Kaj počnem - December 2023
SimonS
Prispevkov: 4770
Aktiv.: 20.08
Kraj: Kobarid
PrispevekObjavljeno: Sre Dec 20, 2023 11:20 am    Naslov sporočila:   Odgovori s citatom
Če se ti ne sanja, potem ne tikaj knjižnice Smile
0xFA (hex) = 250 (dec) ampak tega ne spreminjaj, ker tako pač mora biti!
Sicer pa zakaj nebi uporabil sprintf? Saj si sam napisal primer, kako prikazati le eno decimalko.
Ne prikazuj direktno izhod senzorja na println, ampak ga daj v eno neznako (float) in potem z sprintf prikaži le eno decimakno.
Koda:
float T = bmp.readTemperature();
char buf[10];
sprintf(buf, "%.1f", T);  // .1 means: print 1 numbers after the dot
Lep dan
Simon
Bizgec65
Prispevkov: 2099
Aktiv.: 11.25
Kraj: Trebnje
PrispevekObjavljeno: Sre Dec 20, 2023 11:31 am    Naslov sporočila:   Odgovori s citatom
Seveda je bila to prva stvar, ki sem jo preizkusil.
Rezultat:
PS.:
Sem še malo "raziskoval" in naletel na tole: (Še za par ur tuhtanja Smile)
KLIK
Now you might be like… “Wait a second now – I thought you said the “s” character formatter was for a string of characters, but the temperature in Fahrenheit is a floating point value – what gives?!”
Well, here’s the deal.
Sprintf() with Arduino cannot handle floating point values. So if you have to print something that has a decimal point, like 3.14 or 156.7, then you need to convert that float value to a character string first, and then print the string. A handy way to do that is with dtostrf(), which converts a floating point value to a string. I won’t get into that now, but be sure to check out our other video on using dtostrf() with Arduino.
 Velikost datoteke:  3.16 MB
SimonS
Prispevkov: 4770
Aktiv.: 20.08
Kraj: Kobarid
PrispevekObjavljeno: Sre Dec 20, 2023 12:10 pm    Naslov sporočila:   Odgovori s citatom
Saj si potem na koncu dal:
Koda:
u8g2.println (buf);
se opravičujem, da nisem napisal, se mi je zdelo samoumevno....
Lep dan
Simon
Bizgec65
Prispevkov: 2099
Aktiv.: 11.25
Kraj: Trebnje
PrispevekObjavljeno: Sre Dec 20, 2023 1:05 pm    Naslov sporočila:   Odgovori s citatom
Sem ja, potem pa dobim "? °C"
Sem še TOLE šel brati in mi še vedno marsikaj ni jasno. Če dam kak drug argument za "%1" dobim izpis ampak ne pravi, neke 4 mestne številke.
Ta "sprintf" bi moral izpisati natanko to kar želim, ampak...
Se tudi sam opravičujem, ker mogoče sprašujem traparije, ampak se vse te stvari šele učim, pa še to bolj počasi. Smile
Prispevkov: 3533
Aktiv.: 31.39
PrispevekObjavljeno: Sre Dec 20, 2023 9:05 pm    Naslov sporočila:   Odgovori s citatom
Najlažje se je igrati v kakem online prevajalniku, npr.:
https://onecompiler.com/c/3zwzaqpyq
SimonS
Prispevkov: 4770
Aktiv.: 20.08
Kraj: Kobarid
PrispevekObjavljeno: Sre Dec 20, 2023 9:49 pm    Naslov sporočila:   Odgovori s citatom
Probaj tako:
Koda:
char buf[10];
u8g2.println (buf);
Serial.println (buf);
Tako boš videl tudi naserijskem portu kaj ti izpiše
sicer pa %.1f pomeni izpis na 1. decimalko spremenljivke float
Lep dan
Simon
Bizgec65
Prispevkov: 2099
Aktiv.: 11.25
Kraj: Trebnje
PrispevekObjavljeno: Sre Dec 20, 2023 10:45 pm    Naslov sporočila:   Odgovori s citatom
To sem že vse naredil, na serial portu je isto. Tisto "%.1f" mi je jasno, edino kar nisem preizkusil, je še, da v Float vpišem kar neko svojo številko, kot v primeru 2 prispevka višje od mosquita in kakor so na netu primeri.
Poročam jutri.
RGorazd
Prispevkov: 1715
Aktiv.: 7.22
Kraj: Ig
PrispevekObjavljeno: Čet Dec 21, 2023 8:19 am    Naslov sporočila:   Odgovori s citatom
float x = 123.456789;
int a, b;
a = (int)x;
b = (int)((x - a) * 10);
printf("%d.%d", a, b);
x = tvoja meritev
printf = sprintf(buff. " Temp: %d.%d", a,b);
LP.
._. _ _ ._. _.__. _|
[ (_](_)[ (_] /_(_]
._|
Bizgec65
Prispevkov: 2099
Aktiv.: 11.25
Kraj: Trebnje
PrispevekObjavljeno: Čet Dec 21, 2023 10:26 am    Naslov sporočila:   Odgovori s citatom
RGorazd
That's it!! Dancing sbeer sbeer
Le tukaj mora biti vejica namesto pike:
Koda:
sprintf(buff, " Temp: %d.%d", a,b);
Sedaj ta del pri meni izgleda takole:
Koda:
float x = bmp.readTemperature();
      int a,b;
      a=(int)x;
      b=(int)((x-a)*10);
      sprintf(buf,"%d.%d",a,b);
      u8g2.print(buf);
Hvala tudi ostalim za potrpljenje in pomoč. Nekaj novega sem se pa tudi vmes naučil. Ko končam še ostali prikaz, objavim sliko.
RGorazd
Prispevkov: 1715
Aktiv.: 7.22
Kraj: Ig
PrispevekObjavljeno: Čet Dec 21, 2023 2:07 pm    Naslov sporočila:   Odgovori s citatom
Me veseli.
Ja, pisal sem na pamet, kompajler bi me opozoril Wink
LP,
[ (_](_)[ (_] /_(_]
._|
Prispevkov: 3533
Aktiv.: 31.39
PrispevekObjavljeno: Čet Dec 21, 2023 7:53 pm    Naslov sporočila:   Odgovori s citatom
Ostanek deljenja z deset lahko izračunaš tudi z opearorjem % (modulo).
b = a % 10;
Bizgec65
Prispevkov: 2099
Aktiv.: 11.25
Kraj: Trebnje
PrispevekObjavljeno: Pet Jan 12, 2024 12:24 pm    Naslov sporočila:   Odgovori s citatom
Sicer bi tile moji prispevki tule lahko romali v Arduino sekcijo...
Končno sem nekaj uspel "spesniti" s tistimle senzorjem in LCDjem:
 Velikost datoteke:  2.96 MB
Stran 3 od 3
Uptime: 9 dni
