Update teži
Prispevkov: 16777193
Aktiv.: 70622.25
PrispevekObjavljeno: Ned Dec 02, 2007 8:59 am    Naslov sporočila:  Update teži Odgovori s citatom
Benjamin
Pridružen-a: Tor 10 Jul 2007 11:23
Prispevkov: 116
Aktiv.: 0.53
Kraj: Trebnje, Ljubljana
PrispevekObjavljeno: Ned Dec 02, 2007 10:44 am    Naslov sporočila:   Odgovori s citatom
Zdravo!
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=2258531&SiteID=17
Well, I think I found a solution, for XP at least. I don't know if this will work for everyone experiencing this problem, but here goes.
I downloaded the update program "msxml4-KB936181-enu.exe" from the Microsoft site, not Windows Update.
http://www.microsoft.com/downloads/details.aspx?familyid=021E12F5-CB46-43DF-A2B8-185639BA2807&displaylang=en
I ran the program and told it to remove all.
I rebooted and then ran the program again to install it.
I then ran the Windows Update file for "Security Update for Microsoft XML Core Services 4.0 Service Pack 2".
After reboot, the icon is gone and it no longer pops up.
Yea!!!!!
Good Luck all,
TDeGrenier
Se pravi, Microsoft je spet za**bal Cool
Aktiv.: 70622.25
PrispevekObjavljeno: Ned Dec 02, 2007 10:50 am    Naslov sporočila:   Odgovori s citatom
Aktiv.: 70622.25
PrispevekObjavljeno: Ned Dec 02, 2007 11:11 am    Naslov sporočila:   Odgovori s citatom
mirkatmir
Prispevkov: 1876
Aktiv.: 7.90
Kraj: Ribnica (JN75IR)
PrispevekObjavljeno: Ned Dec 02, 2007 12:13 pm    Naslov sporočila:   Odgovori s citatom
Tudi meni je vseskozi težil (xp), pa sem ga enostavno dal na "ignor".
lp, Miran (Miro - S51SK)
Aktiv.: 70622.25
PrispevekObjavljeno: Ned Dec 02, 2007 12:16 pm    Naslov sporočila:   Odgovori s citatom
Benjamin
Prispevkov: 116
Aktiv.: 0.53
PrispevekObjavljeno: Ned Dec 02, 2007 1:02 pm    Naslov sporočila:   Odgovori s citatom
Za visto piše na isti strani, čisto na koncu:
OK I have a fix for the Vista issue of this problem.
Go to Start > Settings > Control Panel and select Programs and Features. Then Uninstall all entrys related to Microsoft XML core services (These will be clearly marked)
Then close everything down back to the desktop and do a search for updates and you should get the normal 1 XML Core Services 4.0 update. Unstall this and it should fix the problem.
Mogoče bi bilo vredno dodati, avtor ne prevzema nobene odgovornosti za morebitno škodo, vse delaš na lastno odgovornost Smile
Aktiv.: 70622.25
PrispevekObjavljeno: Ned Dec 02, 2007 1:17 pm    Naslov sporočila:   Odgovori s citatom
borber
Prispevkov: 3111
Aktiv.: 13.10
Kraj: LJUBLJANA
PrispevekObjavljeno: Ned Dec 02, 2007 1:45 pm    Naslov sporočila:   Odgovori s citatom
Ta update imam menda inštaliran in nimam težav. Tu je WindowsUpdate.log za primerjavo. Probaj svoje ustrezno popraviti. Mogoče bo kaj pomagalo?
V registru je update vpisan na štirih mestih. Poglej moje izvožene reg filete in poglej pri sebi.
borber
Prispevkov: 3111
Aktiv.: 13.10
Kraj: LJUBLJANA
PrispevekObjavljeno: Ned Dec 02, 2007 2:05 pm    Naslov sporočila:   Odgovori s citatom
Boris poglej še drugi upload. reg2 in reg3 je treba spremeniti, če ju boš hotel vnesti v register, vendar na svojo odgovornost.
Aktiv.: 70622.25
PrispevekObjavljeno: Ned Dec 02, 2007 2:31 pm    Naslov sporočila:   Odgovori s citatom
psevdonim
Prispevkov: 3411
Aktiv.: 14.91
Kraj: slo
PrispevekObjavljeno: Pet Mar 05, 2010 1:40 pm    Naslov sporočila:   Odgovori s citatom
(3 leta kasneje) če inštaliram update KB955759, se po ponovnem zagonu Internet Explorer ne da več zagnati. Pojavi se samo slika kot v prilogi.
Ne pomaga drugega kot obnovitev sistema na točko pred inštalacijo KB955759.
Kakšen nasvet, razlaga ?
Tukaj sicer nekaj piše, a je prezapleteno. Verjetno bo najbolje tale update kar odkljukati in "ne opominjaj več" ?
 Velikost datoteke:  30.88 KB
Nazadnje urejal/a psevdonim Pet Mar 05, 2010 2:28 pm; skupaj popravljeno 3 krat
a.sukljan
Pridružen-a: Tor 02 Mar 2010 20:22
Prispevkov: 85
Aktiv.: 0.45
Kraj: Črni Kal
PrispevekObjavljeno: Pet Mar 05, 2010 2:19 pm    Naslov sporočila:   Odgovori s citatom
Preglej če ti manjka kakšna sistemska datoteka, ki je ključna za delovanje explorerja...
Kar ne dimi, ni skurjeno!
Uptime: 9 dni
