watt
* 1808 (4516 metric) : 0.177" × 0.063" (4.5 mm × 1.6 mm)
* 1812 (4532 metric) : 0.18" × 0.12" (4.5 mm × 3.2 mm) Typical power rating for resistors 1/2 watt
* 2010 (5025 metric) : 0.2" × 0.1" (5.0 mm × 2.5 mm) Typical power rating for resistors 1/2 watt
* 2512 (6332 metric) : 0.25" × 0.12" (6.35 mm × 3.0 mm) Typical power rating for resistors 1 watt
Vir:Wikipedia
LP! Gregor
vilko
Prispevkov: 3362
Aktiv.: 14.18
Kraj: Dragomer
PrispevekObjavljeno: Pet Feb 25, 2011 4:03 pm    Naslov sporočila:   Odgovori s citatom
Se mi zdi ker precej, glede na drobcenost zrnca, ki predstavlja upor.
Hvala!
Bo že držalo, če wikipedija tako piše.
reber
Prispevkov: 2279
Aktiv.: 9.61
Kraj: Bled
PrispevekObjavljeno: Pet Feb 25, 2011 4:25 pm    Naslov sporočila:   Odgovori s citatom
Glede na to, da se upor zaradi direktne montaže na vezje, hladi kar v vezje, se mi napisane moči ne zdijo pretirane. Če je vezje pravilno dimenzionirano in ni prevelika gostota obremenjenih uporov, se tudi vezje ne bo pregrevalo. V primeru, da imamo več uporov, ki so blizu polne obremenitve, je smiselno vezje načrtovati z več bakra in razmak med upori povečati, seveda pa je smiselna tudi paralelna ali serijska vezava uporov, za porazdelitev disipacije in tudi napetosti, kadar nastopajo nekoliko višje napetosti na uporu.
Uptime: 498 dni
