SimonS Član
Pridružen-a: Čet 01 Jul 2004 11:18 Prispevkov: 4770 Aktiv.: 20.08 Kraj: Kobarid
Objavljeno: Sre Dec 20, 2023 11:20 am Naslov sporočila: |
Če se ti ne sanja, potem ne tikaj knjižnice
0xFA (hex) = 250 (dec) ampak tega ne spreminjaj, ker tako pač mora biti!
Sicer pa zakaj nebi uporabil sprintf? Saj si sam napisal primer, kako prikazati le eno decimalko.
Ne prikazuj direktno izhod senzorja na println, ampak ga daj v eno neznako (float) in potem z sprintf prikaži le eno decimakno.
Koda: |
float T = bmp.readTemperature();
char buf[10];
sprintf(buf, "%.1f", T); // .1 means: print 1 numbers after the dot |
_________________ Lep dan
Simon |
Bizgec65 Član
Pridružen-a: Sre 10 Mar 2010 11:46 Prispevkov: 2099 Aktiv.: 11.25 Kraj: Trebnje
Objavljeno: Sre Dec 20, 2023 11:31 am Naslov sporočila: |
Seveda je bila to prva stvar, ki sem jo preizkusil.
Rezultat:
PS.:
Sem še malo "raziskoval" in naletel na tole: (Še za par ur tuhtanja )
KLIK
Now you might be like… “Wait a second now – I thought you said the “s” character formatter was for a string of characters, but the temperature in Fahrenheit is a floating point value – what gives?!”
Well, here’s the deal.
Sprintf() with Arduino cannot handle floating point values. So if you have to print something that has a decimal point, like 3.14 or 156.7, then you need to convert that float value to a character string first, and then print the string. A handy way to do that is with dtostrf(), which converts a floating point value to a string. I won’t get into that now, but be sure to check out our other video on using dtostrf() with Arduino.
3.16 MB |
1 krat |
_________________ Če bi nekateri padli z višine svojega ega na višino svoje inteligence, bi se ubili. (Je pa res, da se meni ne smilijo!)  |
SimonS Član
Objavljeno: Sre Dec 20, 2023 12:10 pm Naslov sporočila: |
Saj si potem na koncu dal:
Koda: |
u8g2.println (buf); |
se opravičujem, da nisem napisal, se mi je zdelo samoumevno....
Simon |
Bizgec65 Član
Objavljeno: Sre Dec 20, 2023 1:05 pm Naslov sporočila: |
Sem ja, potem pa dobim "? °C"
Sem še TOLE šel brati in mi še vedno marsikaj ni jasno. Če dam kak drug argument za "%1" dobim izpis ampak ne pravi, neke 4 mestne številke.
Ta "sprintf" bi moral izpisati natanko to kar želim, ampak...
Se tudi sam opravičujem, ker mogoče sprašujem traparije, ampak se vse te stvari šele učim, pa še to bolj počasi.
mosqito Član
Pridružen-a: Čet 07 Apr 2016 23:22 Prispevkov: 3533 Aktiv.: 31.39
Objavljeno: Sre Dec 20, 2023 9:05 pm Naslov sporočila: |
Najlažje se je igrati v kakem online prevajalniku, npr.:
https://onecompiler.com/c/3zwzaqpyq
SimonS Član
Objavljeno: Sre Dec 20, 2023 9:49 pm Naslov sporočila: |
Probaj tako:
Koda: |
char buf[10];
u8g2.println (buf);
Serial.println (buf); |
Tako boš videl tudi naserijskem portu kaj ti izpiše
sicer pa %.1f pomeni izpis na 1. decimalko spremenljivke float
Simon |
Bizgec65 Član
Objavljeno: Sre Dec 20, 2023 10:45 pm Naslov sporočila: |
To sem že vse naredil, na serial portu je isto. Tisto "%.1f" mi je jasno, edino kar nisem preizkusil, je še, da v Float vpišem kar neko svojo številko, kot v primeru 2 prispevka višje od mosquita in kakor so na netu primeri.
Poročam jutri.
RGorazd Član
Pridružen-a: Čet 20 Maj 2004 15:57 Prispevkov: 1715 Aktiv.: 7.22 Kraj: Ig
Objavljeno: Čet Dec 21, 2023 8:19 am Naslov sporočila: |
float x = 123.456789;
int a, b;
a = (int)x;
b = (int)((x - a) * 10);
printf("%d.%d", a, b);
x = tvoja meritev
printf = sprintf(buff. " Temp: %d.%d", a,b);
LP.
_________________ .
._. _ _ ._. _.__. _|
[ (_](_)[ (_] /_(_]
._| |
Bizgec65 Član
Objavljeno: Čet Dec 21, 2023 10:26 am Naslov sporočila: |
RGorazd
That's it!!
Le tukaj mora biti vejica namesto pike:
Koda: |
sprintf(buff, " Temp: %d.%d", a,b);
Sedaj ta del pri meni izgleda takole:
Koda: |
float x = bmp.readTemperature();
int a,b;
a=(int)x;
b=(int)((x-a)*10);
sprintf(buf,"%d.%d",a,b);
u8g2.print(buf);
Hvala tudi ostalim za potrpljenje in pomoč. Nekaj novega sem se pa tudi vmes naučil. Ko končam še ostali prikaz, objavim sliko.
RGorazd Član
Objavljeno: Čet Dec 21, 2023 2:07 pm Naslov sporočila: |
Me veseli.
Ja, pisal sem na pamet, kompajler bi me opozoril
LP,
_________________ .
[ (_](_)[ (_] /_(_]
._| |
mosqito Član
Objavljeno: Čet Dec 21, 2023 7:53 pm Naslov sporočila: |
Ostanek deljenja z deset lahko izračunaš tudi z opearorjem % (modulo).
b = a % 10;
Bizgec65 Član
Uptime: 9 dni
